Help me ID my ring gear and pinion. - Vintage Mustang Forums
post #1 of 12 (permalink) Old 02-06-2004, 08:27 PM Thread Starter
I think I might have a none matching set of ring gear and pinion, and that might be the reason for all my problems.
I can't find a number on the pinion but the gear has 37 teeth and shows 3-3-6 code on it.
The pinion has 10 teeth but they jst don't fit right together it seems like.
The guy who sold me this says it has a C2AW 4210 A part number.
Can someone ID this?
1967 Coupe 302 4V
n_sabardin is offline
post #2 of 12 (permalink) Old 02-06-2004, 08:55 PM Thread Starter
I measured the ring gear that is way thicker than my old 3.00 gear and it is 1 7/16 thick. Put on the trac-lok, I have no play at all. The teeth are about to touch the housing, so are the posi bolts.
1967 Coupe 302 4V
post #3 of 12 (permalink) Old 02-06-2004, 09:06 PM Thread Starter
One thought...
is the ring gear thicker for an open differential than for a track-lok? Since the open gear differential is thinner (no clutch set) would it make a difference?
1967 Coupe 302 4V
post #4 of 12 (permalink) Old 02-06-2004, 09:14 PM
Myopic
Nick,
I have been watching your posts with baited breathe. I hope you can get this all to work out without having your rear explode on you when you install it. The only advice I can offer for you is this.....have you considered seeking the help of a hands on Professional?
1965 Fastback 410c AOD - DT
1967 Fastback 347 T5- Cruiser
1968 Fastback 408w T5 - Brute
1991 GT Hatch - Fauxbra
1996 Dodge Viper GTS
https://www.youtube.com/watch?v=0LUK2D0GjdY
dodgestang is offline
post #5 of 12 (permalink) Old 02-06-2004, 09:16 PM Thread Starter
live and learn...
1967 Coupe 302 4V
post #6 of 12 (permalink) Old 02-06-2004, 10:21 PM
Richelieu's Avatar
I would have to agree with my esteemed colleague from Maryland.
Especially when I hear that the information you are using isn't totally what you need and you're just "making things up"... I figured there were a few things I just would NOT do, and rear end work was one of them...
Rich
'66 Mustang, 302, front chin spoiler, R-model valance, '67 style Shelby hood, custom trunk and console.
Richelieu is offline
post #7 of 12 (permalink) Old 02-06-2004, 10:55 PM Thread Starter
Guys, guys... I will rebuild this thing for two reasons:
1- I like the challenge and learning experience,
2- I'm stubborn
I'll probably get a local Professional opinion but I thought this forum was the place to get professional opinions. Heck, if Art can build a engine for Bob, I think that qualifies don't you?
Any how, thanks for the input but this is not the answer I'm looking for right now.
1967 Coupe 302 4V
post #8 of 12 (permalink) Old 02-06-2004, 11:30 PM
I think you find according to the Ford shop manuals that the gear sets are made in pairs- therefore you can't go matching any given pinion gear with any given main gear you have. They are matched pairs, and cut accordingly, usually with matching paint marks I think if memory serves me correctly.
kevinstang is offline
post #9 of 12 (permalink) Old 02-06-2004, 11:48 PM
289fan's Avatar
I'm a novice at looking things up in the Ford Master Parts Catalog, but here's what I find: A C2AW-4210-A (should be stamped on the outer face of the ring) is shown to be mated with one of three pinions: C2AW-4610-A, C2AW-M and C2AW-J. I thought those numbers were stamped into the pinion along it's shaft, but it's been a while since I fondled one of the things. Those three combinations make up set part numbers: C2AZ-4209-A , B7AZ-F and B7AZ-K translating to 4.11s ,37 ring/9 pinion teeth. Rings and pinions are matched, mated assembly and you shouldn'r mix one from one set with one from another. I've not experienced what can happen when you do, so I don't know it that could be a cause of your troubles. With ten teeth on the pinion, I'd wager it could very well be a "sticking" point.
P.S. The source for that information is the 65-72 catalog, and it doesn't list 3.70s used in 9 inches during that period of time, but Ford did earlier than that. Someone with the earlier catalog coverage could maybe see if that ring was somehow mated with a 10 spline pinion to make up a 3.70 R&P. In my Hollander, the 37/10 R&P that make up the 3.70 ration is shown with part number B7AZ-M, But it doesn't give the individual R&P part numbers.
Tom (Johnson) Kubler, a.k.a. 289fan, HiPo289fan, TJinSA, Fy A. Thyrio, & various other unmentionable names.
The A.B.C.s of the '66 GT350- Accelerometer, Beatermeter, Clock
289fan is offline
post #10 of 12 (permalink) Old 02-07-2004, 02:22 AM
bob
bob's Avatar
This forum is for opinions, it's up to you as to whether they're professional or not.
I will say, since you mentioned myself and Art specifically as if it defended your position in taking on something extremely technical without much knowledge, that Art (who has unreal expertise and experience in putting together the kind of engine that I was after) was who I went to as putting together an engine was outside of my expertise. Quite the opposite, you're trying to do something outside of your skill set and you need to realize that without someone right there to show you, as well as arm you with the right tools, you could cost yourself a LOT of heartache and pain in the process of learning. Great to learn how to do things yourself, but add up the cost.
-bob
bob is offline
post #11 of 12 (permalink) Old 02-07-2004, 10:59 AM Thread Starter
OK, let's close on the subject. I'm not trying to justify nothing. I'm asking people that might have knowledge of this their opinion. There are some very technical people on this forum (like Art and thanks to you Bob) and I wanted their opinion. I think I can do this between info I get here, multiple manuals, articles, video, other websites and local people. Now I understand it needs to be done right or I'll pay the price for it but that is a risk I'm willing to take. I believe in rewarding curiousity, perseverance and effort.
That's it, now you're making me feel like I do need to justify myself... :p ::
1967 Coupe 302 4V
post #12 of 12 (permalink) Old 02-07-2004, 11:04 AM Thread Starter
Thanks for the info. I know it is suppose to come as a matching set and that you cannot mismatch rings and pinions. I bought it as a 3.70 set on ehay and I'm thinking I might have gotten screwed. The serial number on the pinion is unreadable so I can't verify it. What I noticed though is that the ring gear is 1/2" thicker that my old 3.00 gear where the pinion teeth diameter is not 1/2" thinner. So everything is more cramped now.
1967 Coupe 302 4V
