Ran out of gas. - Vintage Mustang Forums
 1Likes
post #1 of 17 (permalink) Old 04-21-2017, 12:35 PM Thread Starter
Ran out of gas.
So I was trying to run my car down to less then 5 gallons since I have to replace the Fuel sending unit which is on its way here. I have a 67 Stang with the 16 gallon tank. I figured I would be getting at least 12-15mi/gal so around 192mi to the tank or more. But nope ran out of gas at 156mi from last fill to the top, so 9.75mi/gal. Should I be worried about gas mileage? I have a 289, 4v Edelbrock Performer intake, 600cfm Carter carb, Mild cam and a C-4 with 2.79 rear gears. I do mostly city driving not freeway. I read some past posts and people are getting 20mi/gal or more. I do feel my carb is running way too rich but wanted to get your folks thought.
my289 is online now
post #2 of 17 (permalink) Old 04-21-2017, 12:46 PM
69GT350H's Avatar
What do your plugs look like?
Reading 101: How to Read Your Spark Plugs - OnAllCylinders
1969 Shelby GT350 Hertz rebuild Gallery
Delivered to Ball Ford in Miami Florida, purchased by Hertz Rent A Car for delivery to Miami Internation Airport
69GT350H is online now
post #3 of 17 (permalink) Old 04-21-2017, 01:02 PM
zray's Avatar
Possible gas leak somewhere ??
Z
zray is online now
post #4 of 17 (permalink) Old 04-21-2017, 01:22 PM Thread Starter
Here is number 5 plug, number 1 looks the same. I have never seen a leak but possible.
my289 is online now
post #5 of 17 (permalink) Old 04-21-2017, 01:28 PM Thread Starter
Hmm picture is right side up but when I attached it, it put it sideways. Weird.
my289 is online now
post #6 of 17 (permalink) Old 04-21-2017, 02:02 PM
69GT350H's Avatar
The dark black ring at the base indicates that it is running just a little too rich. The strap looks a little rough. Possibly old plugs or bad ignition. The porcelain should be a light tan or light gray.
Last edited by 69GT350H; 04-21-2017 at 02:07 PM. Reason: Strap not as bad upon 2nd look.
post #7 of 17 (permalink) Old 04-21-2017, 02:03 PM
city driving=stop&go
mild cam=less mpg
C4=fewer mpg
2.79 rear = sluggish so you gas it more just to feel normal.
Idling even while coasting adds up
Did you slosh the tank and make sure it picked up 98% of the gas?
1ofAMillion+ is offline
post #8 of 17 (permalink) Old 04-21-2017, 02:07 PM
Maybe full is not really full.
331 solid flat cam, rings and bearings break in run up.
https://www.youtube.com/watch?v=3MNjb-AiWec
331 break in complete and is waiting on me to finish the body work
https://www.youtube.com/watch?v=YhnOk5FCBkE
macstang is offline
post #9 of 17 (permalink) Old 04-21-2017, 02:30 PM
zray's Avatar
Is the car kept in a garage ? If so, there will usually be at least a slight gas smell if not a strong one when there's a leak present.
Z
zray is online now
post #10 of 17 (permalink) Old 04-21-2017, 02:44 PM Thread Starter
Thanks guys. So to answer some of the questions. The plugs are about 3 years old. They are the Bosch Platinum DR8BPX, I usually only put 1-2k miles per year so at the most maybe 6k miles on the plugs. I can't find where I wrote down when I replaced them which I usually do. Ill check the tank once I get the sending unit to see how much gas was left but banging on it sounds pretty empty. It is garage kept, no smell of gas in there only when I turn it on smells a little rich. I did tune the carb idle screws to get the most vacuum which was about 12 last year. Timing is at 12 base, not sure if that matters.
my289 is online now
post #11 of 17 (permalink) Old 04-21-2017, 03:35 PM
69GT350H's Avatar
You might need to do a jet change, but running a little rich is better than running lean.
post #12 of 17 (permalink) Old 04-21-2017, 03:44 PM
4ocious's Avatar
Mostly city driving, eh?
So how much does
your right foot weigh?
gt350sr likes this.
68' Fastback 302 GT, 350hp,T5z, some mod's
Near total rebuild began 12/08 AND NOT DONE YET
Davy Crockett: "Be sure you're right then go ahead"
4ocious is offline
post #13 of 17 (permalink) Old 04-21-2017, 03:50 PM
gt350sr's Avatar
+1^^ I usually worry about my 'tire mileage' before my gas mileage! lol
Buckle up- I wanna try something!!
gt350sr is offline
post #14 of 17 (permalink) Old 04-21-2017, 04:51 PM
Rorin67's Avatar
Your gas mileage sounds a bit right for me, especially since you might be running a tad rich (better than a tad lean) and do mostly city driving. Don't worry about it at all.
Formula for a daily driver street fighter in Los Angeles:
'67 Fastback + Built 351W + T5 + 3.55:1 + LTs + 2.5" + 40s + TT2 17s
+ Shelby drop + CSRP + R&P + Bilsteins + SFCs + under riders + 22 Gal.
+ 3pts + 2nd Skin + MTF grille/lights + LEDs + SiriusXM
MTF Grille/Light Kit Install w/ Pics... & Engine Bay Pics...
As featured in Hot Rod Magazine tech article, May 2014
Rorin67 is offline
post #15 of 17 (permalink) Old 04-21-2017, 05:07 PM Thread Starter
Ok. Yeah I do have a heavy foot. My wife and kids say I drive too fast and I don't drive the 67 any differently then my other cars. Just wasn't sure if the 10mi/gallon was a cause for concern or not. I read some past posts about the Copper Autolite plugs being easier on the Ignition system. So maybe Ill go back to stock plugs to see if that helps and I can try a jet change to a leaner setting.
my289 is online now
