65 notchback "track day" build - Page 3 - Vintage Mustang Forums
 13Likes
post #31 of 149 (permalink) Old 02-28-2015, 03:19 PM
Target's Avatar
Originally Posted by Kermit View Post
Now regarding engine bay, what colour would you recommend?
I want to be able to see any dirt, oil leaks, splashes etc....
So black is out of the question.
My engine bay is matte black and you can see EVERYTHING...
1967 Mustang 302 - Build Thread
1976 Triumph Bonneville
From Los Angeles. Going to college in Santa Cruz, California.
Target is offline
post #32 of 149 (permalink) Old 02-28-2015, 04:36 PM
Supporting Vendor
Shaun's Avatar
My car will be picked up in two weeks time to start the work required for this build.
first step:
weld all the little holes that accumulated over the last years, ie: drilled holes and not rust hole as there is no rust on the body
seam weld the chassis
prime it
undercoat
engine bay painted
I would do the entire underside and engine bay grey. I only had my interior & trunk painted like this and its already much easier to see things. My next build will be inside, underside, engine bay and trunk like this. Great for a race car where you want to keep an eye out for cracks/leaks etc.
Shaun is online now
post #33 of 149 (permalink) Old 02-28-2015, 05:10 PM Thread Starter
Hi Shaun,
I saw your track day car build (very cool), I do like this grey.
Would you mind sharing the paint code or give a pointer as to what it is please?
Kermit is offline
post #34 of 149 (permalink) Old 02-28-2015, 05:25 PM
Supporting Vendor
Shaun's Avatar
Hi Shaun,
I said to the guy I want Nascar grey, and that is what I got! I don't know what he used.
Shaun is online now
post #35 of 149 (permalink) Old 02-28-2015, 05:37 PM Thread Starter
ok no worries, I will show the pictures to the guy and see what he comes up with.
Kermit is offline
post #36 of 149 (permalink) Old 03-04-2015, 03:56 PM Thread Starter
decisions decisions.... the dash....
GT350-r style
source
or original dash with the pad?
Kermit is offline
post #37 of 149 (permalink) Old 03-23-2015, 04:37 AM Thread Starter
The car has been picked up this Saturday.
All the necessary welding will be done, primer, under body protection and maybe engine bay painting.
Kermit is offline
post #38 of 149 (permalink) Old 04-06-2015, 08:01 PM
cornholio's Avatar
Since you went modified, I say no Pad. I changed mine and never looked back.
[IMG][/IMG]
[SIGPIC]
1966 Coupe Restomod
331 stroker, 5 speed
9 inch with 3.90 posi
Coil Overs, Ladder bar, subs, 6pt rollbar
Wilwood Brakes
Novi 1200 Blow Thru
510 rwhp after S/C
cornholio is offline
post #39 of 149 (permalink) Old 04-07-2015, 04:40 AM Thread Starter
It does certainly look better in my opinion, I have now seen one modified (ie: no pads) with my own eyes the other day and I really do prefer it this way.
Kermit is offline
post #40 of 149 (permalink) Old 04-07-2015, 04:46 AM Thread Starter
A quick update about the build, it's gathering pace now.
The old speaker holes are now gone
(This was really at the beginning)
The other door with the hole gone.
LOTS of little holes to weld up...
The is stage 1 (without going into all the fine details of it).
weld all the holes that needs doing
quick light primer to protect the metal
Stage 2 is roll cage (TBA).
Stage 3 is paint (TBA).
Kermit is offline
post #41 of 149 (permalink) Old 04-07-2015, 04:54 AM Thread Starter
After a lot of thinking, I've taken the decision in building a 289... however not a crazy one with gazillion of BHP and RPM's ....
Kermit is offline
post #42 of 149 (permalink) Old 04-07-2015, 02:34 PM
Looks like that 289 was/is already built up for some extra HP: Electric water pump, roller cam conversion, ARP hardware, roller rockers..... Got a pretty good set-up as is. Just going to clean it out, have the block/heads checked, then reassemble using old hardware (replace worn items like rings and maybe the lifters if they are not roller and rebuild-able)?
roboticservo is offline
post #43 of 149 (permalink) Old 04-08-2015, 11:09 AM
very cool build. Cant wait to see the finished product
JpMotorsports is offline
post #44 of 149 (permalink) Old 04-08-2015, 12:23 PM Thread Starter
Same here
Today, I've received my first ever order from CJ PonyParts.
Quite pleased with the service, fast and efficient I would say.
It was more of a test order....
Now, I bought some hood hinges (repro) made from Dynacorn.
First time I said wow for a repro part, compared to the made in China & Taiwan flimsy ones I got a few years ago, this is really a huge improvement.
I doubt very much I will be able to bend them.
Kermit is offline
post #45 of 149 (permalink) Old 04-08-2015, 09:42 PM
cornholio's Avatar
[IMG][/IMG]
Updated pic of interior without dash pad.
[SIGPIC]
1966 Coupe Restomod
Wilwood Brakes
Novi 1200 Blow Thru
510 rwhp after S/C
