65/6 steering column removal - is it this easy? - Vintage Mustang Forums
post #1 of 5 (permalink) Old 05-10-2003, 10:16 AM Thread Starter
68COUPE's Avatar
I will be pulling the column out of my 65 coupe for dash and column restoration. According to Dobbs and Farr in "How to Restore Your Mustang" removal is as follows:
Disconect horn and turn signal wiring under dash
Unscrew and remove turnsignal shaft
Remove bracket that attaches column to dash and pull the column out
Thats it? I suppose re-installation is just as easy, but in reverse?
Seems too easy.
Thanks.
65 289 Holley 4160, F4B, Doug's Tri-Y Headers, 3.25 T-loc, coupe (father, son and daughter project)
64 1/2 coupe 289 4v, D-code (looong term puzzle)
64 1/2 conv 289 4v, D-code (long gone)
68 289 2v sprint 'B' coupe - Bone Stock (Holley 4412, 500 cfm 2v) SOLD, gonna miss that one.
68COUPE is offline
post #2 of 5 (permalink) Old 05-10-2003, 10:30 AM
Poppy65's Avatar
You have to remove the steering wheel and horn too. You will need to buy or rent a steering wheel puller to do that job.. very simple job to do.. you may have to give the tube a little tug..sometimes the rubber seal a the bottom can give you a little problem.
Chris Hunter
65 A-Code Convertible
My game site http://www.toadgames.com
Poppy65 is offline
post #3 of 5 (permalink) Old 05-10-2003, 10:44 AM
Myopic
Yes it is that easy to remove the column once you removed the steering wheel.
1965 Fastback 410c AOD - DT
1967 Fastback 347 T5- Cruiser
1968 Fastback 408w T5 - Brute
1991 GT Hatch - Fauxbra
1996 Dodge Viper GTS
https://www.youtube.com/watch?v=0LUK2D0GjdY
dodgestang is offline
post #4 of 5 (permalink) Old 05-10-2003, 01:34 PM
autoxsteve's Avatar
Add Rally Pac if you have one of those. You do, don't you?!?
Links-R-Us...
Steve Leslie, 65 cpe, 302, toploader, A/C, orig disc brakes, bench seat, tri-bars, tri-Ys, I need tri-power! 356,000 miles (4/12/2010)
1965 Ford Mustang - All Weather Fighter
autoxsteve is offline
post #5 of 5 (permalink) Old 05-10-2003, 04:45 PM Thread Starter
68COUPE's Avatar
several ::
Thanks for the re-assurance on the removal.
68COUPE is offline
