LED Tail Lights - Vintage Mustang Forums
 5Likes
  • 3 Post By Woodchuck
  • 2 Post By tomypasta
post #1 of 10 (permalink) Old 11-04-2016, 01:27 PM Thread Starter
LED Tail Lights
I purchased the Sylvania Zevo LED to replace my 1157 on my 67 Mustang, but they will not blink, however they stay stuck on Bright like they wanted to Blink. Do i need to add a resistor before the light socket? Or add something else?
bustrud67 is offline
post #2 of 10 (permalink) Old 11-04-2016, 02:18 PM
I'm not completely familiar how a '67 works, but you may need to install an LED compatible flasher. I did with my '69. The resistor idea may work as well.
2008 Bullitt|Roush M90 w/ 2.57 pulley and CAI, 90mm MAF, Steeda UCA, LCAs, Hyperco springs, Brenspeed tune, Roush shifter, a few other things|
1969 Coupe Restomod-never complete!
2008 Power Wheels Bullitt Clone
Mustangs from the past: 66 coupe, 69 Coupe, 69 Grande, 2001 Bullitt, 2011 V6
rangerdoc is offline
post #3 of 10 (permalink) Old 11-04-2016, 02:24 PM
gt350sr's Avatar
I did resistors on a '40 as I did the taillights only. After words I found they make special flashers for the LED bulbs, and I think even ones for mixed LED and regular bulbs. The LED's don't draw enough voltage to trip the flasher unit..
Buckle up- I wanna try something!!
gt350sr is offline
post #4 of 10 (permalink) Old 11-04-2016, 06:59 PM
qbui's Avatar
PM GTONavy on this forum and see if he can give you some insight. I purchased his sequential tail lights and he had me install a different flasher for his tail lights.
1969 Mustang Convertible
302, C4, P/S, P/B, A/C, FiTech EFI
qbui is offline
post #5 of 10 (permalink) Old 11-04-2016, 07:27 PM
Woodchuck's Avatar
Conventional flashers work on circuit resistance causing a bi-metal strip to heat up and bend, breaking the circuit, then cooling and re-establishing contact. LED's have much less resistance and won't heat the strip enough to bend.
You can either replace the flasher with a solid state unit that doesn't rely on load, or add resistors to make up for the lost load.
66conv6, 69DroptopGT and Mach671 like this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #6 of 10 (permalink) Old 04-21-2017, 03:48 PM
tomypasta's Avatar
Send a message via AIM to tomypasta Send a message via Yahoo to tomypasta
you prob had the bulb 180 degrees off in the socket.
66/93project and artc like this.
tomypasta is offline
post #7 of 10 (permalink) Old 04-21-2017, 10:47 PM
franklinair's Avatar
The low current draw of the LED's require a flasher compatible with the lower current.
Neil Hoppe
1968's: Best of the Best:
1968 GT/CS J Code
franklinair is offline
post #8 of 10 (permalink) Old 04-22-2017, 01:28 AM
gtonavy's Avatar
You will need an LED flasher (turn and hazards) like this one.
Accessories
It must have the extra ground wire.
Gary
1967 CV 289 A Code
1973 450SL
http://www.vintageleds.com/
gtonavy is offline
post #9 of 10 (permalink) Old 04-24-2017, 10:23 AM
C6ZZGT's Avatar
Accessories
Gary
Why does it need the ground wire ?
6r07a143871 --owned since 10/83
C6ZZGT is offline
post #10 of 10 (permalink) Old 04-24-2017, 12:44 PM
gtonavy's Avatar
It needs a reference to ground.
gtonavy is offline
