Want to build a corner carver - Vintage Mustang Forums
 1Likes
post #1 of 90 (permalink) Old 03-03-2013, 07:32 PM Thread Starter
Hey VMF, first post here but not new to Mustangs. I've got a 66 coupe, 4 speed manual with a 289 that I've owned for 10 years and would like to improve the chassis. Not pertinent to old Mustangs but I also own a 04 GT with a full Griggs Racing chassis. I've been doing research for quite some time and would like some opinions for the 66.
Not sure if I should go full blown modern chassis on it or do a mix of old school with a modern twist. First off I snagged a set of Global West uppers to do a Shleby drop, they were used so I don't have a template. I understand there is a one inch or a 1.75 drop, any opinions on which would be better? I've been exercising the idea of rack and pinion or doing a FR quick ratio box and rebuilding the factory stuff. I love how quick and easy steering is on any new car, I don't mind the effort of manual steering but if I decide to auto x or do driving events I want quick responsiveness. I'm open for any set ups or experience you guys have!
Thanks!
CalStang66 is offline
post #2 of 90 (permalink) Old 03-03-2013, 08:18 PM
Bucket Lister's Avatar
Don't do any drilling for the Shelby drop until you get a template. The new holes are not directly downward.
Global West has a website. Get ahold of them. I'm sure they will get you a template somehow.
Illigitimi non corundum.
1966 mustang coupe GT350H clone
5.0L, GTP heads ported, RPM, E303, Holley 650 CFM, GForce T5, Tri-Y 2.5" X, 411:1, Global West front & rear, Wilwood front, Cobra rears, Caltracs
Bucket Lister is offline
post #3 of 90 (permalink) Old 03-03-2013, 08:47 PM
silverblueBP's Avatar
http://www.opentrackerracingproducts...s/template.jpg
-Mark-
1966 Mustang 2+2
"Money can't buy happiness, but it can buy a race car. And I've never been sad in a race car!"
silverblueBP is online now
post #4 of 90 (permalink) Old 03-04-2013, 12:23 AM Thread Starter
Do you guys have any opinions on rebuilding stock steering vs R&P set ups? Pros and cons?
post #5 of 90 (permalink) Old 03-04-2013, 09:10 AM
No R&P for me. I'm running manual with a Flaming River (new in 2002) box.
-Mark-
1966 Mustang 2+2
post #6 of 90 (permalink) Old 03-04-2013, 12:24 PM
GT289's Avatar
Originally Posted by silverblueBP View Post
Neither of those is the right drop template for Global West upper arms.
The drop on their arms currently is 1.5" ....... the reason I say currently is
because that number has changed at least once since 1984.
I'm traveling this week, so your best bet is to call them and see if you
can score one that way.
I really don't care for the R&P kits that are out. Too much compromise.
The only good one's I've seen are all custom rack setups.
ex-Global West GM
1991-1995
- Douglas Adams
GT289 is online now
post #7 of 90 (permalink) Old 03-04-2013, 01:06 PM
Titus_RacerX's Avatar
I have a Datsun 240Z for sale...
Titus_RacerX
'66 GT Fastback, Springtime Yellow. Plant: Metuchen , NJ DSO: Atlanta. AT, A/C. 6T09A111858
Parked since 1980. Carport find that I've been watching for 10+ years.
2013 Nissan Leaf SV
2006 Nissan Pathfinder SL
Code Name: Daisy Photobucket
Often the path to forgiveness is to realize that the other person is an imbecile.
Titus_RacerX is offline
post #8 of 90 (permalink) Old 03-04-2013, 03:18 PM Thread Starter
I was digging around my parts pile and realized I have the templates and some hardwear. I installed some new ball joints in my used GW arms and got one side installed already. I called GW just for grins and they said their drop is 1 3/8 apparently.
As far as steering goes Im not sure what to do. Quick ratio boxes run in 500 or 600 range plus other items I'll service while Im in there like tie rods or what ever. Not sure if I should also run a Shelby pitman arm or is that only for use with stock steering? Flaming River makes a steering rack/tilt steering combo for 1200. Thats tempting considering I'd like a tilt column and a new box would be 50 percent of the cost of a RP set up. Im sure with either set up I'll have to correct bump steer. Another consideration, IIRC, steering effort is heavily related to scrub radius so rack and pinion or not I've got some more figuring out to do...
post #9 of 90 (permalink) Old 03-04-2013, 06:31 PM
GT289's Avatar
That's just today (and depending upon who you talk to there), tomorrow maybe
different
I have both 1 3/8" steel and 1 1/2" blue plexiglass in my tool box.
ex-Global West GM
1991-1995
- Douglas Adams
GT289 is online now
post #10 of 90 (permalink) Old 03-04-2013, 09:27 PM Thread Starter
Well, I ripped the pony around and seems to be better, I didn't have time to align it tonight so I'll do it tomorrow. Not sure what I think yet, I know it's an improvement but its hard to tell. Steering is sloppy and I'm sure there is zero caster because I lost all my self centering on the steering. I'm almost certain I have way to much negative camber also. I'd like to get adjustable strut rods from GW but I'm running 16x8 wheels with a 225 tire, IIRC it's a 55 side wall, but they rub like crazy. So if I add more caster through strut rods it will just get worse.
post #11 of 90 (permalink) Old 03-04-2013, 09:47 PM
Check out StreetorTrack.
patrickstapler is online now
post #12 of 90 (permalink) Old 03-04-2013, 09:51 PM
Lukesportsman's Avatar
Need either measurement or photo of front ride height.
225 is not max'd, but rim offset may not be ideal
Yes, if you just did the "Shelby" drop you are prob camber heavy. Get the camber eccentric eliminators.
Wouldn't have thought the caster would have changed remarkably unless you moved the lower arm too. But yes caster can change the rotation axis. Where is it rubbing front/back fender:frame
Don't forget in the end to compensate for bump steer. You'll never be happy with the lowering until you do. Neither of these mod's are pricey and there are several good strut rod solutions. Do NOT run Poly on stock type as it just binds and doesn't fix problems.
69 351 TKO Sport Roof, Ride Tech coilover
70 557 PG Mach I tube chassis 2650lb
70 427 TKO Sport Roof, SoT full chassis to be
70 351 FMX Mach I
67 347 TKO Coupe SoT/CAT5
67 289 C4 Coupe stockish cruiser
69 460 TKO Vert, Mustang Plus Grab a Track
94 351 TKO AIX, Maximum Motorsports
01 5.4 4L80E Twins and CrMo caged
http://www.hubgarage.com/mygarage/LukeSportsman
Lukesportsman is offline
post #13 of 90 (permalink) Old 03-04-2013, 10:04 PM Thread Starter
I have no idea how much it's lowered, I know the center of the wheel from the ground to top of the wheel well is 24.5 inches. I know that means nothing with out a pic but its tucked. It rubs the front lower part of the fender. I really like GW bump steer kit but I'm not sure if I'm going to run RP or factory steering so I want to make sure it's compatible with any bump steer kit I get. I'd actually like to get new springs front and rear with Bilstiens or some other quality shock. I'm sure with bump steer and the terrible rebound control of my tired KYB's that doesn't help either.
post #14 of 90 (permalink) Old 03-04-2013, 10:40 PM
Myopic
You are fighting yourself.
16x8 wheels, to fit on a mustang have 4.5 backspacing, which is limiting factor number 1 (aka with a larger rim you could move everything inward another .25 inch.
A 225 55 16 is 26 inches tall and your car's ride height is 24.5 so where other people can live the backspacing on the 16x8 you can't which is limited factor number 2
You need more - camber to keep the tires from rubbing plain and simple with how you have it configured at this point.
You also need the adjustable rods not necessarily for the caster (that is a benefit) but for the solid mount and lose the deflection of the bushing in your stock strut.
You then need to install your upper arms either according to the global west instructions (best) or at least in the shelby drop location and then you need to take it and get it aligned with -2.5 camber, as much caster as you want and 1/8 toe. If it rubs after that roll your fender lips. If it rubs after than, go to -3.
1965 Fastback 410c AOD - DT
1967 Fastback 347 T5- Cruiser
1968 Fastback 408w T5 - Brute
1991 GT Hatch - Fauxbra
1996 Dodge Viper GTS
https://www.youtube.com/watch?v=0LUK2D0GjdY
dodgestang is offline
post #15 of 90 (permalink) Old 03-05-2013, 02:51 PM Thread Starter
I think I'll order up GW strut rods. Im going to get it up on the alignment rack today and get some base line specs. Im still not sire which route to go with the steering. I adjusted my steering box successfully but slow ratio makes it less fun to drive.
