Is it possible my torque converter doesn't have a drain plug? - Vintage Mustang Forums
post #1 of 4 (permalink) Old 03-13-2005, 04:58 PM Thread Starter
I'm in the process of removing my automatic transmission (I believe it's a C4). The manual says to spin the crank until the torque converter drain plug shows up. I've removed the drain plug cover plate thing so I can see the torque converter bolts, but I can't find my drain plug. All the bolts seem to be the torque convertor bolts to bolt it to the flywheel. Is it possible my converter doesn't have a drain plug?
CBarnes69 is offline
post #2 of 4 (permalink) Old 03-13-2005, 05:04 PM
Yes, if it has been replaced via an aftermarket version it is possible. It is not a big deal, just that when you remove the converter from your transmission it will be heavier and messier, fluid will spill.
4562 is offline
post #3 of 4 (permalink) Old 03-13-2005, 09:02 PM
1320Fastback's Avatar
Sure it is.
1968 Mustang Fastback
289ci, Hooker full lengh headers, 1406 Edelbrock carb, TCI Streetfighter C4, TCI Saturday Night Special TC,B&M Z-Gate shifter, SSBC brakes.
BeerMachine
1320Fastback is offline
post #4 of 4 (permalink) Old 03-14-2005, 10:01 AM
i noticed the same thing on mine(mine is aftermarket)...i was wondering how i drain all the trannie fluid when changing trans. filter....
1966 Mustang, 289 C.I., bored .030, petronix ignition, heddman headers, hyperutectic pisotns, edelbrock performer cam, edelbrock performer rpm intake, edelbrock (1406) 600 carb, hughs 2500 rpm stall, c4 trans, B&M stage II shift kit, 3.55 richmond gears, flex lite trannie cooler...
http://www.cardomain.com/id/brandons1966
Brandon is offline
