Steering wheel with less dish. - Vintage Mustang Forums
post #1 of 8 (permalink) Old 04-13-2017, 09:43 AM Thread Starter
I've got a buyer for my Deluxe interior steering wheel. I want to replace it with something with less dish. I'm a vertically challenged guy and the Deluxe wheel is uncomfortably close to my chest. Also, how little dish can you get away with before the turn signal lever becomes an issue?
rose62 is offline
post #2 of 8 (permalink) Old 04-13-2017, 10:08 AM
charlie65_67's Avatar
Look at the Lecarra line of steering wheels.
Charlie, CMSGT USAF Ret. 65 Hi-Po F/B, Mustang Owners Club of Austin (MOCA) TX, Member MCA #27479. Now working a '69 M code mach 1.
charlie65_67 is offline
post #3 of 8 (permalink) Old 04-13-2017, 10:15 AM
My wheel is significantly flatter than your factory deluxe wheel. The issue is that most aftermarket wheels require an adapter that partially offsets the the gains made in the shallow wheel. You can still pick up some clearance if you choose carefully. My setup requires a very slight bend at the base of the turn indicator wand for knuckle clearance. It's a simple process!
'66 GT Fastback, 302, Edelbrock Top End, Holley 670 Street Avenger,
MSD Ignition, JBA Headers & 2.5" Exhaust , T5Z, Currie 3.55 Trac-Loc
rhutt is online now
post #4 of 8 (permalink) Old 04-13-2017, 10:31 AM
GT289's Avatar
I'm assuming the 65/66/67 deluxe wheel is what you're talking about. So 4.5" dish.....
When open tracking, I wanted less to put my hands in a more advantageous position.
Seems like most everything is too much. I went with a Motolita wheel, which is 1.25 dish.
When you add in an original style 6 bolt hub (GT-350), you get around 3.75" of dish total.
(You will need to mark the turn signal stalk, remove it and chock it in your vise to put
a slight bend in it in the appropriate place)
As far as dish, .75" was about all the "savings" I got.
- Douglas Adams
GT289 is offline
post #5 of 8 (permalink) Old 04-13-2017, 11:24 AM Thread Starter
Yeah, I realize that the adapter puts back much of what a flatter wheel gives. On my other car I considered shortening the tube, shaft and everything to move the entire assembly further away. I cut the input shaft when I installed the replacement box and put it back together with a "double-d" coupler from Speedwaymotors. At that time I could have shortened the tube and all, but I never did.
rose62 is offline
post #6 of 8 (permalink) Old 04-13-2017, 06:50 PM
megansmustang's Avatar
Never used one personally but maybe this will gain you a little:
Product Description
Scott Drake Short Turn Signal Lever for all 1965-1966 Mustangs.
Installing a new turn signal lever in your 1965-1966 Mustang has never been easier thanks to this high-quality Scott Drake Short Turn Signal Lever! This lever is easy to install and will look great with your smaller diameter steering wheel.
Features & Benefits:
- Chrome-Plated OEM-Style Direct Fit Replacement
- 5-1/2" in Length
- Ideal for Smaller Diameter Steering Wheels or If You Need Extra Leg Room
- Screws into Place: No Tools Needed for Installation
This Scott Drake S1MS-13305-A Short Turn Signal Lever is a chrome-plated OEM-style direct fit replacement that's 5-1/2" in length. It's a great turn signal lever to use with steering wheels that are smaller in diameter or if you need some extra leg room. But the best part is how easy it is to install! You simply screw it into place and you're done: that's it! No special tools needed!
CJ Pony Parts offers a wide variety of Scott Drake parts that have become so popular many customers ask for them by name. Once you try their parts on your Mustang, we're sure you will too.
Order a Scott Drake S1MS-13305-A Short Turn Signal Lever for your 1965-1966 Mustang from CJ Pony Parts today!
Scott Drake S1MS-13305-A Mustang Turn Signal Lever Short 1965-1966
And read this earlier post Shortened turn signal lever with use of Shelby Steering Wheel? Help!
Oh, and thanks for the wheel.
megansmustang is offline
post #7 of 8 (permalink) Old 04-13-2017, 06:58 PM
That's cool. Never knew anyone made a short version.
post #8 of 8 (permalink) Old 04-13-2017, 07:13 PM
schweigert's Avatar
Moto-lita might be easier to manage in terms of finding what you want
https://www.moto-lita.co.uk/steering-wheels/
yes you're buying from UK but the price is still competitive - and you know the adapter will fit (which i've read is a problem when sourcing lecarra)
the Lecarra I wanted they stopped making as well.
also... something about a genuine UK steering wheel seems neat.
schweigert is offline
