1968 door hinge stops - Vintage Mustang Forums
post #1 of 8 (permalink) Old 01-03-2017, 03:27 PM Thread Starter
The "stops" that are on the lower hinge that hold the door in certain positions, on my car are in need of repair. Meaning the pressed pin is coming loose off the bottom. I have three options,
1. weld it in place
2. try to replace it, although I don't see replacements
3.buy new hinge
What do the experts say?
BenBuilder is offline
post #2 of 8 (permalink) Old 01-03-2017, 06:44 PM
I opted for the smart way out and bought new hinges.
By the time I factored in, at a minimum, pulling the fenders and the labor to pull or drill out the old pin it wasn't worth it to me.
eldog is offline
post #3 of 8 (permalink) Old 01-03-2017, 09:03 PM
Woodchuck's Avatar
Buy new hinges. They are relatively inexpensive and aren't THAT bad. Option #2 if the pin won't stay is to use an oversized pin...if you can find one....or have an original knurled.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is offline
post #4 of 8 (permalink) Old 01-03-2017, 10:36 PM
22GT's Avatar
Good grief, why would you remove the fenders? I have done hinge swaps without even removing the door, just support the door with a padded jack and replace one hinge at a time. Just paint a new hinge the correct color and install it.
Oh, and use a door hinge wrench.
Amateur restorer. Well, sometimes I have been paid for it. But not right now.
22GT is offline
post #5 of 8 (permalink) Old 01-04-2017, 05:06 AM Thread Starter
Thanks guys. Fender is off as I am doing a bunch of things on the car. I will spend 10 minutes on this then may buy a new hinge.
post #6 of 8 (permalink) Old 01-04-2017, 07:50 AM
I bought new bottom hinges and rebuilt my tops with bushing/pin kit
Jedi is offline
post #7 of 8 (permalink) Old 01-04-2017, 03:11 PM Thread Starter
I ended up welding the back side of the door stop to the hinge. seems to be working fine. Thanks again
post #8 of 8 (permalink) Old 01-04-2017, 03:25 PM
I think the lower hinge and the spring, and the plate comes in a kit from one of the better Mustang parts suppliers. Try NPD or Virginia Classic Mustang parts
Roddster
67 GT 350: MCA & SAAC Gold winner
67 S code GTA coupe
Roddster is offline
