Removal of front springs... - Vintage Mustang Forums
post #1 of 27 (permalink) Old 04-08-2001, 12:34 PM
Posts: n/a
How tough a job is it to remove the front springs on a 66 Mustang and what kind or brand of spring compressor is the safest and most economical to use? Any other tips would be greatly appreciated. Thanks guys.
Shelby Man
post #2 of 27 (permalink) Old 04-08-2001, 01:04 PM
Sandy: I have had mine out and in a couple of times (it gets faster with practice). First, remove the shock out through the top of the shock tower (remove mounting nuts at bottom area of springs, and bolts at top of shock tower) The type of compressor that I use looks like a couple of bent fingers on the top and the same on the bottom (but facing each other) with a long screw connecting them. With the wheel off, support the weight of the car under the lower control arm, hook the "fingers" over the coils, near the top and bottom, on each side (opposite each other, one front and one at rear) and start screwing the "fingers" together. It will take a while so take your time, and remember that there is a lot of stored energy in those compressed springs and will do a lot of damage if they pop out of the compressor. When they are compressed enough, you can lift the spring up, tilt the bottom towards you, and out she comes. If I forgot anything, please read the other posters and follow their suggestions. Good luck and be SAFE. Mark
Mark_Hone is offline
post #3 of 27 (permalink) Old 04-08-2001, 01:42 PM
Richelieu's Avatar
That's exactly the same spring compressor type and way I got mine out of my '66.
Just make sure all of the fingers are kinda wrapped around the spring. You'll notice
that they might not get all over. It's like getting a straight line to hit perfectly on a
curved line. You'll be off just a bit on either end. Also, make sure the clamps are as
close to straight across from each other as possible. If not, you'll find that the spring
will start to angle in that direction.
Rich
'66, 302-4bbl, Granada disk brakes, etc, etc...
Rich
'66 Mustang, 302, front chin spoiler, R-model valance, '67 style Shelby hood, custom trunk and console.
Richelieu is offline
post #4 of 27 (permalink) Old 04-08-2001, 02:49 PM
Go HERE to see 2 pics of the spring compressor in 'action'. Since the bolthead is facing down, I used a long box-end(closed end..?) wrench to turn the bolt....
This is how I did it on my 68...Piece of cake once you figure out how those finger things work...
Good luck...
RJ
68 Diamond Blue Coupe
Sprint Promotion A
289 2bbl with a C4
College Station, TX
Click Here For Home Page
Edited by bluebeast on 04/08/01 12:54 PM (server time).
RJ
I used to have a vintage Mustang, but I sold it in May 2002. Now I lurk in the VMF shadows trying to keep up with the Mustang world...
Currently I own a Blue 2007 Mustang GT...
Newburgh, NY
Home Page
bluebeast is offline
post #5 of 27 (permalink) Old 04-08-2001, 04:09 PM
also use oil on the screw so that it turns easily
My son got me into this and I'm having a ball
65 fastback, 289, 3 speed, Holly 1850, Edelbrock intake. SSB front disks in a box, Canadian Mustang "real big kit" suspension in alot of boxes,
Right now lots of boxes!!
65 Fastback,289,holley 1850,Edlelbrock performer 289,Power heads,T-5 z series,8"2.80 rear,Canadian Mustang "Real Big Kit",Fuel Safe fuel cell,70 highback seats,SSB dual MC front disks, Stainless steel brakelines,pertronix points/coil,3 row radiator.
DMORRISON is offline
post #6 of 27 (permalink) Old 04-08-2001, 04:26 PM
I've changed spring sets three times. It's really scary the first time and not much less scary on the second and third times. When changing springs, it always seems most dangerous when relaxing the spring to remove the compressor when it's not on the car. I admit the part I dislike the most is getting my fingers into the spring to get the compressor springs into usable positions.
My question: Has anyone made and used the spring compressor described in the Tony Branda catalog
Russ
G1967T is offline
post #7 of 27 (permalink) Old 04-08-2001, 07:22 PM
Tip #2 on this sheet is a spring compressor that looks much easier to use that an internal compressor. Anybody tried this?
Russ
G1967T is offline
post #8 of 27 (permalink) Old 04-08-2001, 08:44 PM
Supporting Vendor
Opentracker's Avatar
The tools in the diagram are for holding the spring
while you replace or rebuild the upper a-arm, or do
the Shelby mod to the shock towers. Don't
try to remove the spring with these home made tools.
Proud VMF Sponsor
Vintage Mustang Suspension
www.opentrackerracingproducts.com
Opentracker is offline
post #9 of 27 (permalink) Old 04-09-2001, 09:42 AM
Send a message via Yahoo to Dees67
If you have a VIP Auto Parts nearby, they can loan you exactly
that kind of spring compressor. They will put a temporary
charge of $50 on your card, and then cancel the charge when
you return the tool so it ends up a free rental. I've done this
a couple of times and it's a great deal.
Rich
'67 C-code 'vert (Dees67)
'69 GT FB (project car)
Milford, NH
Check out my band: Brickyard Blues
Rich
Milford, NH
'67 Vert, '66 Fairlane 500XL
Dees67 is offline
post #10 of 27 (permalink) Old 04-09-2001, 11:39 AM
Posts: n/a
I haven't had much success with removing front coil springs on my mustangs (65 and 66), either. I rented one of those "finger" type compressors. I tried to put it in with the bolt head pointing up, but that didn't work because the other end interfered with the perch. When I flipped it the other way, I couldn't get a wrench on the bolt head. I finally gave up and still have yet to install my springs (car on rotisserie). The Ford Mustang shop manual shows some "tower" style spring remover which is kind of like the Branda one. I've even considered building my own spring compressor. Maybe I'll just buy the "finger" style and try it again..........
post #11 of 27 (permalink) Old 06-22-2010, 02:04 PM
I just purchased a finger-type spring compressor from CJPonyParts. I had previously purchased the two independent types, which I used to remove the springs, but I didn't like how the thread end of the bolts scratched up the sheetmetal and the compressors moved toward each other as you tightened them, causing the springs to bow. But how the heck to I get the finger-type to tighten enough to get the spring in place AND get a tool in to loosen the bolt. This is the biggest challenged I've faced on my 66 coupe. ANY help would be most appreciated.
REOakes is offline
post #12 of 27 (permalink) Old 06-22-2010, 02:55 PM
65-73 Mustang Shelby Falcon Coil Spring Compressor: eBay Motors (item 260483510437 end time Jun-25-10 07:06:26 PDT)
This one works great. Falcon 15 is a VMF member. Once you compress it you can loosen or remove you LCA and uncompress to remove. Piece of cake, I tried renting one from Auto Zone and took it back and bought this
http://i569.photobucket.com/albums/s...ps563b40b4.jpg
Front 235/45/17 tire on a 17x8 rim. 4.75 BS
Rear 275/40/17 tire on a 17x9.5 rim 5.0 BS
The rear end is narrowed 1 inch on each side so for a stock mustang that would be 6.0 BS in the rear.
Mustangs to Fear interior.
New 410 Stroked Windsor from DSS Racing
Top Loader 4 Speed
New Currie 9 inch Tru Trac 3.25 rear.
Anything is for sale including this car.
BADCRUZ68 is offline
post #13 of 27 (permalink) Old 06-22-2010, 05:19 PM
i used to struggle with my finger type until i welded a nut on the end with no nut and problem solved. it works like a charm with no problems. wes
mustang656man is offline
post #14 of 27 (permalink) Old 06-22-2010, 05:31 PM
mikemstang66's Avatar
if your replacing the springs and have a torch heat them up till they sag , then just pull them out after they cool no compressor needed and no worrys of a flying spring .
the replacement performance springs are a lot shorter and drop right in .
1966 convert
mikemstang66 is offline
post #15 of 27 (permalink) Old 06-22-2010, 06:18 PM
Doesn't that effect the spring rate?
I've heard of people loosening the lower control arm and getting them out without a compressor, but it sounds iffy to me.
1969 Coupe Restomod...in progress http://www.1969stang.com/mustang/for...ead.php?t=8156
2011 V6 Grabber Blue...let the mods begin!
2008 Power Wheels Mustang Bullitt Conversion!
Past Mustangs: '66 Coupe, '69 Coupe, '69 Grande, 2001 Bullitt
rangerdoc is offline
