Battery in trunk, bat disconnect switch NHRA - Vintage Mustang Forums
post #1 of 9 (permalink) Old 12-04-2001, 01:00 PM Thread Starter
I relocated my battery in the trunk, but, in order to drag the car, I have to have a battery disconnect switch located on the back of the car which will kill the car when you disconnect the positive battery cable. This cannot work with stock 3-wire alternator, as the power for the alternator goes directly to the starter solenoid. When the car is running, you can totally disconnect the battery from the car, it will stay running, I know because I tried it.
With a 1-wire alternator, it will work because the alternator connects directly to the battery, not the starter solenoid. With the mustang, if I disconnect the power wire from the alternator to the solenoid, I can then start the car and run it off the battery, and then disconnect the battery to kill the car. Obviously, I cannot run the car like this as the battery would not be able to run the car very long without being recharged. I don't know if I can run the wire from the alternator all the way back and connect it directly to the battery or not, plus, I don't want to do this.
Does anybody know of any other solutions, or what other people are doing?
69 Mach 1, 393 EFI Stroker, AODE
alaroque is offline
post #2 of 9 (permalink) Old 12-04-2001, 01:11 PM
Midlife's Avatar
Disconnecting the negative side of the battery should do the trick.
'Electrical Guru: Let me Check Your Shorts! Ooops...that didn't turn out right.
http://midlife66.com/harnesses
http://midlifeharness.com
Midlife is offline
post #3 of 9 (permalink) Old 12-04-2001, 01:31 PM Thread Starter
If your talking about with the stock setup, it doesn't, I tried. The alternator is supplying all the power to the motor once its started, I totally disconnected the battery from the car, I could have taken it out of the trunk, and the car still runs and drives fine.
alaroque is offline
post #4 of 9 (permalink) Old 12-04-2001, 01:37 PM
Not an electrician, so can't help much, but, i have seen lots of relocated batterys and they sometimes move the solinoid to trunk next to the battery. Maybe this will help.....
If you are going to be dumb, you got to be tough.
'70 Mustang Fastback,460 powered
(SC)
[image]http://www.southernmustangandford.com/IMG_3807.JPG[image]
fordnut is offline
post #5 of 9 (permalink) Old 12-04-2001, 02:06 PM
gt350clone's Avatar
HERE YOU GO. It's called a shutdown relay:
"Even with your master disconnect turned off, your engine may continue to run due to alternator feed back. This relay is installed between the alternator and the battery. When the master disconnect is switched off, the relay is de-energized and stops current flow to the ignition system. Includes all hardware and installation instructions.
If the above link doesn't work - go to http://www.jegs.com and look at part # 764-50103. It's made by Painless Wiring and runs $37.99.
Ye old 65 Clone - www.gt350clone.com (Car & Tech Pages)
The young stud - www.MySaleen.com
gt350clone is offline
post #6 of 9 (permalink) Old 12-04-2001, 03:14 PM Thread Starter
Just a question though, will this work for a non 1-wire alternator such as a stock ford mustang one. I can see how this would work for a 1-wire alternator which connects directly to the battery, but with the stock ford alternator, it does not hook up to the battery, it hooks up to the starter solenoid. Would this device then be installed between the alternator and the starter solenoid? If you are not sure, I can call Painless Tech line if they have one and ask them.
alaroque is offline
post #7 of 9 (permalink) Old 12-04-2001, 03:44 PM
gt350clone's Avatar
My understanding is that it installs in the "hot" line from the alternator. You can contact them to verify:
800-423-9696
tech@painlessperformance.com
post #8 of 9 (permalink) Old 12-04-2001, 08:05 PM
Send a message via Yahoo to Hottarod
I ran a 6 gauge wire from the switched side of my battery disconnect(the battery post side) up to the alternator wire that used to go to the solenoid and junctioned the two wires together. I think that will shut it all off. The basic situation is that you have to isolate the alternator charge wire from the rest of your electrical system or the alternator will carry enough current on the charge circuit to keep the motor running through feed back.
Sheila, 1965 289 mustang 2 + 2
Hottarod is offline
post #9 of 9 (permalink) Old 12-04-2001, 09:46 PM Thread Starter
That is what I was planning to do, I was still wondering if it would charge the battery, and I can't see why it would not. Thanks for confirming for me it can be done and all works OK.
alaroque is offline
