Viking Coilovers - Page 2 - Vintage Mustang Forums
 1Likes
post #16 of 24 (permalink) Old 12-13-2016, 12:29 PM
Originally Posted by app01 View Post
I can't comment on the coil overs yet since they are still in the box, however, the viking shocks currently in the car have the same valving and I was very happy with them. Super easy to adjust with definite clicks for each setting so easy to count, and lots of adjust ability.
Is it possible that the same shocks can work for drag and road course?
Jsams is offline
post #17 of 24 (permalink) Old 12-13-2016, 02:01 PM
Just a quick heads up... I just ordered a pair of front coil overs from CCP( 11/28/16) I spoke with an employee who noted that if you buy the single adjustment shocks...they will ship you the dual adjustment. No additional cost. I guess they are no longer carrying single adjustment. I paid for single adjustment and received the dual adjustment as promised. Might save you a few bucks...if they are still doing it.
66fstback is offline
post #18 of 24 (permalink) Old 12-13-2016, 03:29 PM Thread Starter
the single they offer is a QA1 shock and its about the same price give or take 30dlls , Viking only offers a double adjustable shock so they can stay competitive and cheaper. My guess is viking is outselling the QA1 so they removed the single since its just not any cheaper then the double. Good to know with shipping mine were 60dlls more, its a nice chuck of change if its true.
snakekiller is offline
post #19 of 24 (permalink) Old 12-13-2016, 04:23 PM
rpm
rpm's Avatar
If you get double adjustable.
Bob
There are 2 types of people, those who own pickups and those who borrow them.
69 M code Mach 1, 393w AFR 185, C5 trans, 3.50 traction lok N case, 13" 01Cobra 4 wheel disc, QA1 4 wheel coil covers, Chromo tube susp arms, Triangulated rear arms, Convertible inner rockers & seat riser, 6 point roll bar.
Build Pics http://s782.photobucket.com/user/rob...?sort=3&page=2
Build Thread
http://1969stang.com/forum/index.php...bitch-is-back/
rpm is offline
post #20 of 24 (permalink) Old 12-13-2016, 07:42 PM
app01's Avatar
Yes if that are DA ad mentioned. With the viking Crusader ones, you can adjust the rebound and compression independently. 19 compression settings and rebound 22 settings.
Also the valving can be changed for even more tuning.
But remember this is only one part of the chassis setup and everything needs to wok together.
www.PalmieriConcepts.com custom showboards
10.47 @133(still practicing)
70 Mach 1 w/Boss 460 Stroker Engine-Build http://forums.vintage-mustang.com/bu...ld-thread.html
70 Boss 302-May 70, Dearborn-Build http://www.palmiericoncepts.com/My-M...970Boss302.htm
62 Corvette-Build http://www.palmiericoncepts.com/My-M...roon/index.htm
MCA, MCCNE Member
app01 is offline
post #21 of 24 (permalink) Old 02-21-2017, 09:56 AM
I have been running the Viking Crusader DA shocks on all 4 corner since the spring, and just a week picked up a set of front coil overs. Very very well made. I will be installing them later this month and will be updating my build thread then. These are going in mt 70 drag car. The adjustment access on both shocks and coil overs is very easy.
I have Opentracker Racing Roller, UCA and LCA's along with Spring perches. The spring perches come out and the bottom of the coil over assembly bolts right to the UCA. The top of the spring sits in the shock tower pocket like stock springs. Both ends of the assembly are roller bearings.
As a side note, I will be selling my current front Viking Crusader shocks that have less than 300 miles and 50 1/4 mile passes.
Originally Posted by snakekiller View Post
Sweet i have order them from cpp, cant wait to install them. I will write a review as well.
either of you two have any updates on your coilover install?
bdub4u is offline
post #22 of 24 (permalink) Old 02-21-2017, 01:43 PM
app01's Avatar
Yes.. All went very well......Please see my build thread for details.
See here: 1970 Mach 1 with 460 SBF Boss Build Thread
MCA, MCCNE Member
app01 is offline
post #23 of 24 (permalink) Old 02-21-2017, 08:59 PM
Je942010's Avatar
Just installed these on mine a few weeks ago. Everything went smooth as noted by others. Haven't driven on them yet so I can't comment on that. There's a few pics on my build thread. Look up 67 mustang restomod build
Sent from my SM-N910V using Tapatalk
67 Coupe Dark Moss I6 to V8 swap in progress
Je942010 is offline
post #24 of 24 (permalink) Old 02-25-2017, 12:48 AM Thread Starter
Yes i installed them alredy. Its probably the easiest suspensions component i ever installed, the only hard part was getting the snaprings to seat in the bushings.
