A-code versus C-code, what's the difference?.... - Vintage Mustang Forums
post #1 of 6 (permalink) Old 12-15-2002, 12:39 PM Thread Starter
After searching but having no luck, I've decide to ask. What exactly is the difference between a '65-'66 A-code engine and a C-code engine. I've been told its just the bigger carb. If this is true, would a C-code with aftermarket 4 barrel carb and intake be superior in performance to an original A-code?
[color:"blue"]1966 289 C-4 Restomod Coupe[/color]<img src="/forums/images/graemlins/cool.gif" alt="" />
Earls66 is offline
post #2 of 6 (permalink) Old 12-15-2002, 12:42 PM
C code had dished pistons for a 9.3 to 1 compression ratio. A code had flat top pistons for 10 to 1. 4 barrel intake and Autolite 480 cfm 4 barrel carb on the A code.
If I recall correctly, everything else is identical.
1966 Ford Mustang Coupe, 289 C code originally. 1995 5.0L, B303, Weiand Stealth, Edelbrock 1405, MSD Pro Billet/MSD 6A, JBA Ceramic Shorties, 2.5" 2 chambers with H pipe, C4 auto, 3.00 open 8"
plessm is offline
post #3 of 6 (permalink) Old 12-15-2002, 12:49 PM Thread Starter
Thanks for the fast reply! I've heard of a HP difference between a 2V and a 4V carb but what kind of HP difference would the different pistons create if any?
Earls66 is offline
post #4 of 6 (permalink) Old 12-15-2002, 01:25 PM
The C code was rated at 200hp
The A code was rated at 225hp
Higher compression always adds to the horsepower
Paul
1965 Mustang 2+2
1968 Mustang California Special
pprince is offline
post #5 of 6 (permalink) Old 12-15-2002, 01:28 PM
IIRC, the C-coder was rated at 200 HP and the A-coder at 225 HP....
Based on my observations with performance engines, that's a reasonable increase to expect from a carb/ C/R change. Manifold, although 4V, is somewhat limiting in design. An aftermarket aluminum manifold could add another 10 peak HP with the same carb.
http://forums.vintage-mustang.com/signaturepics/xsigpic18756_2.gif.pagespeed.ic.3vzsIY6Mah.jpg
Visit my VMF lingo page
Visit the Ford engine torque specs page
Visit my MySpace Blog
camachinist is offline
post #6 of 6 (permalink) Old 12-16-2002, 08:31 PM
One other important distiction is this: The GT models in 65, 66 & 67 had at least A code 289's, No C code Gt's were built those years. But I bet a lot of C codes have been converted to GT's, whether the current owner want to admit it or not
Roddster
67 GT 350: MCA & SAAC Gold winner
67 S code GTA coupe
Roddster is offline
