1968 Split Rear Window - Vintage Mustang Forums
post #1 of 8 (permalink) Old 10-22-2003, 03:30 PM Thread Starter
Has anyone out there successfully repaired the split rear window of a 1968 Mustang, and if so, could you please provide the steps? I am also concerned about removing the curtain and throwing the rest of the top out of alignment.
Peter
1968 Mustang Conv 289 2v Pebble Beige 1974-1988
Wife 1988 - 2000
1968 Mustang Conv 351w 4v Pebble Beige 2003-
swimmerone is offline
post #2 of 8 (permalink) Old 10-22-2003, 04:11 PM
You are referring to a convertible top rear glass window with the seam, right?
The best repair I have heard of is to remove the existing silicone, clean the area thoroughly, use masking tape to hold the 2 glass pieces together at the correct gap, and use new silicone to "glue" the sections together.
btw, I read this in Mustang Monthly
Paul
1965 Mustang 2+2
1968 Mustang California Special
pprince is offline
post #3 of 8 (permalink) Old 10-22-2003, 04:24 PM Thread Starter
Thanks, and yes, I am referring to the convertible top rear glass window with the silicon seam.
Do you know if I should lower the top when I remove the rear window curtain and glass for repair?
Peter
Wife 1988 - 2000
post #4 of 8 (permalink) Old 10-22-2003, 04:34 PM
With the top up you unzip the window and remove it
Paul
1965 Mustang 2+2
pprince is offline
post #5 of 8 (permalink) Old 10-22-2003, 04:36 PM
You have to note that this is a weak point and the repair will not last if you continue to raise and lower the top with the window in the car.
Paul
1965 Mustang 2+2
pprince is offline
post #6 of 8 (permalink) Old 10-22-2003, 04:38 PM Thread Starter
And that means unscrewing and removing the metal trim bar with holds the well liner, top, and curtain also?
Peter
Wife 1988 - 2000
post #7 of 8 (permalink) Old 10-22-2003, 04:46 PM Thread Starter
Do you mean unzipping the rear window and laying it down in the well each time I lower the top?
Peter
Wife 1988 - 2000
post #8 of 8 (permalink) Old 10-22-2003, 09:50 PM
i967mustang's Avatar
Hi, I fixed my back window in the car. Did it the same way removed all the old silicone taped it off, but I taped off about 3/8" wider than the gap and taped completely inside right over the gap. I then filled the gap from the outside with fresh silicone and smoothed off with finger. Let it dry and then peel off the tape, if there are any voids you can fill them from the inside by masking the same as you did on the outside. mine has been done for almost two years and is still in good shape and I don't lower the window before dropping the top.
(southern NJ) 68 acapulco blue convertible, and 95 opal frost pearl G/T BOSS edition convertible and 78 Mustang II last two belong to swmbo MCA#54225 http://pic90.picturetrail.com/VOL215.../179847757.jpg
i967mustang is offline
