69 Instrument Panel Lights Not Working!! - Vintage Mustang Forums
post #1 of 10 (permalink) Old 05-08-2003, 02:43 AM
Posts: n/a
since i've recently put the battery into my car, i've been checking for lights and whatnot to be working. However the lights inside the instrument panel will not come on, same with the heater bezel illumination.
The clock works, the map light works, dome light works, ignition switch light works, but the instrument panel & heater bezel lights do not. I replaced the fuse that runs the bulbs in the fuse box, but that didnt solve my problem.
since there are so many bulbs inside the instrument panel, i find it hard to believe that they are all burnt out, so i'm thinkng that i'm missing a ground somewhere. I have a wiring schematic, and I see two grounds, one on the actual instrument panel, and then one off of the plug that goes into the panel itself, but as far as I can tell that is grounded...
also, all of the gauges inside the panel work...
any ideas?
post #2 of 10 (permalink) Old 05-08-2003, 06:26 AM
Posts: n/a
What car? We have no idea of what you are talking about because you haven't filled out your bio.
post #3 of 10 (permalink) Old 05-08-2003, 07:46 AM
abadtb2's Avatar
Since all 69's had the same dash, only difference being Tach Dash or not I would guess he's talking about his Mustang. This is a Mustang related post, that's why your having trouble Glen.
With my 70 I know that when I pull my headlight switch on and it doesn't sit in the exact right position my dash lights don't light up. Just a little wiggle/repositioning of the switch and on they come. Might check there and see if your not having the same problem with the contact in your switch, yours may not be making contact at all. Just a thought.
Mark Brown/San Diego
abadtb2 is offline
post #4 of 10 (permalink) Old 05-08-2003, 08:36 AM
While we are on the subject, The dash lights for my 69 Mach are some what dim, I am told there are bulbs with higher wattage, is that a good idea ?
Maybe I also have a bad switch ?
Gary B
If It Ant Broken You Aren't Trying Hard Enough ( Red Green )
Duct Tape has Replaced The Dog As Mans Best Friend. Just Ask Red Green
http://www.myrestorationprojects.com
69 Mach 1 ( Molly )
68 Gmc short box 4x4
67 Triumph 650 Motorcycle Being Restored
plumbit is offline
post #5 of 10 (permalink) Old 05-08-2003, 08:40 AM
I have to say I have a bit of the same attitude as Glen here, we have a whole bunch of newbies and for some unknown reason they refuse to fill out any information and think we are able to read minds ! It sure would be a little helpfull if they would all give us a little more info.
Gary B
69 Mach 1 ( Molly )
plumbit is offline
post #6 of 10 (permalink) Old 05-08-2003, 08:54 AM
abadtb2's Avatar
I also agree, Bois should be filled out to help with answering posts that forget to mention what type of Mustang is being referred to. In this case though it's not that tuff.
abadtb2 is offline
post #7 of 10 (permalink) Old 05-08-2003, 08:55 AM
manyc's Avatar
The dash and heater lights are on a rheostat that is part of the headlight switch. To win the Doofus award you would have to have the lights dimmed all the way down and not know that this is your problem. I'm sure you know about the dimmer and that you will not win the award.
It is possible that there is corosion on the contacts or that the rheostat is bad. You will have to take the headlight switch out to test it. To remove it you will have to first take out the knob. This is done by holding done the button on the side of the switch, under the dash, and pulling the knob & shaft out. Then you remove the bezel with a big flat blade screw driver. The rheostat portion is
the big spring looking thing on the front.
"If I can't fix it, I'll fix it so no one can !"
1969 Mustang LE600 Sportsroof - Groovy Green
1969 Mustang LE600 Coupe - Flower Power Red
1969 Mustang Sportsroof - Dark Jade
1969 Firebird 350 Conv - Mayfair Maze
1968 Cougar Hertz XR7-G (project)
1959 Oldsmobile Super 88
1963 Jaguar XKE Coupe (project)
[url=http://www.relicrecyclery.com/groovygreen/groovygreen.htm]
[url=http://www.relicrecyclery.com/]
manyc is offline
post #8 of 10 (permalink) Old 05-08-2003, 09:00 AM
I may have a bad switch , I know you have to turn the knob all the way for brighter lite's
Gary B
69 Mach 1 ( Molly )
plumbit is offline
post #9 of 10 (permalink) Old 05-08-2003, 10:04 AM
arh69fastback's Avatar
It also helps to know the dash lights brighten when you turn the knob counter-clockwise rather than clockwise (seems the wrong way round to me, and had me fooled at first)
mustangbooks.com - Mustang books, gift items and restoration parts for the UK and Europe.
facebook page
eBay store (UK & Europe only!)
arh69fastback is offline
post #10 of 10 (permalink) Old 05-08-2003, 03:11 PM
Gone but never forgetten
johnpro's Avatar
I would suspect a bad headlight switch as well. The '69 dash has a built in ground (part of the big plug), unlike the previous years that had a seperate wire run from a dash pillar to the CVR mounting bolt.
Do the gauges work? (may be hard to tell if the car isn't yet running). This would tell if the ground is good. If the gauges also don't work, I'd suspect a the ground wire is broken, the plug isn't plugged in well, or there's a problem with the dash circuit board itself.
VMF Jedi Knight who's spirit will be with us forever.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
johnpro is offline
