Viking Coilovers - Vintage Mustang Forums
 1Likes
post #1 of 24 (permalink) Old 11-23-2016, 04:18 AM Thread Starter
Viking Coilovers
Anyone running viking coilovers? Whats your experiance with them? Im looking for mostly height adjustment and if their as good or better than bilstein sport its a plus.
Ive read up on them and most a positive reviews. Made in the usa and by a ex QA1 engineer.
snakekiller is offline
post #2 of 24 (permalink) Old 11-23-2016, 08:37 AM
Ponyboy's Avatar
You should buy the Street or Track setup, just my onion.
66 coupe, '93 Fox seats, Three point belts, 289, Weiand, Hipo manifolds, duel exhaust, T5 trans, Pro 5.0 shifter, 3.40 open, KH front disc, Porterfield R4-S pads, 1" front sway bar, Shelby drop, Spring perch relocation, Shelby quick steer, GT progressive coils (1/2 coil cut), 4.5 leaf mid-eye, Bilstein Street Shocks, Export brace, Monti-Carlo bar, Sub-frame connectors, Performance alignment (+3.5 caster/-.5 camber), 16x7 wheels, 215/55/16 & 225/55/16 BFG G-force
Ponyboy is offline
post #3 of 24 (permalink) Old 11-23-2016, 09:31 AM
billywatson1205's Avatar
I've got them from cpp. Can't comment on ride yet but they are a very nice setup. They do exactly what I was looking for in my application.
Living the dream or running it down... haven't figured out which yet.
My website and blog
67 fastback on jackstands... slowly getting a new lease on life.
billywatson1205 is online now
post #4 of 24 (permalink) Old 11-23-2016, 02:42 PM Thread Starter
street or track great product i have their whats link, i will like to but don't have the budget.
one thing i did when planning out my build is ask myself what the purpose of the car would be,
what did i came up with? sporty street driving mostly. I will most likely not use the suspension to its full potential,
so i can't justify the coin for a street car with the occasional autocross event.
rpm likes this.
post #5 of 24 (permalink) Old 11-23-2016, 02:49 PM Thread Starter
nice, I'm looking at the double adjustable version on CPP. What rear shock do you have, I'm not sure if i should keep the bilstein sports. I know QA1 is a quality shock and thats one of the reasons why it lead me to Viking, from what i read their identical but with a different spring design.
whats the fitment like?
post #6 of 24 (permalink) Old 11-23-2016, 03:12 PM
Fitment was great. Went together very easily. Rears I just have Monroe right now. Haven't decided the direction back there yet.
My website and blog
post #7 of 24 (permalink) Old 11-23-2016, 03:25 PM
rpm
rpm's Avatar
I read somewhere that Viking was started by a couple of disgruntled QA1 employees. If so, the quality should be top shelf. I bought QA1's four years ago, and have about ten miles on them.
Bob
There are 2 types of people, those who own pickups and those who borrow them.
69 M code Mach 1, 393w AFR 185, C5 trans, 3.50 traction lok N case, 13" 01Cobra 4 wheel disc, QA1 4 wheel coil covers, Chromo tube susp arms, Triangulated rear arms, Convertible inner rockers & seat riser, 6 point roll bar.
Build Pics http://s782.photobucket.com/user/rob...?sort=3&page=2
Build Thread
http://1969stang.com/forum/index.php...bitch-is-back/
rpm is offline
post #8 of 24 (permalink) Old 11-23-2016, 07:24 PM Thread Starter
yes i believe so, it explains why they look exactly like QA1 shocks. The viking site is interesting, they only focus on double adjustable shocks, but believe they now offer single as well.
post #9 of 24 (permalink) Old 11-23-2016, 07:27 PM Thread Starter
I've never installed coil-overs before did you need spring compressors? i have bilstein sport valve shock in all 4 corners at the moment, I'm thinking of keeping the rears if i upgrade.
post #10 of 24 (permalink) Old 11-23-2016, 08:29 PM
GT289's Avatar
That's pretty close..... ex-QA1 guys that didn't like certain business practices is the "PC" version
of how it happened. Basically the engineer in question took his "ball" (his patent designs) and left.....
ex-Global West GM
1991-1995
- Douglas Adams
GT289 is offline
post #11 of 24 (permalink) Old 12-06-2016, 11:15 AM
app01's Avatar
I have been running the Viking Crusader DA shocks on all 4 corner since the spring, and just a week picked up a set of front coil overs. Very very well made. I will be installing them later this month and will be updating my build thread then. These are going in mt 70 drag car. The adjustment access on both shocks and coil overs is very easy.
I have Opentracker Racing Roller, UCA and LCA's along with Spring perches. The spring perches come out and the bottom of the coil over assembly bolts right to the UCA. The top of the spring sits in the shock tower pocket like stock springs. Both ends of the assembly are roller bearings.
As a side note, I will be selling my current front Viking Crusader shocks that have less than 300 miles and 50 1/4 mile passes.
www.PalmieriConcepts.com custom showboards
10.17 @134(still practicing)
70 Mach 1 w/Boss 460 Stroker Engine-Build http://forums.vintage-mustang.com/bu...ld-thread.html
70 Boss 302-May 70, Dearborn-Build http://www.palmiericoncepts.com/My-M...970Boss302.htm
62 Corvette-Build http://www.palmiericoncepts.com/My-M...roon/index.htm
MCA, MCCNE Member
app01 is offline
post #12 of 24 (permalink) Old 12-07-2016, 03:33 AM Thread Starter
Sweet i have order them from cpp, cant wait to install them. I will write a review as well.
post #13 of 24 (permalink) Old 12-12-2016, 08:31 PM
I wonder how the double adjustable version would do with my Global West setup?
Hard to tell with out spending the bucks....
Jsams is offline
post #14 of 24 (permalink) Old 12-13-2016, 01:28 AM Thread Starter
I can actually answer those questions when i write a review. I have GW upper and lower control arms with rosehill perf adjustive Strut-rods, the uppers have -3 degrees of camber built in so it should be a decent Performer.
post #15 of 24 (permalink) Old 12-13-2016, 06:39 AM
app01's Avatar
I can't comment on the coil overs yet since they are still in the box, however, the viking shocks currently in the car have the same valving and I was very happy with them. Super easy to adjust with definite clicks for each setting so easy to count, and lots of adjust ability.
MCA, MCCNE Member
app01 is offline
