1965 fuel pump - Vintage Mustang Forums
 1Likes
  • 1 Post By Tubbster1966
post #1 of 9 (permalink) Old 04-20-2017, 10:40 PM Thread Starter
Tubbster1966's Avatar
1965 fuel pump
Want to run a 65 fuel pump so I don't need to have an inline filter going up the the fuel command center for my fuel injection. Is the outlet a 1/2-20 flared female? I believe my 66 pump is.
I need to adapt the outlet to -06AN
1966 Mustang Coupe, 289, 4v
Tubbster1966 is online now
post #2 of 9 (permalink) Old 04-20-2017, 10:52 PM
LeeFred's Avatar
Just curious...will the 65 fuel pump supply enough pressure for the fuel injection?
O'Reilly Auto shows the outlet fitting size as being 1/8-27
LeeFred is offline
post #3 of 9 (permalink) Old 04-20-2017, 11:00 PM Thread Starter
The mechanical fuel pump only supplies fuel to the fuel command center which has an electronic fuel pump in it then it goes to the throttle body.
lucasp likes this.
post #4 of 9 (permalink) Old 04-20-2017, 11:11 PM
LeeFred's Avatar
Didn't know that.
Anyways, it appears that the flared outlet on the 65 fuel pump fits into a 1/8-27 tapped hole in the body. Just remove the flared outlet, and put a 1/8-27 to -6AN adapter in its place. You can find the adapter all over the place...Jegs, Summit, eBay, etc.
LeeFred is offline
post #5 of 9 (permalink) Old 04-20-2017, 11:18 PM Thread Starter
Didn't know that.
Thanks, I didn't think to look on autozone or rockauto, didn't think they would list fitting sizes. Now I know!
post #6 of 9 (permalink) Old 04-20-2017, 11:54 PM Thread Starter
I take it that 1/8-27 is npt?
post #7 of 9 (permalink) Old 04-20-2017, 11:57 PM Thread Starter
Also, a lot of the pumps I see come with a brass fitting of some sort. Anyone know what size they are?
http://www.rockauto.com/en/moreinfo....nid=431&jpid=1
post #8 of 9 (permalink) Old 04-21-2017, 01:47 AM
LeeFred's Avatar
More Information for CARTER M4009
Don't know what the size of the brass fitting is, but just remove it and use the 1/8-27 to -6AN adapter in it's place. One less connection that you would have to worry about springing a leak. The fuel pump I saw on Napa had three fittings that the customer could use. There were two of the barbed fittings to attach a rubber hose onto, and there was the flared fitting that you see on the pump in the Rockauto link.
LeeFred is offline
post #9 of 9 (permalink) Old 04-21-2017, 06:46 AM
1/8"-27 is the tap size for 1/8" NPT or 1/8" pipe thread. I doubt 1/8" pipe is used on a fuel pump.
1/2"-20 is the straight thread size for the nut used on 5/16" flared tubing.
awhtx is offline
