speedometer cable lubricant - Vintage Mustang Forums
post #1 of 8 (permalink) Old 11-29-2004, 07:33 PM Thread Starter
I am replacing the speedometer cable on my 67 289 C4 fastback. I went to buy cable lubricant and was told it is no longer available since everything today is electronic. What can I use in it's place? I have a can of Silicone Spray, can I use that? If not, What
thanks
Jay
jaybarbara is offline
post #2 of 8 (permalink) Old 11-29-2004, 08:30 PM
sfv
Nothing liquid.It collects at the low spots and turns to yuk.You need graphite.Any FORD store should be able to get it for you.
Bring 'em back alive restorer own 10+ now.Have FULL service resto. shop in Houston area.
sfv is offline
post #3 of 8 (permalink) Old 11-29-2004, 09:08 PM Thread Starter
Thanks for the input. I'll check with my local Ford dealer tomorrow.
post #4 of 8 (permalink) Old 11-29-2004, 09:26 PM
I used lubriplate also
Shaune
Some have the passion......They control the ride (Lynyrd Skynyrd)
68 C code convert....a driver
88 mustang, low miles, 4 banger
52 Plymouth...SWMBO's ride
52 F100 truck...project 428
laynrubber is offline
post #5 of 8 (permalink) Old 11-29-2004, 11:24 PM
DEL65's Avatar
Johnpro suggested the following which works just fine. I used Marvel's Mystery Oil to lube the cable in my 65. I put the oil in a coffee can and let the cable soak in it for a while. Then I installed it. No more needle-jumping.
Early 65, 5sp, GT Clone, Nightmist Blue
DEL65 is offline
post #6 of 8 (permalink) Old 11-30-2004, 12:04 AM
Graphite would be a good choice after the cable is cleaned of old gunk. Be aware it will be a very messy job especially with graphite powder, that stuff gets everywhere it ain't supposed to.
I have seen/used a teflon powder lubricant that comes in a small plastic tube with excellent results. It's much cleaner than graphite. That would be my choice. Trouble is I can't remember anything else about it.
If I should remember I'll post.
My 68 Mustang sitting in a bunch of boxes in my basement still looks better than your import!
I admit my problem, I'm checking into the Henry Ford clinic for help...
Look here, it'll make you feel better... (my car)
68 Hardtop 289/AOD in need of lots of TLC, and a couple of other rather fast cars...
68Hardtop is offline
post #7 of 8 (permalink) Old 11-30-2004, 12:25 AM
poonstang's Avatar
few years ago i was looking for a lube to quite down a real nice squeel in a toyota truck speedo cable. found a small tube of lube at the local auto store that said it was good for speedo cables (that was in small print and didn't jump out at ya) . turned out to be some kind of liquid graphite stuff, i think that the graphite was only suspended in the liquid, that would later evaporate but that is only a guess. got ride of the squeeel and smoothed out the speedo needle as well.
poonstang is offline
post #8 of 8 (permalink) Old 12-01-2004, 12:17 AM
I have also used a graphite spray on tach drive cables and that has lasted a couple years now.
Take the cable out roll it up on a cloth and spray it.
Shaune
