1968 Manual Disk Brake Master Cylinder - Vintage Mustang Forums
post #1 of 8 (permalink) Old 09-24-2002, 09:22 PM Thread Starter
What type of master cylinder should I use when upgrading to manual disk brakes from drums (1968). I looked at Autozone site for a 68 manual disk master cylinder and they don't show one? Another parts store also could not find one and Mustangs Unlimited catalog doesn't show one either, just the power brake MC. Is their such a part or are the drum and disk MC interchangable? If I use a 74 Maverick MC will I be able to use my existing rod?
See my T-5 hydraulic clutch setup at: Hyd. Clutch
See my T-5 cross member fabrication at: Cross member
See my 140HP and 180HP Turbo Festivas at: Festivas
mattswabb is offline
post #2 of 8 (permalink) Old 09-24-2002, 09:38 PM
Posts: n/a
I used the 74 Mav. Use the 68 rod.
post #3 of 8 (permalink) Old 09-24-2002, 09:45 PM
Posts: n/a
the reason nobody shows one is because manual disc brakes weren't an option.
post #4 of 8 (permalink) Old 09-24-2002, 10:34 PM
Use a 69-70 power brake master cylinder. Bore should be smaller than 1 inch and with correct manual brake pedal they work but not as good as a power disc brake set up Gary
66 A Code Coupe
66 T Code Coupe
63 Falcon V8 Ranchero
Gary6768 is offline
post #5 of 8 (permalink) Old 09-24-2002, 10:35 PM
Do you have to change out the master cylinder? Why can't you just leave the Manual MC that is there in place?
The needs of the many outwiegh the needs of the few, Saddam!
msgjvh is offline
post #6 of 8 (permalink) Old 09-24-2002, 10:50 PM
Posts: n/a
You need more fluid to move those big disk brake pistons!
post #7 of 8 (permalink) Old 09-25-2002, 01:02 AM
Just some guy
GypsyR's Avatar
You can, but the end result is that the car won't even begin to stop until the pedal is almost to the floor. This tends to cause soiled underwear (and other accidents).
.... it wouldn't be the first time reality took theory and conjecture out behind the woodshed and gave them a good thrashing.
GypsyR is offline
post #8 of 8 (permalink) Old 09-25-2002, 07:44 AM
I don't know for sure but Mav MC doesn't have any larger bowls or piston diameter. Aftermarket MC might be needed if you have aftermarket saddles. However, if you use larger piston bore MC, the brake pressure will decrease unless you change your pedal to piston rod -ratio.
Oversized sig pics nobis delenda est. No need for that anymore, I found Hide avatar choice.
Arto65FB is offline
