Should I use gasket sealant on both sides of oil pan gasket? - Vintage Mustang Forums
post #1 of 12 (permalink) Old 08-13-2003, 06:57 PM Thread Starter
Dumb question, but wanna make sure to get this right ::
66Replica is offline
post #2 of 12 (permalink) Old 08-13-2003, 07:29 PM
RTM
RTM's Avatar
I am not big on the silicon gasket sealer. I like to use #2 permatex sealer. It's a black sealer that doesn't harden.
For oil pans and valve covers I like to use weather strip adhesive on the gasket for the oil pan or the valve covers and then very little #2 on the other side.
The weather strip adhesive does two things. It keeps the gasket in place while you close it up and for the valve cover it making it easier to clean and replace later. The gasket is stuck to the valve cover not the head.
I do the same thing on the timing cover gasket as well.
1965 fastback
RTM is offline
post #3 of 12 (permalink) Old 08-13-2003, 08:24 PM
Ive always used a thin bead.....but there are some permatex spray on gasket sealers that look like they would reduce the chances of excessive sealer
Ported vacuum IS manifold vacuum ANYTIME the throttle is open on a holley.
sharkmouth is offline
post #4 of 12 (permalink) Old 08-13-2003, 08:26 PM
yelostang's Avatar
No.2 Permatex is getting hard to find. Still use that stuff for watrerpumps, timing covers, pans, etc. etc. Never get leaks with it.
yelostang is offline
post #5 of 12 (permalink) Old 08-13-2003, 08:27 PM
67gt's Avatar
Typically, the purpose of any gasket is to prevent leakage, and (most) are designed to be used without any "sealant" at all.
"Gasket sealant" is an extra measure used to ensure no leakage. As a rule of thumb, when I want (or it requires) extra sealant, I always will use the sealant ONLY on the part that can be removed from the block . . .
i.e. On your oil pan, I would seal the gasket to the pan, and not apply any sealant to the block. That way, if there's a leak, or whenever I need to remove the oil pan, the gasket isn't sealed to the block which makes removal of the pan and any subsequent gasket work a lot easier because the gasket is sealed to the removable part, and not the block. (Ever try scraping off an old oil pan gasket off the underside of the block while it's still in the car??)
Hope this makes sense,
Rick
'67 390 GT Coupe
[color:"red"]*Click on the pic for more info about the car and pictures on my website!*[/color]
"Yesterday, the bottom fell out of my world, so I drank 8 pints of Felinfoel Ale and this morning, the world fell out of my bottom." -Haydn Croft
67gt is offline
post #6 of 12 (permalink) Old 08-13-2003, 10:30 PM
Gone but never forgetten
johnpro's Avatar
There's no need for gasket glue on an oil pan gasket. I will put a few dabs on the BLOCK side, just to hold the gasket in place while intalling the pan.
I do, however, put a big blob of sealant in each of the 4 corners where the cork gasket meets the rubber one.
VMF Jedi Knight who's spirit will be with us forever.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
johnpro is offline
post #7 of 12 (permalink) Old 08-13-2003, 11:20 PM
*raises hand* , I HAVE scraped gasket material off the underside of my block while its in the car. PO obviously put alot of sealer on the block itself.. when i removed the oil pan , the gasket basically was 100% glued to the block itself... to me, the worst part of my melling hv install was the gasket removal from the block, not only was it super time consuming and slow going but, i got SO MUCH debris and gunk all over myself in the process.. NEVER AGAIN, i hope.
66 coupe,289,C4,Edelbrock cam,weiand stealth,edelbrock carb, Pertronix,3.55 gears-detroit locker,3"cowl hood,Hedman headers, 2.5" X pipe exhaust going out 2 chamber flows,front and rear sway bars, Eibach springs,KYB's, traction bars.91GT bucket seats,CD player, power locks and alarm. daily driven! http://www.angelfire.com/rock3/66stanger-01GT,5spd,cobra body kit,mineral gray.
Restomod66 is offline
post #8 of 12 (permalink) Old 08-13-2003, 11:35 PM Thread Starter
I already scraped it off the underside :: So i know how that goes!
post #9 of 12 (permalink) Old 08-14-2003, 12:44 AM
Posts: n/a
Now just how many times do you have to scrape gaskets off an engine if you do it right the first time? I listened to guys like you when I built my GTO, and it ended up leaking. I listened to you guys when I built my GMC, and it leaked. I sealed it up tight with permatex #2 on my Mustang, and guess what? No leaks. So build your engine right, and seal it up tight. You'll thank me for it.
post #10 of 12 (permalink) Old 08-14-2003, 04:09 AM
johnpro's Avatar
You listened to guys like who? US? ME?
Sorry, but I take offense in that. We offer up our advice to help others. You don't have to take our advice, but you don't have to slam us for giving it either. I've never had a pan gasket leak in all the engines I've built in 27 years of working on cars ... because I've done them ALL right the first time.
johnpro is offline
post #11 of 12 (permalink) Old 08-14-2003, 12:47 PM
kvinkler's Avatar
I support johnpro on this.
By the way I never use a sealer on the block side on my racing engines and never had a leak either.
Kevin
69'Elvira 357W/400HP
Restomod
http://www.geocities.com/kvinkler/
kvinkler is offline
post #12 of 12 (permalink) Old 08-14-2003, 03:17 PM
I hate leaking pans, so I put a little non-hardening Permatex on both surfaces, and on both sides of the gasket. For cork gaskets that might slip, 3M weatherstrip adhesive will tack them in place. Lacquer thinner dissolves Permatex quickly for cleanup. Nobody reuses pan gaskets do they, so why not guarantee a seal on the b%$#%&&?
Valve covers are a good place to just glue the gasket to the cover so it can be pulled off and put back on (for those with noisy rockers - John?), although I've never succeeded in getting a long term leak-proof seal on covers without a touch of silicone. Such a stupid design, cork gaskets w/o a drip path.
66 Coupe,351W,Al heads/manif,hdrs,C4,9" Versailles,3.25,lim slip,discs
KENK66 is offline
