speedometer cable lube - Vintage Mustang Forums
post #1 of 3 (permalink) Old 05-31-2001, 02:47 AM Thread Starter
I'm going to replace my speedo cable...instructions say to pull out the metal cable inside, lube it, and put it back in outside cable and install in car...how do you pull it out? Just take needle nose pliers a yank? am I going to break something doing it this way? and putting it back in, is it hard, easy? I'm sure it's a long process, but am I going to kink the inside cable putting it back in? Any advice would be appreciated...a few more weeks and this car should be top notch mechanically and I can start working on the body!! Guy(NH)
'69 Mustang Grande
351W - 2v - FMX - dual exh
'69 Ford Mustang Grande, 351W, FMX
Guy_NH is offline
post #2 of 3 (permalink) Old 05-31-2001, 08:49 AM
Posts: n/a
You should be able to just pull the speedo cable from the dashboard end. Lightly lube it, then reinstall. Your going to hit some snags, so be patient. Also, twisting the cable as you put it back into the sleeve should help.
Don't forget to replace the speedo gear. It's a plastic piece that is prone to wear.
Matt
65 Blue, A Code 2+2
post #3 of 3 (permalink) Old 06-02-2001, 04:37 AM
I have used "lubriplate" on any cables i have pulled.
Shaune
Keep your stick on the ice
67 GTA 390 F/B underconstruction
79 F100 very rusty but mine
92 grand caravan...family wheels
Shaune
Some have the touch....others just the hand. (Lynyrd Skynyrd)
68 C code convert....a driver
88 mustang, low miles, 4 banger
52 Plymouth...SWMBO's ride
52 F100 truck...project 428
laynrubber is offline
