double v-belt pulley on 130amp alternator - Vintage Mustang Forums
post #1 of 10 (permalink) Old 08-15-2015, 03:51 PM Thread Starter
Hi Everyone,
I am trying to run a double v-belt pulley on a 130amp alternator. I have power steering and a 3 groove crank pulley. Does anyone have pics of running a similar setup? It looks like the only way to do that is by having a very long belt connecting the power steering pulley and 2nd groove of the alternator v-belt pulley.
On another note, is there a way to tell if my drive shaft has the rubber dampner inside it and is able to be shortened?
Thanks for the help!
Stang Guy is offline
post #2 of 10 (permalink) Old 08-15-2015, 04:02 PM Thread Starter
Here are pictures of the setup.
post #3 of 10 (permalink) Old 08-15-2015, 05:21 PM
c6fastback's Avatar
Send a message via AIM to c6fastback
Usually you would run a single or double belt on the alternator/water pump /crank and another belt on crank/power steering or crank/water pump/power steering .
68 302-4V w/1.84",1.54" ported , Comp XE268H , 2200 rpm Hughes converter, 3.25 9" w/10x2.5" shoes , MSD box/distrib , RPM intake , 670 Holley , cross flow aluminum radiator , Granada discs......
Michael S.
c6fastback is offline
post #4 of 10 (permalink) Old 08-16-2015, 01:26 AM
Just some guy
GypsyR's Avatar
I've fought with that in the past with little luck, depending on the vehicle. On my '67 I've found it practical to only run a single sheave with my current setup. Not being a driver, I haven't had it for real world testing. Depending on setup, some people have had belt squeal. If I get that then the first thing I will do is try a "289 HiPo" alternator pulley. The larger diameter slows the rotation a bit but happily 3G's deal with low RPM operation without really high demand quite well. The point of swapping to a HiPo pulley is to give the belt more surface area to contact. More area=less slip=less squeal. The goal being no squeal. Without actually doing the math, I'd guess the contact area of HiPo pulley to be quite a bit more than the stock diameter but maybe not as much as a double sheave.
GypsyR is offline
post #5 of 10 (permalink) Old 08-16-2015, 04:54 AM
Markus's Avatar
Since i have my 3G alternator i have a squeling and belt eating problem with ac and electric fan on.
With a double pulley on the alternator and longer ps belt the problem is gone.
With out ac, electric fan and other high current parts you can try a bigger diameter for the alternator pulley. Like GypsyR said.
Markus
67 Mustang Fastback restomod
- 331 stroker
- MSD Atomic EFI
- AFR 185, comp pro magnum RR
- Ed Curtis custom cam
- Hooker comp. LT
- TREMEC TKO
- 3.55 : 1
- Innovate wideband
- complete specs at http://www.mustang1967.de/overview.html
68 Mustang Coupe daily driver
- 5.0 roller
- Edelbrock e-street heads with Ed Curtis custom cam/valve train
- performer rpm intake
- hedman headers
- ac
- pb
- borgeson steering
- complete specs at http://www.mustang1967.de/overviewcoupe.html
Markus is offline
post #6 of 10 (permalink) Old 08-17-2015, 02:36 AM Thread Starter
Thank you everyone for the pictures and help! This definitely helps.
Guy
post #7 of 10 (permalink) Old 08-17-2015, 03:54 AM
You can run a double pulley on the alt but i don't know why. I have always run a single groove pulley with a stock alt and have ac with never a problem with belt squeal. Wii soon be switching to a 135 a 3g and will still keep the single groove pulley. Though on my preset vehicle I run a hipo alt pulley to slow down the alt rpms because of the larger crank pulley.
ron
FordsForever is offline
post #8 of 10 (permalink) Old 05-18-2017, 02:24 PM
Rorin67's Avatar
Similar to Markus, I have a long belt that runs around the crank, power steering, over the water pump, and around the 3G alt pulley. Then a shorter belt just going around the crank, water pump, and the second groove of the 3G alt pulley. It can be difficult to get the tension on both belts exactly the same to avoid belt squeal, but it can certainly be done. I run this setup on the '67 daily driver and it's totally fine with no squeal.
Formula for a daily driver street fighter in Los Angeles:
'67 Fastback + Built 351W + T5 + 3.55:1 + LTs + 2.5" + 40s + TT2 17s
+ Shelby drop + CSRP + R&P + Bilsteins + SFCs + under riders + 22 Gal.
+ 3pts + 2nd Skin + MTF grille/lights + LEDs + SiriusXM
MTF Grille/Light Kit Install w/ Pics... & Engine Bay Pics...
As featured in Hot Rod Magazine tech article, May 2014
Rorin67 is offline
post #9 of 10 (permalink) Old 05-18-2017, 04:46 PM
I get my sandwichs from World Deli.
1ofAMillion+ is online now
post #10 of 10 (permalink) Old 05-20-2017, 02:58 AM
Just some guy
GypsyR's Avatar
They wouldn't be Spam sandwiches, would they? (post deleted)
GypsyR is offline
