70 351c. Z bar HELP - Vintage Mustang Forums
post #1 of 12 (permalink) Old 03-05-2013, 11:29 AM Thread Starter
70 351c. Z bar HELP
I'm trying to buy all the parts I need
To do my 4 speed swap to my 70 351c
Mach.
Will a 351w z bar kit work with my 351c?
I don't see any Cleveland z bar kits out there
For sale. And I'll be running headers.
Thanks for any help and info
970fizz is offline
post #2 of 12 (permalink) Old 03-05-2013, 02:10 PM
Mustangs unlimited used to carry the 351c z bar.
Jsams is offline
post #3 of 12 (permalink) Old 03-05-2013, 06:50 PM
dobrostang's Avatar
Great time to go hydraulic - do the $$$ numbers, might not be so bad at this point...
dobrostang is offline
post #4 of 12 (permalink) Old 03-08-2013, 12:13 AM Thread Starter
I would like to keep to the original z bar set
Up.
Some mustang forums say a 351w will
Work and some say they won't.
I'm sure other people on here have had
This problem ?
970fizz is offline
post #5 of 12 (permalink) Old 03-08-2013, 08:42 AM
I think several 289/351 z bars might work depending on your headers.
I bought my z bar from mustangs unlimited several years ago
It is for a 70 with a 351c
Jsams is offline
post #6 of 12 (permalink) Old 03-08-2013, 10:52 AM
turbo2256b's Avatar
Back in 71/72 installed a highly modified 351C in my 69 GT350 no issues using the 351W Z bar that came with the car. Only issue was it took 3 days to figure how to install it using 2 1/8 hooker super comp headers.
turbo2256b is offline
post #7 of 12 (permalink) Old 03-08-2013, 10:59 AM Thread Starter
I know headers may be a problem,
I'm looking at jba headers and maybe a jba z bar, but not sure if they make 351c headers.
still don't know what's the best headers to use?
970fizz is offline
post #8 of 12 (permalink) Old 03-08-2013, 11:13 AM
coupe3w's Avatar
I have a 351 C with Hooker Comp headers for a '70 Mustang in my '67 and I used the 289 z bar with no problems.
coupe3w is offline
post #9 of 12 (permalink) Old 03-08-2013, 12:28 PM
turbo2256b's Avatar
I think all the SBF bars were the same. Think the 250 6 was the same too. 220 6 tube was longer I think. Have all of them aroud here somewere.
post #10 of 12 (permalink) Old 03-08-2013, 02:25 PM
caveeagle's Avatar
I can tell you that in '67 the I6 had a different Z-bar than the 289. I know because I had to swap out the original one during my v8 swap.
I also know that the 289 Hi-Po cars had a different Z-bar, which is not available (AFAIK). I have heard rumors that the Boss302 Z-bar will fit, but I cannot confirm that.
mark
04 SVT Cobra, Torch Red (daily driver)
67 'vert 302,4spd,Red/Red (almost ready!)
67 Coupe 289,auto,black/black,deluxe (sold)
67 Coupe I6 to V8 conversion (sold)
caveeagle is offline
post #11 of 12 (permalink) Old 03-09-2013, 03:38 PM
I installed a 351C in a 69' and the stock 69' bar worked fine.
Roy
royclore is offline
post #12 of 12 (permalink) Old 03-15-2013, 01:52 AM
You could always call Modern Driveline and go with a cable clutch setup.
1968 Mustang Coupe: Total Control/Global West suspension, 600# front coils, 165# race leaf springs (Maier Racing), Koni shocks, 393w AFR heads, TKO-600, 9in rear Moser axles, 3.50:1 TruTrac, Bear Brakes front/rear
1973 Mach-1: 351C 4v, C6, 9in with 3.73:1. (Under Construction)
cazsper is offline
