How long can gas sit in a gas tank until it's advisable not to use it? - Vintage Mustang Forums
Old 09-27-2003, 01:21 PM   #1 (permalink)
I'm currently doing a restoration and the gas has been sitting in my tank for 4 months. The fuel pump is off, but the gas has been sitting in the tank and line for all this time. I estimate I'll have the project done is another 2 months--so the gas would have been sitting for a total of 6 months. The engine bay is torn down to only the block & heads remaining; carb is off. I know I should have used Sta-bil but I wasn't planning on taking this long--so should I just drain the gas and dispose of it--or am I OK to use it?
Thank you to all in advance,
Neil
HoustonShelbyman is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 01:27 PM   #2 (permalink)
Gas in the tank is only part of the problem...its the gas in the carb; especially around the needle seats, jets, etc. that gums up. Best to put a stabilizer in, run the car some and then shut it down for extended storage.
"You need only two tools: WD-40 and Duct Tape. If it doesn't move and it should, use WD-40. If it moves and shouldn't, use the duct tape."
fdreano is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 01:29 PM   #3 (permalink)
Forgot to mention, engine bay is torn down to only the block & heads; carb is off. Thanks.
Old 09-27-2003, 01:45 PM   #4 (permalink)
You should have no problem in that amount of time. I would add some sta-bil to the tank. I left a truck I have sit for over a year with sta-bil in the tank and it was fine.
69 Mach 1 427 Windsor,T-56 6 Speed,4.56 Traction Loc
http://memimage.cardomain.com/member...81_21_full.jpg
mod9 is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 02:16 PM   #5 (permalink)
Fuel tends to go stale faster in small amounts, thats why the carb bowls and jets, seats and such gum up quicker. I concur that you should not have a problem in the time span you talk about..
A mans gotta do what a mans gotta do..
66 Fastback Ivy green
onefastback66 is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 02:20 PM   #6 (permalink)
Gone but never forgetten
johnpro's Avatar
It will take probably a year or 2 before you'd have any problem. Each winter we put our boat away with whatever gas is still in there, and it sits from September through May with the gas in it, then fires right back up each May.
I filled up the tank in my sportsroof about 4 months ago. It's driven a total of 2 miles since then.
VMF Jedi Knight who's spirit will be with us forever.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
johnpro is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 03:55 PM   #7 (permalink)
dailydriver's Avatar
As someone else already mentioned, small amounts can go bad sooner than if the tank is full. I think it is partially due to the air in the tank, and the moisture in the air, so it's always advisable to keep the tank full. Stabilizer is no doubt a good thing to add to some of these vehicles that aren't driven a lot.
I have to believe that warm weather probably makes it go bad sooner too. I once had a boat (89 gallon fuel tank) sit for 2 years in Wyoming (read: cooold weather). I had the tank full, with NO stabilizer in it. I routinely let it set for 8 months like that, but circumstances beyond my control stretched it out to 2 years that time. When I went to get the boat, it was fine, and the Rochester 4 bbl on it didn't even have any problems. I figured I would be looking for a place to put a bunch of bad gas, but lucked out. Bottom line, don't worry about it. If it runs crappy when you get it running, take the carb apart and clean it out, as the gas will most certainly have evaporated out of it and will leave some residue. Old leaded gas was much worse about that than unleaded.
Ken
"Get your facts straight first, then you can distort them as much as you wish"!!
1965 Fastback, Sunlit Gold, I6, T-5, Pertronix, CAA AC, SSBC frt discs
dailydriver is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 06:11 PM   #8 (permalink)
sfv
Your fine.Keep going.SCOTT 936-756-2535.
P.S. I've run 10 year old gas out and still been ok. It's just when it turn to suryp and in your carb thats bad. May have to run a few gal. of good gas to be at it's best performance.
Bring 'em back alive restorer own 10+ now.Have FULL service resto. shop in Houston area.
sfv is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 07:22 PM   #9 (permalink)
PTSTANG's Avatar
Well since your from sugar land. I'd advise changing it because the sugar in the air may get into your tank.
Just Kidding
I've dumped gas at 8 months and it still smelled ok. For general running purpose it should be ok. I'm trying to keep my cars running with 100% clean gas (I put super in them). I think at worse you car may smoke for a little while and may not give you it's best performance, but will clear up as you add new gas.
Under God
71 Mustang Mach 1
91 Ford Ranger
01 PT Cruiser
PTSTANG is offline   Reply With Quote Quick reply to this message
Old 09-27-2003, 09:19 PM   #10 (permalink)
Here's my conclusion: I've got a 1/4 tank of the old stuff--so I guess the answer is easy thanks to everyone's help:: add 3/4's new gas plus Stabil and I'll be off to the races.
Insurance
Please select your insurance company (Optional)
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
