Sparco Seats - Vintage Mustang Forums
 1Likes
  • 1 Post By roboticservo
post #1 of 9 (permalink) Old 02-20-2017, 04:37 PM Thread Starter
romayo's Avatar
Sparco Seats
Little by little the stang is coming along for track purpose, but I have Sparco seats which are quite tall for this car - theres about 2 inch or so gap from the top the seat to the top of the roof
so from what I've been able to gather is that I have to remove the raised seat pan?
If so, is it just a simple remove or does something else needs to be fabricated as a replacement?
How much structural rigidity am I losing?
I've made several attempts to find other threads discussing/showing how to remove them and so on.
Any help?
'68 HardTop
302, Flat Pistons, 170 Trick Flow (P&P)
Trick Flow Lifters, Scorpion Roller Rockers
Hooker,T5, Al Flywheel, Al Drive Shaft, 9 rear
romayo is offline
post #2 of 9 (permalink) Old 02-20-2017, 07:55 PM
roboticservo is offline
post #3 of 9 (permalink) Old 02-20-2017, 08:36 PM
Boom's Avatar
A 69 seat pan drops right in and is a bit over an inch shorter. No magic involved.
-Brett
1968 Mustang coupe 5.0/T5
FiTech EFI
Build Thread
Current Project: 1968 fastback 351w
Boom is offline
post #4 of 9 (permalink) Old 02-20-2017, 09:19 PM
Couple of options, first do the 'vert seat pan for the added lateral structural support. This would also require vert inner rockers though which are also an excellent addition for longitudinal support. For the pan itself, Shaun (SorT) has a really good tech article on lowering the seat pan on his website. Option two, if you are doing a cage...which you should be if it is a track car...would be to eliminate the seat pans altogether and build a tubular structure tying both sides of the car together at the seat pan locations. Then add in adjustable seat plates front to back between the tubes at the seat locations. This way you can set the height at your discretion. If you check out the CA site, you can find some pics of this option.
patrickstapler is offline
post #5 of 9 (permalink) Old 02-20-2017, 09:34 PM
It is not required to install the convertible rockers to get the one piece seat pan. They make the one piece seat pans for coupes and fastbacks without the need to install conv. inner rockers:
Dynacorn 3647YCWT Mustang Seat Platform One-Piece WT Prim Coupe/FB 65-68
rpm likes this.
post #6 of 9 (permalink) Old 02-20-2017, 09:38 PM
rpm
rpm's Avatar
The 69 vert pan is 1" higher than the sportsroof due to the hump over the tunnel. I and others have cut and spliced the hump from the one piece conv seat riser to the stock 69 sportsroof seat risers. It's a snug fit at the inner seat belt bolt, but doable.
Bob
There are 2 types of people, those who own pickups and those who borrow them.
69 M code Mach 1, 393w AFR 185, C5 trans, 3.50 traction lok N case, 13" 01Cobra 4 wheel disc, QA1 4 wheel coil covers, Chromo tube susp arms, Triangulated rear arms, Convertible inner rockers & seat riser, 6 point roll bar.
Build Pics http://s782.photobucket.com/user/rob...?sort=3&page=2
Build Thread
http://1969stang.com/forum/index.php...bitch-is-back/
rpm is offline
post #7 of 9 (permalink) Old 02-20-2017, 09:45 PM
Cool. Didn't know they made that. Would still do the inner rockers however...for reasons listed. Even with a cage.
post #8 of 9 (permalink) Old 02-21-2017, 02:40 PM
Agree 100%
post #9 of 9 (permalink) Old 02-22-2017, 07:01 PM Thread Starter
romayo's Avatar
Thank you for all the replies - just what I was hoping to find
'68 HardTop
romayo is offline
