Headers for High Port Heads - Vintage Mustang Forums
post #1 of 3 (permalink) Old 09-06-2016, 01:42 PM Thread Starter
Tnunisaw's Avatar
I have a 65 mustang that I have installed the custom IFS front and rear suspension with Power Rack. My engine is a CHP 347 block with Trick Flow High Port Heads. My current Super Comp Tuned Headers that I have been running with these heads have a fitment issue with the new IFS. The number 8 tube is in the direct path of the steering linkage. Is there another header setup that will work with this. Thanks
My Herd
1965 Coupe
1965 Convertible
1965 Fastback
1967 Coupe
1967 S code Convertible 390 4 speed
1967 Fastback GTA
1969 Mach 1 428 cj R code 4 speed
1969 Sportsroof H code
1970 Mach1 351 4v
1973 Mach 1 Q code 351 4v auto
2012 GT 5.0
Tnunisaw is offline
post #2 of 3 (permalink) Old 09-07-2016, 10:19 AM
I need the same info
forrrrrrd is online now
post #3 of 3 (permalink) Old 09-07-2016, 05:27 PM
Supporting Vendor
TCI Engineering's Avatar
The original set of headers(which we still offer) were designed on our shop Mustang which had AFR heads. They use Fel Pro 375-1487 exhaust gaskets. I am pretty darn sure the Trick Flows use the same gasket. Can you confirm if they do?
-Jason
TCI Engineering is offline
