I previously had a 1 groove main pulley installed and due to the addition of a few accessories, I added a 3 groove main pulley. Now, I cannot install the water pump pulley because it hits the largest groove on the main pulley (See picture).
What do you think could be the problem? My hunch is that I just found out that my current water pump is a PRW 1435100 High Flow Aluminum Water Pump. This water pump is for a 351C. My engine is a 351W. I assume that the 351C pump sits lower than the 351W?
My pulley combination should be correct. I have a 3 groove crank for AC and Power Steering and the water pump pulley that I got is supposed to support AC. I am working on the water pump part now.
The crank pulley that I currently have is a 4 bolt so its the post 1970 kind. Good point about searching for 351W parts. Perhaps purchasing a kit of V belts would be a better option?
So I ended up getting a very nicely machined 351W 3 Groove kit from March Performance. I am very happy with it. My only concern is that I may need to use a spacer on my main pulley. The first groove actually sits behind the alignment of my water pump pulley. This means the second groove (or center groove) aligns with my water pump pulley.
I plan on using power steering and AC. Does this sound like something that a Spacer would fix? As of now I am not sure if the first groove on my main pulley is usable.
You might be able to move the hub back on the pump, if that would help. Use a press.
Related Threads
Vintage Mustang Forums
4M posts
89.2K members
Since 2001
