Auto-X Road Race Steering??? - Page 2 - Vintage Mustang Forums
post #16 of 33 (permalink) Old 11-15-2007, 07:56 AM
autoxsteve's Avatar
I'm running a power steering box, manual center link, Shelby quick steering arm, roller idler, StreetorTrack.com's heim joint strut rods, ORP's upper A-arms (road race model), OPR's roller spring perches, KYB gas shocks.
Just had alignment set to this:
Driver's side: -2.5 deg camber, +2.5 deg caster
Pass side: -2 deg camber, +2.5 deg caster
1/8" toe IN
This is working almost perfect on the big track at Willow Springs. I need another 1/2 deg of neg camber on the driver's side (turn 2 really works that left front tire).
On the shopping list:
ORP's lower control arms
Install the ORP 700#/inch springs in front
Koni shocks
Links-R-Us...
Steve Leslie, 65 cpe, 302, toploader, A/C, orig disc brakes, bench seat, tri-bars, tri-Ys, I need tri-power! 356,000 miles (4/12/2010)
1965 Ford Mustang - All Weather Fighter
autoxsteve is offline
post #17 of 33 (permalink) Old 11-15-2007, 12:40 PM
bob
bob's Avatar
Originally Posted by Deviousfred
I'm curious as to what set-ups you Road Racing/Auto-X guys use and how you like it?
Whatever Shelby set it up with.
-bob
bob is offline
post #18 of 33 (permalink) Old 11-15-2007, 01:14 PM
galenic's Avatar
i'm just curious,i bought roller idlerarm from OP, can i put a quich steering arm with that and where can i found it?
i'm running actually with steering box manual long one, shelby drop -1deg,grabatrack coil 620, konis at 4 corner,rollerspringperche,stock uca and lca but just receive autocross one from OP.
the car handle very good but steering is not very responsive, i plan to put the 16:1 ratio and quicker steering arm.
http://community.webshots.com/album/555181396KxBmXC
galenic is offline
post #19 of 33 (permalink) Old 11-15-2007, 03:31 PM
Well the saying goes...
How much do you want to spend?
In the big picture will it make a difference?
Comic is offline
post #20 of 33 (permalink) Old 11-15-2007, 04:01 PM Thread Starter
Deviousfred's Avatar
I see a lot of you all are running PS boxes. I'm assuming they have a better ratio?
Deviousfred is offline
post #21 of 33 (permalink) Old 11-15-2007, 04:07 PM
2bav8's Avatar
Manual box is 19:1 while the power box is 16:1
1966 Coupe build for SCCA Autocross
347 V8 - Tremec TKO - ORP Suspension
www.geocities.com/2bav8
2bav8 is offline
post #22 of 33 (permalink) Old 11-15-2007, 04:29 PM Thread Starter
so is an HCC-AX and its manual
post #23 of 33 (permalink) Old 11-15-2007, 04:49 PM
"Manual box is 19:1 while the power box is 16:1"
Not exactly true!
There are some that can be PS or non-PS with the 16:1 ratio.
Mine SMB-K box is for either PS or non-PS and it is a 16:1.
Solo2 is offline
post #24 of 33 (permalink) Old 11-15-2007, 04:53 PM Thread Starter
Someone brought up a question earlier that I just thought of.
Can a rollerbearing idler arm be used with a quick-steer pitman arm? and does any sell the quick-steer pitman alone?
post #25 of 33 (permalink) Old 11-15-2007, 05:04 PM
BornInAFord's Avatar
IIRC, the idler arm and the pitman arm have to be the same length to maintain correct geometry. With a quick steer pitman arm (longer, a la the 65 Shelby), you need the matched length (longer) idler. You can, however, make this a roller, too. Maybe Opentracker would know for sure?
Daniel
Currently enjoying my grandfather-in-law's 1966 A-code coupe. I am the second owner.
BornInAFord is offline
post #26 of 33 (permalink) Old 11-15-2007, 05:39 PM Thread Starter
I wonder if I could ship them he quicksteer idler and they could perform the service and ship it back.
post #27 of 33 (permalink) Old 11-15-2007, 08:53 PM
silverblueBP's Avatar
I have all new steering parts; added the quick steer kit with the Flaming River 16:1 manual box. The steering was very crisp, but just a tad too hard at slow speeds. I changed the idler arm to roller bearing and it made a noticeable difference at slow speeds.
I didn't change the idler arm, just modified it with the bearings.
-Mark-
1966 Mustang 2+2
"Money can't buy happiness, but it can buy a race car. And I've never been sad in a race car!"
silverblueBP is offline
post #28 of 33 (permalink) Old 11-15-2007, 10:36 PM
autoxsteve's Avatar
I believe the Shelby quick steering arm can be purchased at Mustangs Plus.
The quick steering arm is on the steering box. The idler arm does not change (that's where the roller bearing goes).
Also, a point of order, having the proper adjustment of your steering box (cleaning out the grease, adding fresh grease and adjusting the steering box properly) is paramount to proper steering from a recirculating ball steering setup.
Only reason I see for me to replace the steering box is to remove the death spear shaft on my steering box with a collapsable style....
Links-R-Us...
post #29 of 33 (permalink) Old 11-16-2007, 04:30 AM
Maybe I'm not understanding you correctly, but both the pitman arm and idler arm are different (=longer). Many vendors sell them.
I use them in combination with a properly rebuilt/adjusted and lubricated (which makes all the difference) 16:1 box and a roller bearing in the idler arm.
The steering precision, effort and ratio are all very decent now. I wouldn't say it feels like a modern car or anything, but it's a lot better than before the rebuild and modifications.
Helmantel is offline
post #30 of 33 (permalink) Old 11-19-2007, 12:34 PM
Yeah, I think the manual box is 19:1 or 20:1
UGAstang is offline
