66 Fastback rebuild / track ride - Page 2 - Vintage Mustang Forums
 4Likes
post #16 of 70 (permalink) Old 09-17-2015, 03:00 AM
I love the trimmed shock towers. I have a 351w in a 65 fastback and anything header or spark plug related is a total PITA. It's a nicely done beautiful car!
Jeff351w is offline
post #17 of 70 (permalink) Old 09-17-2015, 05:01 PM Thread Starter
Interesting on the 1" difference I need all the headroom i can get as i'm 99% positive with a helmet on I will be close to the roof.
So quick update:
Been working with Mike at Maier the last week on the brake package.
I think we've settled on the Superlight Wilwood 6 piston fronts with dynalite 4 piston rears with the b pads and chryo treated pistons. I'm still going back and forth on the rears using a superlight in the rear but mike feels it might over brake the rears.
Also getting quotes on ET wheels model 3's in both 17x8's squared and 18x8' squared. the kid in me wants the 18's however the lower mass of the 17's is the smart move..so i will most likely end up with 18's =)
Try2Paz is offline
post #18 of 70 (permalink) Old 09-17-2015, 05:05 PM Thread Starter
So quick update:
Try2Paz is offline
post #19 of 70 (permalink) Old 09-17-2015, 07:01 PM
I would look at tire availability before making that choice, sticky tires will trump minor wheel weight differences.
'65 A-code coupe, T-10 4-speed, 8" 3.25 limited slip
stephen_wilson is offline
post #20 of 70 (permalink) Old 09-17-2015, 07:41 PM
fej
I agree, very little is offered in appropriate widths for our cars in 17's these days, most everyone in the CAM and USCA type events are on 18's now, that is a function of size availability in the best compounds (as well as large brake clearance requirements)
Mike will get you taken care of, are you local to the Bay?
Fej
1966 GT Coupe
Not much left original
Trying to do things once
MMI CO ~ Astro A5 ~ FiTech ~ MGW ~ AAW
fej is online now
post #21 of 70 (permalink) Old 09-29-2015, 10:56 PM Thread Starter
Hey guys having trouble with a water pump that's becoming way more trouble than it should.
So originally the car had a drive side lower radiator feed that went to a passenger intake. the problem was i had this huge hose that was cobbled together with aluminum and rubber.
i wanted to switch to a drive side feed to have a nice short hose come out of the radiator and up to the water pump.
so here is the problem..
The original water pump had a block to hub height of 5.42"
the new water pump that feeds from the drive side is 5.7" and now the pulleys don't align.
I ordered a canton pulley for the new water pump and i'm off by a long shot to the harmonic balancer.
so now what? does anyone make a different driver feed water pump that is shorter or do i get a different lower harmonic balancer pulley?
i'm lost.
[IMG][/IMG]
Try2Paz is offline
post #22 of 70 (permalink) Old 09-29-2015, 11:35 PM Thread Starter
i cant find the exact specs on this pump but looks like ford has one also.
Ford Racing Mechanical Water Pumps M-8501-F351 - Free Shipping on Orders Over $99 at Summit Racing
If it's 5.42 i will return the edlebrocks and get this unit.
Try2Paz is offline
post #23 of 70 (permalink) Old 10-14-2015, 05:57 PM Thread Starter
Couple updates:
Water Pump is back to the feed side of Passanger.. the only way to make a driver side feed work is to change timing cover, harmonic balancer, pullies etc...
So instead I ordered a new C&R radiator with both pass return / feed.
I've pulled all the fuel lines and starting on cleaning up the trunk. The fuel cell is pulled and we are grinding down all the crap, filling all the holes from the last 40 years and giving it a nice Por 15 treatment.
[IMG][/IMG]
Try2Paz is offline
post #24 of 70 (permalink) Old 10-28-2015, 11:29 PM
Car looks great, a little freshening up and you'll have it back on track in no time! Good call on the new radiator, the headache of trying to get Ford pullies matched up can be a nightmare.
Have you decided what to do on the seats? If you decide to sell the current ones I'd be interested, just sayin.
Oh and the 18's are going to change the entire look of the car, for the better!
Good luck selling the CTSV.
Dan
Dbasher is offline
post #25 of 70 (permalink) Old 11-18-2015, 10:45 AM Thread Starter
Well time for wheel picks! I'm settled on Charcoal / polished lip
now its just down to these two! let me here your Votes.
Try2Paz is offline
post #26 of 70 (permalink) Old 11-18-2015, 11:00 AM Thread Starter
Some updates to the progress.
Finished new Cooling system:
We went with a custom C&R radiator that had both the fill and return on the passenger side. It was pricey but at least I don't have to worry about a long lower radiator hose. We also had them use side mounts on the radiator apposed to top.
New T-Stat housing / New high flow water pump / New radiator / Fans / harness. Done!
Next up is Fuel system.
We pulled out everything old ran new lines from trunk to front with a feed / return.
patched up the hundred holes in the trunk and laid down a fresh coat of Por 15 and started reassembling.
Feed out of tank
New pump setup - shut off valve / filter / inline pump
new fuel pressure regulator with Return setup
finished product
road test went great no leaks, I do have a slight miss that feels fuel related so i'm going to be pulling the carb off and sending it to Competition Carbs in Reno to have them hot tank it, and work it over a little bit for the road course. I've already done Plugs / wires / coil / cap etc.
Now the car is at Mike M for suspension disassemble.
Try2Paz is offline
post #27 of 70 (permalink) Old 11-18-2015, 04:25 PM
Lookin good! Funny I was looking at those same wheels, decided that when the time comes I'll save for the ETIII's. If it were my money I'd be going for the Tungsten with brushed lip, either way they're great looking wheels.
Shameless plug for a buddy....Have you looked at Rushforth's?
Dbasher is offline
post #28 of 70 (permalink) Old 11-18-2015, 04:32 PM
rabdyl's Avatar
Been following your updates, looks great! I like the Tungsten rims just a little bit more.
1966 "C" Code Fastback, Ford crate 306, T5, 3.80 Trak Lok Rear, Sub-frame connectors, Tri-Y headers, Shelby drop with an empty wallet.
rabdyl is offline
post #29 of 70 (permalink) Old 11-19-2015, 12:02 AM Thread Starter
I've got the rushforth night trains on my Nova and love the look but the finish isn't holding us as nice as I'd like for how expensive they are.
I told mike I can't have all his parts and the same wheels as his! I originally was going to do the ET wheels also.
Try2Paz is offline
post #30 of 70 (permalink) Old 11-19-2015, 05:47 PM
That's too bad about the Night Trains, good looking wheel and a good guy to deal with. What about the ACIII wheels from ET, they've got that vintage look as well.
I see the rear pan hard bar from MMI and leaf springs still in place...what all have you got planned? Oh and just a heads up, I texted Mike and told him to steal the seats out of your car! Haha!
Dbasher is offline
