TCI Engineering's '67 Fastback project - Page 8 - Vintage Mustang Forums
 1Likes
post #106 of 120 (permalink) Old 06-03-2014, 11:33 AM
Are these needed on a street car/ street racer? Has the front end been weakened enough to warrant these on a driver car?
stick1 is offline
post #107 of 120 (permalink) Old 10-06-2014, 04:33 PM Thread Starter
Supporting Vendor
TCI Engineering's Avatar
Breaking News: The TCI Engineering '67 Mustang has been chosen to represent 1 of 50 Mustangs in the Ford booth at SEMA 2014 as part of their "Celebration of Mustangs".
-J
TCI Engineering is offline
post #108 of 120 (permalink) Old 10-06-2014, 06:14 PM
Well deserved!! That's a fine ride!!
1966 Pro-Touring Fastback build in Progress
2001 F250 Platinum Edition - 1 of 2482
2012 Competition Orange/Black Boss #806
manOwar is offline
post #109 of 120 (permalink) Old 05-28-2015, 12:18 PM Thread Starter
Supporting Vendor
Making a few changes to the car recently.
We'll probably wait until later in the year for this upgrade. From memory I think Ed said this was 70 lbs lighter than the iron block in the car now.
Here's a couple pics from the Speed Ventures event at Fontana a few weeks back.
-J
post #110 of 120 (permalink) Old 02-16-2016, 02:59 PM Thread Starter
Supporting Vendor
It's been a long time since an update. The engine lost oil pressure on turn one at the Auto Club Speedway so the car has been sitting while the attention was directed towards our 2nd Gen Camaro product development. The new engine is being built using the aluminum block above. We're also moving up from the 210 AFR heads to 225's, bumping the compression to 12:0 and adding a much more aggressive cam. This new engine should make 600 at the tires with ease. This engine should be 80 or so lbs lighter also.
We're also changing to dry sump to make sure this doesn't happen again. It may look the same but Ed built a new cage made of Chromoly instead of DOM. This new cage is 80 lbs lighter than the old one.
-J
post #111 of 120 (permalink) Old 02-16-2016, 05:28 PM
j persons's Avatar
What size are your lines to and from the oil tank? I had a friend that used a 3 stage pump on a very similar engine, and had oil pressure problems when running at Willow Springs. He fixed it by running a AN-16 supply and a AN-20 return. With the smaller lines the tank would almost run dry.
Dynacorn 67 fastback. Dart 363, Close ratio Magnum 6 speed, 3.70 Eaton Truetrac in a fabricated full floater 9", SorT coil over suspension. Still in pieces.
j persons is offline
post #112 of 120 (permalink) Old 02-18-2016, 07:18 PM Thread Starter
Supporting Vendor
We're running -12 lines based on Lingenfelter's recommendation.
post #113 of 120 (permalink) Old 03-29-2016, 12:21 PM Thread Starter
Supporting Vendor
We finally got our new bullet assembled and dyno'd.
-J
post #114 of 120 (permalink) Old 03-29-2016, 12:47 PM
Serious power!
Huntingky is offline
post #115 of 120 (permalink) Old 04-14-2016, 01:13 PM Thread Starter
Supporting Vendor
Once again, Ed is going to a wider tire because there's no way he's going to allow a Camaro have more tread width than him.
post #116 of 120 (permalink) Old 05-27-2016, 05:11 PM Thread Starter
Supporting Vendor
We had a blast at the V8 Builds event at Streets of Willow. The car is performing extremely well with the new engine and tires.
-J
Huntingky likes this.
post #117 of 120 (permalink) Old 06-22-2016, 11:29 AM Thread Starter
Supporting Vendor
Another great day of racing with the NMCA last weekend.
-J
post #118 of 120 (permalink) Old 09-02-2016, 01:30 PM Thread Starter
Supporting Vendor
A few weeks back we took the car to the Auto Club Speedway to compare the Mustang to our Camaro #projectreddawn
This rivalry is going to be a heck of a lot of fun to watch play out.
-J
post #119 of 120 (permalink) Old 09-29-2016, 01:16 PM Thread Starter
Supporting Vendor
A couple more track days for Ed and the Mustang.
NMCA Autocross at the Auto Club Dragway in Fontana.
We also ran the Extreme Speed event with Redline Time Attack also at the Auto Club Speedway but in the infield track. This will be the same track configuration as Optima in a couple weeks.
-J
post #120 of 120 (permalink) Old 10-13-2016, 06:09 PM Thread Starter
Supporting Vendor
