» Network Links
»Super Springs
Go Back   Vintage Mustang Forums > General Discussion > The Track
Old 04-14-2009, 08:00 PM   #1 (permalink)
Default Oil Pan for Road Course
Hi all I'm putting a fresh 302 into my '68 open track car and was wondering what would be a good oil pan for it.
It's primarily used at the local road courses such as Thunderhill and Sears Point. I'd like something with a low profile sump and baffling but that can fit over a windage tray...Thanks
68Restoman
68restoman is offline   Reply With Quote
Old 04-14-2009, 09:14 PM   #2 (permalink)
Maxum96's Avatar
Default Re: Oil Pan for Road Course
I have a Canton road race pan like this on my car.
1970 Fastback (to be finished outside as a Boss 302 clone)
393 Windsor AFR 205 heads with 11:1 compression
Tremec TKO 5 Speed
Link to my Hub Garage and blog about my car http://www.hubgarage.com/mygarage/maxum96
My car as of December 2009
Maxum96 is offline   Reply With Quote
Old 04-14-2009, 09:43 PM   #3 (permalink)
Tims65's Avatar
I have a high capacity, low profile Canton pan like the one pictured above with a windage tray and baffles for road racing. It fits great and clears my TCP Rack and Pinion. I bought mine through Street or Track - http://www.streetortrack.com/15-630-...-pr-21391.html
Tim
'65 2+2
347 - RetroTek EFI - 471 fwhp
JBA shorty's, 2.5" tubes, Dr Gas X-pipe
T-5 world class 5 speed, w/ .80 OD
9" with 3.70's & T-loc
4 wheel disc brakes
17" CL-205's, 225/45 & 245/45 Azenis RT-615's
TCP/Global West suspension
OpenTracker roller spring perches
subframe connectors, Traction Masters, Panhard bar
TCP manual rack & pinion
Power door/window locks w/ keyless entry
Tims65 is offline   Reply With Quote
Old 04-14-2009, 09:46 PM   #4 (permalink)
silverblueBP's Avatar
Ok, I have the same pan too. I've not experienced any low pressure readings from the oil sloshing away from the pickup. The road race pan works great
-Mark-
66 A code 2+2
CarDomain site
Only 1/4 mile run was 13.51 @ 105.7mph
silverblueBP is online now   Reply With Quote
Old 04-14-2009, 11:12 PM   #5 (permalink)
I'm only autocrossing, not open tracking, but I have a Cobra T-pan and a Ford windage tray. Kinda hard to watch the guage with the cones coming at me so fast, but near as I can tell no oiling issues.
70 Mustang Vert--Konis, Addco, springs, Shelby drop, SSBC front discs, 2.75:1 T-lok, Magstars, Michelin X-Ones, 302, Autolite 4100, cam, Hipo manifolds, C-4. Not a car like I had when I was a kid--rather, a car like I WANTED to have when I was a kid.
Also into American Flyer electric trains--Its never too late to have a happy childhood.
solomaniac is offline   Reply With Quote
Old 04-15-2009, 12:50 AM   #6 (permalink)
garner67's Avatar
+1 for the Canton Road Race pan with a windage tray.
I also got my pan from Shaun @ StreetOrTrack.
67 C code fastback - more pics
Paint & Body done 1/27/09
351w
Global West a-arms
Maier springs
Koni shocks
Baer disc brake system
alum radiator w/dual electric fans
G-Force T5
31 spline 9" w/3:50 gears
Azenis RT 615 225/50/16 front & rear
Fresh Black Paint
garner67 is offline   Reply With Quote
Old 04-15-2009, 07:48 AM   #7 (permalink)
tjc1965's Avatar
+ 1 on the Canton pan also. Someday I'll get the car back on the track...
Tom C (NH)
1965 K fastback, "freshstoration" started
1965 coupe, track car
tjc1965 is offline   Reply With Quote
Old 04-15-2009, 11:24 AM   #8 (permalink)
OK I'm looking at that Canton pan and had a couple of questions. First it says it includes a crank scraper, is that built in or is it removable? Reason I ask is I already have a windage tray with a built in scraper. Also, the pickup says it's larger diameter for high volume pumps. Will that still work OK with a standard pump? Thanks all!
68Restoman
Old 04-15-2009, 11:52 AM   #9 (permalink)
Shaun's Avatar
The crank scraper on the 15-630 is tack welded in. If you don't need it guys just cut it off.
Thanks,
Shaun
Shaun is offline   Reply With Quote
Old 04-15-2009, 11:55 AM   #10 (permalink)
Just Joe
I have the same pan and have a standard pump and windage tray. I can't say to the scrapper
1968 Coupe, In progress
1966 Red Conv (200)
1966 White Pony Int.(289)A Code
1966 Coupe 5.0l; 10:1 compression; 650 Speed Demon, and Close ratio Toploader
1966conv is offline   Reply With Quote
Old 04-15-2009, 12:08 PM   #11 (permalink)
Great, thanks for all the help!
68Restoman
Old 04-15-2009, 02:21 PM   #12 (permalink)
LanceMach's Avatar
Some of the guys in the NorCal Shelby Club (of which I am a member - going to Thunderhill on Saturday!!) like the Avid pan, but it's a bit more than the Canton.
Like most here, I went with a Canton (9 quart, road race version). Like some here, I also got mine from Shaun at Street or Track, but I went one further: he helped me install it (Disclaimer: Shaun and I have been friends since he was a young punk - now he's slightly older: still a punk, but a pretty good guy nonetheless).
I used to get oil starvation in the Carousel at Sears Point and in turn 3 at Thunderhill - not any more!
Also, my car is lowered quite a bit, but I have never had a problem with the pan being too low - wish I could say the same about my headers!
Shaun may be able to answer your questions about the scraper - he's a pretty sharp guy, but please don't tell him I said that!
Lance
67 Mustang 289 4V T5Z
97 Mustang GT 5 Speed
LanceMach is offline   Reply With Quote
Old 04-15-2009, 05:22 PM   #13 (permalink)
Anybody willing to snap a couple of pictures of the inside of these pans? I got a couple of ideas
Rusty
'65 Coupe, 6cyl original, V8 conversion 302, see more at the Car Domain site.
'65 Coupe Road Race Project
Admin - Racefab - Race Car Design and Fabrication Forums
JR4 Motorsports - DIY Fuel injection, MegaSquirt
rusty105 is offline   Reply With Quote
Old 04-15-2009, 10:33 PM   #14 (permalink)
does that pan hold 9 quarts? does everyone run 9 in it,my engine builder told me 7 quarts would be fine.should i add 2 more quarts?
rsrr is offline   Reply With Quote
Old 04-16-2009, 01:29 AM   #15 (permalink)
I have no axe to grind with Canton, or any mfg for that matter, but you are likely not to see that pan on any serious race car. Aviaid or a pan made by AR Oil pans (http://www.geocities.com/motorcity/flats/1624/) might be the way to go. You can have either one make it to your specs. If you don't need the scraper make sure to have them leave it off...its a pain cutting it off later. The one Armando puts on his pan normally will interfere with a stud girdle. I would take a pic of my block pan surface area and send it to them. A really good pan costs a bit because it works. Also make sure you weld a small nut or similar to the bottom of the pick up in case the bottom of the pan is hit it won't cut off oil to the pickup. Most forget this can happen...it can. I redesigned Armando's to hold 10qt and give more ground clearance and had him make it. Good luck.
Sandy
shelbyman1 is offline   Reply With Quote
