Engine ping sound - is it like a rattle on hard acceleration? - Vintage Mustang Forums
 1Likes
post #1 of 17 (permalink) Old 04-21-2017, 02:13 PM Thread Starter
Not sure I know what engine ping sounds like. tried a few youtube videos. Is the ping a sort of rattle sound the engine makes upon hard acceleration?
from other threads, once ping is heard, then adjust the timing back a few degrees, drive it again to duplicate the ping, if the ping is there, reduce timing back a couple degrees, drive it again, no ping - you've achieved the correct timing?
ddaytona1 is offline
post #2 of 17 (permalink) Old 04-21-2017, 02:20 PM
74Rallye's Avatar
Yes, spark knock generally sounds like a rattle from deep within the engine.
What octane gas are you using? What engine do you have? Stock engine?
74Rallye is offline
post #3 of 17 (permalink) Old 04-21-2017, 04:05 PM Thread Starter
289 hipo cam starting with 91 octane. just getting the timing straightened out.
post #4 of 17 (permalink) Old 04-21-2017, 04:31 PM
rbohm's Avatar
think of spark knock, or pinging, as some pebbles bouncing around in a tin can. and yes, back the timing off a couple of degrees and see if that stops it.
64 falcon
66 mustang
05 grand marquis
a man's fate is a man's fate
and life is but an illusion
fordsix.com admin
rbohm is online now
post #5 of 17 (permalink) Old 04-21-2017, 10:37 PM
Kelly_H's Avatar
I've never successfully been able to figure out what "pinging" sounds like. Everyone says that it sounds like rattling or tapping, but my engine is fairly loud and always sounds that way anyways, no matter what the timing is...
Woodchuck likes this.
Calamity Jane 1966 Modified Fastback - Driven semi-daily!
Wrecked and rebuilt even better
289 v8, 4-speed, 3.25 9" rear, goodies and stuff.
See my travel blog here for my adventures: http://calamityjaneroadtrip.blogspot.com/
2014: 10,051 mile, 2-month-long road trip around America
2015: 3,000 mile trip to Knotts in CA, CO to East Coast, an engine rebuild or two
2016: East Coast to TX, Hot August Nights, more trips to the East Coast
2017: Several long trips in the works! Stay tuned
Kelly_H is offline
post #6 of 17 (permalink) Old Yesterday, 12:35 AM
One disadvantage of loud pipes! You could blow the engine without hearing a big problem until it blows! Severe pinging can destroy a piston...not a good thing!
Modern computer control almost eliminates the problem if the sensors are working.
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is offline
post #7 of 17 (permalink) Old Yesterday, 01:13 AM
Tubbster1966's Avatar
Could pinging occur at a certain throttle position, regardless of speed? I get a noise like described only it's at 1/4 throttle street or highway speeds. But after I go past that point it goes away.
1966 Mustang Coupe, 289, 4v
Tubbster1966 is offline
post #8 of 17 (permalink) Old Yesterday, 01:35 AM
rbohm's Avatar
pinging usually happens at low speeds and high loads. i found in most cars i have had over the years, when they did ping it was between 35 and 55 mph.
64 falcon
66 mustang
05 grand marquis
fordsix.com admin
rbohm is online now
post #9 of 17 (permalink) Old Yesterday, 08:30 AM
dobrostang's Avatar
The owners manual for my old 57 triumph says listen for the ping and back off the thumbscrew on the timing a degree or two because gas back then across the world did not have a consistent octane, so you could have to lift the hood on a bad tank of gas and click the thumb screw a couple of clicks. You should hear it best under 3000 RPM e.g. 1500- 2500 under a good load. It does sound like marbles. Like Kelly, I have never heard it on my 351 with headers and flowmasters...
Heavy Metal Thunder Video http://www.youtube.com/watch?v=cW3L_O7N_xs
dobrostang is offline
post #10 of 17 (permalink) Old Yesterday, 09:41 AM
74Rallye's Avatar
I'll 2nd the comment about loud pipes masking the sounds you need to be listening for. If I run regular gas in my truck I get spark knock/pinging when accelerating. I would describe the sound as a barely noticeable clatter, not a pinging noise. It's subtle enough that a crapped out muffler would make it impossible to hear.
74Rallye is offline
post #11 of 17 (permalink) Old Yesterday, 10:03 AM Thread Starter
OK, I hear the sound of deep engine rattle or a can of muffled pebbles. Not sure where the word ping came from - since I'm expecting a high pitched noise, not a rattle.
Can the distributor be too far advanced as to cause a high idle? Seems not that I advanced it, the engine is running fast, adjusting the idle screw on the carb does nothing to change it.
Setting timing - by reading other threads, if the engine is stock, then the timing spec in the book applies. Any changes from stock - cam, intake, exhaust, all bets are sorta off and the timing setting is a "feel" kind of thing? find out where the pining occurs, and adjust from there? Different for every engine based on how it's built?
post #12 of 17 (permalink) Old Yesterday, 12:13 PM
If your idle is uncontrollable, you probably have a vacuum leak. Detonation can be caused by several things. The end result is a rattle sound that can damage pistons. It's not something you want to leave go on in your engine. You need to set your timing correctly, once you find your vacuum issue. Then if the rattle is still present, there are other things to check.
PetesPonies is offline
post #13 of 17 (permalink) Old Yesterday, 01:47 PM
creaky's Avatar
This is an excellent article which, among other things, explains detonation and pre-ignition.
Engine Basics: Detonation and Pre-Ignition by Allen W. Cline
Test drove a Mustang convertible in '65, bought one this year(2013)...I don't like to rush into things.
creaky is offline
post #14 of 17 (permalink) Old Yesterday, 04:00 PM
cahartley's Avatar
Pinging sounds a lot like a coffee percolator.
If the pinging begins at higher load it could be a failed head gasket between cylinders.
I know this from experience.
cahartley is offline
post #15 of 17 (permalink) Old Yesterday, 04:26 PM
It could be the vacuum advance if you have that plugged in, here is an article:
FORDMUSCLE webmagazine: Timing is Everything - Distributor Curving for Maximum Power
Quote "Remember vacuum advance is load dependent, so you cannot check it with a timing light with the car in neutral. The best way to set vacuum advance is by feel, under real driving conditions. Connect the vacuum line and drive the car up a steep, long grade, with the car in high gear and at a low speed, 30-40mph. Occasionally push the accelerator to the floor, and listen and feel for knocking and/or loss of power. If you detect this, immediately back of. This means the canister is advancing too much and you should adjust the canister so the diaphragm is 'tighter', by turning the screw counterclockwise."
Thats for an adjustable vacuum canister.
my289 is offline
