Motor Mounts - 69 Mach1 - Vintage Mustang Forums
Old 06-20-2003, 09:39 PM   #1 (permalink)
What are the correct motor mounts for a 69 Mach 1 with a 351W?
Are there more than one type available? Where can I purchase them?
How difficult are they to install?
Thanks,
Mordi
1969 Mach 1
Black Jade
351W
C6 Transmission
mordi is offline   Reply With Quote
Old 06-20-2003, 10:13 PM   #2 (permalink)
Hemikiller's Avatar
No, just one type, same on both sides. Anchor # is 2287. Your local parts store should have them on the shelf, they were used in many many different vehicles.
Installation is as simple as removing one through bolt, jack the motor up, unbolt from engine block, install new mount, lower, insert through bolt, repeat for other side and tighten through bolts when finished. Just use a block of wood under the pan when jacking the motor, or better yet, use and engine hoist....
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline   Reply With Quote
Old 06-20-2003, 10:32 PM   #3 (permalink)
Hemikiller,
Thanks for the info.
How can I tell if the mounts are indeed worn? My transmssion lines are very close to my fan blades and I am guessing the problem is the mounts?
Thanks,
Mordi
1969 Mach 1
Black Jade
351W
C6 Transmission
Old 06-20-2003, 11:44 PM   #4 (permalink)
This is a little something that I discovered when installing mine...Click on Tips below...
Motor Mount Install Tips
Classic Mustang owner for 28 years.
70_DropTop is offline   Reply With Quote
Old 06-20-2003, 11:53 PM   #5 (permalink)
Cool tip!
So, how long does it take to change the mounts?
Thanks,
Mordi
1969 Mach 1
Black Jade
351W
C6 Transmission
Old 06-20-2003, 11:59 PM   #6 (permalink)
Less than an hour even if you take your time. (Providing all goes well)
Scott
