A-code versus C-code, what's the difference?.... - Vintage Mustang Forums
Old 12-15-2002, 12:39 PM   #1 (permalink)
After searching but having no luck, I've decide to ask. What exactly is the difference between a '65-'66 A-code engine and a C-code engine. I've been told its just the bigger carb. If this is true, would a C-code with aftermarket 4 barrel carb and intake be superior in performance to an original A-code?
[color:"blue"]1966 289 C-4 Restomod Coupe[/color]<img src="/forums/images/graemlins/cool.gif" alt="" />
http://members.aol.com/earlbolanos/images/vmf%20pic.gif
Earls66 is offline   Reply With Quote Quick reply to this message
Old 12-15-2002, 12:42 PM   #2 (permalink)
C code had dished pistons for a 9.3 to 1 compression ratio. A code had flat top pistons for 10 to 1. 4 barrel intake and Autolite 480 cfm 4 barrel carb on the A code.
If I recall correctly, everything else is identical.
1966 Ford Mustang Coupe, 289 C code originally. 1995 5.0L, B303, Weiand Stealth, Edelbrock 1405, MSD Pro Billet/MSD 6A, JBA Ceramic Shorties, 2.5" 2 chambers with H pipe, C4 auto, 3.00 open 8"
plessm is offline   Reply With Quote Quick reply to this message
Old 12-15-2002, 12:49 PM   #3 (permalink)
Thanks for the fast reply! I've heard of a HP difference between a 2V and a 4V carb but what kind of HP difference would the different pistons create if any?
Old 12-15-2002, 01:25 PM   #4 (permalink)
The C code was rated at 200hp
The A code was rated at 225hp
Higher compression always adds to the horsepower
Paul
1965 Mustang 2+2
pprince is offline   Reply With Quote Quick reply to this message
Old 12-15-2002, 01:28 PM   #5 (permalink)
Send a message via ICQ to camachinist Send a message via AIM to camachinist Send a message via Yahoo to camachinist
IIRC, the C-coder was rated at 200 HP and the A-coder at 225 HP....
Based on my observations with performance engines, that's a reasonable increase to expect from a carb/ C/R change. Manifold, although 4V, is somewhat limiting in design. An aftermarket aluminum manifold could add another 10 peak HP with the same carb.
http://forums.vintage-mustang.com/signaturepics/xsigpic18756_2.gif.pagespeed.ic.3vzsIY6Mah.jpg
Visit my VMF lingo page
Visit the Ford engine torque specs page
Visit my MySpace Blog
camachinist is offline   Reply With Quote Quick reply to this message
Old 12-16-2002, 08:31 PM   #6 (permalink)
One other important distiction is this: The GT models in 65, 66 & 67 had at least A code 289's, No C code Gt's were built those years. But I bet a lot of C codes have been converted to GT's, whether the current owner want to admit it or not
Roddster
67 GT 350 (#0036)("Miss July" 2004) owned since 1971. And I still drive it...SAAC 29 Concours GOLD, Div II, MCA Concours Trailered Gold 2X,
Also: 67 GTA S code COUPE (under construction)
General Shelby and Mustang enthusiast, MCA certified Concours judge
Roddster is offline   Reply With Quote Quick reply to this message
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
