» Network Links
»Super Springs
Go Back   Vintage Mustang Forums > General Discussion > The Track
Old 08-04-2009, 02:08 PM   #1 (permalink)
horseplay's Avatar
Default Cutting Coil Springs
I have been thinking about trying this.
I was going to start with a 1/4 a coil cut.
I am looking to get a just a lil lower stance.
My question is doesn't this effect the load rating of the spring (lbs/in) which would be a nice plus for me too.
Is there any formula for this?
1975 Bricklin SV-1 357W
1970 MACH 1 393W
picturetrail.com/jetnoise
horseplay is offline   Reply With Quote
Old 08-04-2009, 02:37 PM   #2 (permalink)
Yes, cutting coil springs affects the stiffness; I've seen several formulas for this and only a few seem to work out right. Wire diameter, # of turns, and height all factor into the load rating. Eaton Detroit has one formula somehwhere on their website and their example is a 67GT spring, so it's pretty useful for us Mustang guys.
Right at the moment, I'm cutting a set of 67 springs to fit in my 66; I'm taking them down to the same height as the originals, then I'll probably cut at least 1/4 of a coil.
Now if I could just find my saw...
The squirrels in my head have spoken.
Cobra 5.0L & AOD swap, here we come.
gotstang is offline   Reply With Quote
Old 08-09-2009, 08:18 AM   #3 (permalink)
deuce68's Avatar
gotstang I cut my front springs and used a die grinder with a flat cutoff disc.
1968 Fastback 347 stroker, C4 trans, 3:55 rear
deuce68 is offline   Reply With Quote
Old 08-09-2009, 10:06 AM   #4 (permalink)
In my opinion the easiest and best way.
Sandy
shelbyman1 is offline   Reply With Quote
Old 08-09-2009, 02:17 PM   #5 (permalink)
I agree. Worked like a charm when I did it a few days ago, though I might use the bandsaw to true them up.
Old 08-09-2009, 06:11 PM   #6 (permalink)
Have found the best way to clean them up is to use an angle die grinder with an abrasive pad.
Sandy
Old 08-12-2009, 05:15 PM   #7 (permalink)
mikes69mach1's Avatar
Default Re: Cutting Coil Springs
I cut 1/2 coil off my Mach with a cut off tool without even removing them from the car. I did take the load off the front tires tho.
69 Mach 1 351w .030 over, KB flat tops, 10.7 comp,282 xtreme energy roller cam,offy 360 degree intake, Holley 750, 9" locker rear end with 3.89 gears,ported heads
mikes69mach1 is offline   Reply With Quote
Old 08-18-2009, 06:48 AM   #8 (permalink)
autoxsteve's Avatar
I use a hacksaw and take it slow.....
Works fine and it does affect (decrease) spring tension.
Links-R-Us...
Steve Leslie, 65 cpe, 302, toploader, A/C, orig disc brakes, bench seat, tri-bars, tri-Ys, I need tri-power! 350,000 miles (4/10/2006)
autoxsteve is offline   Reply With Quote
Old 11-19-2009, 12:41 AM   #9 (permalink)
supershifter2's Avatar
use a grinder or a saw do not use a torch and dont knick the coils as that will cause a breakage.
supershifter2 is online now   Reply With Quote
Old 11-20-2009, 01:03 PM   #10 (permalink)
gfmccann-temp's Avatar
Originally Posted by autoxsteve View Post
.....Works fine and it does affect (decrease) spring tension.
You're saying cutting the spring DECREASES the tension? In fact the net spring rate will increase. A spring is simply a rolled up steel bar that twists as the spring is compressed. Try twisting a yard stick a quarter turn. Now slide your hand in a foot (= cutting a spring) and try to twist the same rotation... Not so easy.
'65 Coupe sold. Onto the next...
gfmccann-temp is offline   Reply With Quote
Old 11-20-2009, 04:02 PM   #11 (permalink)
i 2nd your post ! cutting a coil increases tension. the 620 springs i used back in the early 70's were boss 302 springs that had ( 1-1/2 coils i dont remember exactly ) cut off and that raised the rate to 620 and lowered the car a little bit. i bought mine from MAIER Racing back in the 1970's. i think this was taken from the the boss 302 chassis manual. anytime you remove coils from a spring it becomes stiffer and also lowers the car a tad.
Old 11-22-2009, 08:29 PM   #12 (permalink)
FredG's Avatar
Horseplay,
I found the quickest way to cut the springs was with a cut-off wheel. Then I put a dab of paint on the cut end to prevent rust....For what it's worth, though don't let the advertised spring numbers, like 620 (since that seems to be a popular number) fool you, as I found that that, at least in my experience, it had nothing to with the actual spring rate...might have been the gauge of the wire or something, but all I know is that I wanted a 600 pound front spring rate in my 65 and ordered "620's" from NPD, then Mustangs Unlimmited, and then CJ's. All three sets didn't come close to "620" pounds with the NPD's measuring 495 and 505! The other two were in the low 500's. Wound up calling Scottie at Cobra Automotive and ordered a set of 67 and up big blocks, cut off approx 1 1/2 coils and then brought them over to a local roundy-round race shop (prob the only one on Long Island) for measuring on the spring gauge...605 and 610 pounds!
65 K Code Fastback, the "HuggerMugger", sponsored by Motion Performance, Baldwin, NY 1969-1971
66 GT350H, # 6S1826, black/gold
06 GTH # 06H683 (one of 30 never rented)
03 Silver SVT Coupe, VIN 3000095, # 411
LONG ISLAND CHAPTER SVTOA
06 F-150 SuperCrew
FredG is offline   Reply With Quote
Old 11-26-2009, 12:12 PM   #13 (permalink)
If you have a bandsaw at your disposal, wouldn't that be the best tool to cut a spring?
Thanks... Bruce
DIRTY289 is offline   Reply With Quote
