» Network Links
»Super Springs
Go Back   Vintage Mustang Forums > General Discussion > The Track
Old 11-11-2009, 05:43 PM   #1 (permalink)
masergt's Avatar
Default Trans-Am tribute crankcase ventilation
So I posted a thread on the main page on this 1968 Tran-Am tribute.
1968 Trans-Am Tribute
I am curious about the crankcase ventilation set up plumbed from both valve covers to a cannister (I presume it's crankcase ventilation and not part of a dry sump set up?). Can someone explain it's function and, assuming it's ventilation, does this provide some enhanced function?
Another quality post brought to you by MaserGT from/ uit/ uut/ aus/ de Vancouver, Canada.
This post may contain up to 80% sarcasm, measured by weight not volume. Contents may have settled during posting
resulting in sarcasm appearing more subtle and it may be difficult to discern. Do not adjust your monitor.
masergt is offline   Reply With Quote
Old 11-11-2009, 06:12 PM   #2 (permalink)
Oil vapor collection in place of a PCV system, so that the car doesn't smoke during extended high RPM use....at least that's my guess.
The squirrels in my head have spoken.
Cobra 5.0L & AOD swap, here we come.
gotstang is offline   Reply With Quote
Old 11-11-2009, 08:03 PM   #3 (permalink)
Right, just looks like a fancy catch can for the crankcase vapors. I've also seen longer breather tubes added to stamped steel valve covers that extend upward on '65-8 roadracers, as well as nifty setups like on the later '69-70 T/A cars that have tubing connecting both banks with two inline breather caps.
'65 GT350 Clone - 363 Stroker, Weber 48 IDAs
'70 SportsRoof - Roadrace Project
'98 SVT Cobra - Chrome Yellow/Black
'05 GT - Mineral Grey/Red
amorrow02 is offline   Reply With Quote
Old 11-11-2009, 10:51 PM   #4 (permalink)
roadracer's Avatar
The catch tank is a modern day requirement required by most sanctioning bodies and was not run in the day.
There is no performance advantage, in fact,..it adds weight (= bad).
"If you're under control you're not going fast enough"
Parnelli Jones
Visit Roadracers Corner
roadracer is offline   Reply With Quote
Old 11-11-2009, 11:21 PM   #5 (permalink)
JonK's Avatar
Does anyone still sell these? I'd like to find a pair of stamped steel with the long fill tubes that have a ~45* angle to them like I've seen on some roadracer/transam mustangs.
Jon
"If it ain't broke, I haven't fixed it yet"
-Jon-
1967 Coupe 333ci CandyApple Red w/red int., AOD, 9" 3.50:1, Front PDB
'09 Warriors In Pink V6 w/glass roof - wife's Stang
JonK is offline   Reply With Quote
Old 11-12-2009, 09:15 AM   #6 (permalink)
Jon
Cobra Auto or Shelby Parts or someone makes them, but they charge through the (insert expletive here) nose, something like $500. If you could come up with all the bits, I bet you could get a set welded together on the cheap. (Hint: I own a welder )
Old 11-12-2009, 09:32 AM   #7 (permalink)
Yea, just get some steel tube sized for standard push-on breather caps, and some plate steel for the gusset reinforcements, and weld away. Someone could probably bend them for you easily, or just get the tubing from a shop capable of pre-bending what you need.
I just picked up a couple pairs [new to welding, so I'm sure I'm gonna screw up] of '70 351C valve covers to replicate the '69-70 setup for my '70.
Old 11-13-2009, 09:25 PM   #8 (permalink)
henry_v's Avatar
Crankcase oil vapor ingested via the PCV system decreases horsepower.
henry_v is offline   Reply With Quote
Old 11-23-2009, 03:31 PM   #9 (permalink)
Send a message via ICQ to jeff33702
..and causes detonation which would be a real risk with these iron-headed high-compression motors.
Jeff in Florida
jeff33702 is offline   Reply With Quote
Old 11-23-2009, 06:15 PM   #10 (permalink)
Default Catch Can
The catch can is required by most all Vintage Road Race organizations and SCCA . It's primary function is to collect any oil due to blow by or from an engine failure - The whole point is to keep oil off the race track.
couper69 is offline   Reply With Quote
