Strange Engine Noise - 1970 Mach 1 351c - Vintage Mustang Forums
 1Likes
  • 1 Post By Woodchuck
post #1 of 8 (permalink) Old 03-18-2017, 03:00 PM Thread Starter
Hello all. I've been trying to get my '70 Mach 1 back on the road after a 4 year resto where almost everything has been replaced. I finally got the car running and driving (somewhat) but after the new exhaust was installed and everything's quieted down, I can hear a ticking from the engine. The motor is a 351c 4v that was rebuild and run by a previous owner. I've seen it run on an engine stand without issues. The engine has sat for three years waiting on the car, though I did turn it over regularly and changed the oil before it sat and after. You can hear the noise pretty clearly in the video below:
I'm not sure if its a stuck lifter (they're hydraulic) or something hitting the transmission spacer, or something else entirely. The car runs fine and the noise increases with engine RPM. Any ideas? I pulled the valve cover off and didn't notice anything amiss.
Indianfiremach is offline
post #2 of 8 (permalink) Old 03-19-2017, 08:55 AM Thread Starter
Any ideas?
post #3 of 8 (permalink) Old 03-19-2017, 09:32 AM
Thatís a substantial noise. Hereís what I would do:
1-Check the oil for signs of metal flakes in it, which would indicate a more serious issue.
2- If not already done remove any belts to eliminate anything on the front of the engine as a cause. Test run engine to see if noise remains.
3-Pull the valve covers and inspect looking for rocker arm / Lifter related issue.
4-Inspect flywheel to see if anything is hitting there.
1973 Fastback, 460
droptop50 is offline
post #4 of 8 (permalink) Old 03-19-2017, 09:57 AM
Bo993's Avatar
Is your car an automatic?
Because it sure sounds like the flexplate hitting on something.
Bo993 is offline
post #5 of 8 (permalink) Old 03-19-2017, 03:08 PM
I had an issue with my 351C when installing a t5, as the newer block plate would hit the oil pan on the 351C and push it back into the flywheel making a good awful noise. The solution was to find a block plate that was completely smooth as the factory ford one had raised stamps in it that caused the contact issue.
69 Mach 1 428 CJ
Modern Upgrades-TKO600, FiTech, A/C
cj428mach is offline
post #6 of 8 (permalink) Old 03-19-2017, 05:19 PM
Woodchuck's Avatar
Some may think this is an ordinary broom handle, but it's really a redneck auto stethoscope. You stick the round, wooden end in your ear and the metal end on different parts of the engine and listen to the noise. Move the metal end around to different locations to isolate the noise. Fuel pump (fuel pump noise), header tube (exhaust valve), valve cover (rocker noise) intake runner (lifter noise, intake valve), front cover (timing chain) bellhousing (flexplate/flywheel/inspection cover), cylinder block (rods/mains), oil pan (rods/mains), etc.
66whitepony likes this.
Bart
What, me worry?
- Alfred E. Neuman
Woodchuck is online now
post #7 of 8 (permalink) Old 03-20-2017, 10:33 AM
Any luck figuring out the cause of the engine noise?
1973 Fastback, 460
post #8 of 8 (permalink) Old 03-20-2017, 09:32 PM Thread Starter
Hello all, thanks for the tips. I've made some progress on tracking down the noise. I drove the car for the first time, and as soon as I depress the clutch pedal, the noise goes away. I am using a hydraulic clutch, and believe it may need to be adjusted. I'll play with it next week when I'm back from a business trip and update everyone. Fingers crossed!
