Question about rear suspension - Vintage Mustang Forums
post #1 of 5 (permalink) Old 09-12-2013, 04:11 PM Thread Starter
Phydeauxman's Avatar
I had one of the TCI Torque Arm rear suspension kits installed on my 68 Coupe along with a new 9 inch rear end. The install was done by one of their dealers and came out pretty nice. The concern I have is that I noticed the installer left the old suspension travel bumpers attached to the frame rails. Since the installer did a mini-tub on my car and narrowed the rear-end, these bumpers are directly over the brake lines. Are these still needed? Can I remove them? If they are still needed...I guess I am going to have to trailer the car back down to the installer and have him fix them...somehow.
- 65 2+2 Fastback 289 4V 4-Speed (Mostly stock, under restoration)
- 68 Coupe, (32000 original miles), 2V C4. Resto-modding, TCI suspension, 5.0 EFI conversion w/5 speed
Phydeauxman is offline
post #2 of 5 (permalink) Old 09-16-2013, 04:38 PM
Supporting Vendor
TCI Engineering's Avatar
You can cut the snubbers off. The shocks have internal stops that will hit before the axle bottoms on the frame rail.
-J
TCI Engineering is online now
post #3 of 5 (permalink) Old 01-02-2015, 03:42 PM
Does the torque arm kit use these snubbers for the initial install ( according to the instruction packet) as a reference point? I think it says to put the channel over the frame rail then push it up against the snubber mounts. Just wondering , I was going to go ahead and remove mine now before I started the install but I think I should wait if this is a reference point.
stick1 is offline
post #4 of 5 (permalink) Old 01-05-2015, 01:09 PM
Supporting Vendor
Yes, the snubber plates are used to locate our frame rail brackets.
-J
post #5 of 5 (permalink) Old 01-12-2015, 02:31 PM
thank you for the info
stick1 is offline
