How to hide engine bay wiring? - Vintage Mustang Forums
post #1 of 11 (permalink) Old 03-29-2013, 10:39 PM Thread Starter
I'm doing a 5.0 roller with efi swap. Getting to the point were I have to start thinking about wiring. I don't want to hide everything, but I want the clean, organized and uncluttered look.
I am for sure relocating the battery to the trunk.
So for those that have been down this road, what are your top tips for hiding engine bay wiring?
Here is my current bay:
merfsiu is offline
post #2 of 11 (permalink) Old 03-29-2013, 10:47 PM
Greg'66 5.0's Avatar
I ran some of my wiring behind the fenders along the underside of the fender aprons. I swapped out the fender bolts for some slightly longer ones and then used some rubber lined clamps to retain the harness. I slipped the clamp over the extra length of the bolt and put a nut on to hold it all in place. The bulk of my EFI harness is not completely hidden, but it will be running along the top of the firewall under the cowl lip.
'66 Emberglo Coupe
Modifications:
5.0 EFI conversion
TwEECer EFI tuning
T56 6-speed
Rod & Custom Motorsports IFS
TCP subframe connectors
Vintage Air Heat & AC
'99 Black Cobra - Daily driver
Greg'66 5.0 is offline
post #3 of 11 (permalink) Old 03-29-2013, 11:14 PM
JamesWnew's Avatar
I have some stuff on my webpage for hidden wiring, and efi wiring. I think the best approach is a custom cut harness that removes all the excess.
JamesWnew is offline
post #4 of 11 (permalink) Old 03-30-2013, 10:39 AM
dobrostang's Avatar
When put the battery and solenoid in the back I unwove the wiring harness on the pass side and ran it up the drivers side with the other harness. Alternator wiring came out from under the radiator. I mounted the MSD unit by the radiator on the driver side so I had wires coming to the motor from that side. Ran the alternator wires to the block from below the MSD with the MSD wires, tucked them under the power steering and water pumps with lots of wiring clamps. Came out very clean. Without a battery, solenoid and wiring it came out pretty clean. The drivers side has reservoirs for clutch fluid, power steering and radiator overflow so cleaning the wires on that side would not unclutter it enough to warrant the trouble in my case.
ONe thing I did that worked out very nicely was put a terminal block above the MSD, took the place of the terminal on the solenoid that the power takeoffs come from. Makes a very convenient point for power for timing lights, charging and power pulls.
dobrostang is offline
post #5 of 11 (permalink) Old 03-31-2013, 03:09 AM
Pics I should be starting this next weekend.
Husky44 is offline
post #6 of 11 (permalink) Old 03-31-2013, 05:24 AM
Pmustang's Avatar
I have an RJM harness which is quite sano but with A/C it got very messy under the hood. Mine is in the shop now getting everything cleaned up
I found the worst areas to be by the solenoid and near the firewall where everything came through
Much of mine was just excess length of wires not trimmed back.
Peter
in UK:
66 FB, Black, 4spd
64.5 Cvt, Burgundy
68 Camaro SS/RS clone 4spd
68 Cpe White,
65 Cpe Yellow 4spd,
67 Orange FB
68 Green FB
68 Blue Fastback
66 Red FB Shelby Replica
67 Beige Vert
73 Vert
Shipping to UK :
65 Blue FB project
67 Red Vert
66 White Vert
66 White coupe
67 Black coupe T5
65 Shelby Hertz clone coupe
65 Blue coupe
65 Blue FB mint
Pmustang is offline
post #7 of 11 (permalink) Old 03-31-2013, 12:54 PM
1965wildstang's Avatar
I wanted a clean engine bay also with nothing on the inner fenders. I also relocated the battery to the trunk and mounted the ecu, fan controller, a/f ratio monitor inside the car under the cowl area as jamesw did. All the wiring for the headlights, fog lights, horn, electric fan, blinkers i ran inside the upper section of the dirverside fender and then down into the lower valance branching off to each item. All the wiring for the motor & sensors I pulled through on the passenger side right below the firewall at the toe area. I used a grommet form an sn95 car that allowed all the wiring to come through in one area and branched off beside the trans with the wiring. We used the mesh style wire covering and pretty much was able to hide all the wiring at the back of the motor and along the cam covers & intake area. I moved all the vacuum hoses and solenoids to the back of the supercharger. I did have to add some length to some of the vacuum hoses to allow everything to work. Good luck.
65 coupe,JME bezel w/Autometer gauges,03 cobra motor & T56 trans, 17" TT2'S,9in w/4:10 trac-loc. 445hp & 425 ftlbs tq http://www.youtube.com/watch?v=sya6h...layer_embedded
By wildstang at 2012-02-21
1965wildstang is offline
post #8 of 11 (permalink) Old 03-31-2013, 01:13 PM
2manyhobbies's Avatar
Send a message via Skype™ to 2manyhobbies
I ran the main loom under the driver side fender as well. Relocated the solenoid upside down behind the shock tower since battery is in the trunk, and rerouted the firewall wiring where it was lower and put black loom over it. Dont use colored loom, it stands out and says "look at me". The msd box is under the dash, and the coil will be too later this summer. I have one small loom running down the intake with the dizzy and gauge wiring in it that doesnt stand out much at all. Also going to do a one wire alternator and lose the regulator and associated wiring.
"LAZARUS"
Goodguys Younguys award winner TX-2000
MCA Grand National Pinnacle Award: Best Modified Driven, Sept 2012
Modified Mustang & Ford article: ?/2014
2 years of hard labor later
2manyhobbies is offline
post #9 of 11 (permalink) Old 03-31-2013, 01:47 PM
dobrostang's Avatar
Here is the photo. Man, the dust from this winter really shows up in these photos. I am thinking I may do the driver's side next winter, we will see...
post #10 of 11 (permalink) Old 03-31-2013, 09:43 PM
I just relocated most of the wiring since I still wanted to be able to get to it. I ran the main portion from the firewall forward down along the framerail and covered it with fireproof wrap to keep it from getting cooked and on the battery side i just moved everything down. The battery is in the trunk and where the battery was is now a small custom stainless steel tray that I use as a tool tray. Under that is a custom aluminum cover that hides all the wiring,relays and solenoid. I also installed the engine hourmeter there. The MSD 6AL box is up high above where the battery was and the wiring for it goes into the fenderwell then back out to a mount for the coil that sits next to the shock tower. The coil wire runs along the monte carlo bar to the dizzy.
http://i863.photobucket.com/albums/ab200/aslaned/unnamed_1.jpgChuck Wiltens
MCA Gold card - Modified - Judge
Assistant National Head Judge-3rd Generation
MCA#50308
trkpny2 is offline
post #11 of 11 (permalink) Old 03-31-2013, 11:02 PM
FIVOH's Avatar
I ran mine directly into the fender wells and I used heater hose to protect my wires. Kind of like what Gregg said. I didn't want the wires on the inside of the shock towers, and anything else I ran I just tucked away as much as possible. Of course, i started from scratch on the wiring, starting at the factory firewall plugs. I would run a section and hide it as I went. Only tough part is needing to go back into the harness later, tends to be a bit more difficult, but it was worth the trouble.
Next time I will really take the time to eliminate everything, and put EVERYTHING in the trunk.
1966 Emberglo Coupe - Project Buckshot
FIVOH is offline
