FelPro head gasket? Which side is up? - Vintage Mustang Forums
post #1 of 8 (permalink) Old 10-12-2006, 11:01 PM Thread Starter
Sorry about these stupid questions. Just don't want to screw this up. Bought a FelPro gasket kit from summit, and the headgaskets say Front (on both sides, of course), but I can't figure out which side is up.. It does matter I assume? One side is grey, and the other side has a bunch of lines..
And, I asked in another thread but might as well ask here, I should only apply rtv to the long bolts, correct? No chance of the other holes somehow having a leak into a water jacket? Thanks guys
JohnnyK is offline
post #2 of 8 (permalink) Old 10-12-2006, 11:16 PM
stanger53's Avatar
Just put the gaskets on the block with "FRONT" at the front on both sides. That means that the gasket on one side will look upsidedown compared to the other gasket, but that's the way they are supposed to go. It doesn't really matter on those gaskets whether the grey side or the lined side is on top. If you do it any other way, certain water passages will be blocked and the engine will overheat in minutes.
No need to use sealer on head bolts, they aren't exposed to the water jackets. Just need to use a little oil so they torque down correctly.
1966 289 Coupe, 1967 289 Fastback, 1970 5.0 Coupe
Steering Box & Power Steering Website http://www.stangerssite.com
stanger53 is offline
post #3 of 8 (permalink) Old 10-12-2006, 11:47 PM
fastbackfolk's Avatar
the early 302s you need to flip one side over and reverse it... just look to make sure the bolt,coolant holes line up....
fastbackfolk is offline
post #4 of 8 (permalink) Old 10-12-2006, 11:49 PM
assuming you have a 302 or early windsor... I think all windsors are the same?? not sure....
post #5 of 8 (permalink) Old 10-13-2006, 01:10 AM Thread Starter
Thanks guys. It's an 88 5.0. I can definately see that the longer bolts seem to go into the water jackets. The smaller ones seem to be blind holes though. So definately doesn't matter that they are upside down then eh? Cool.
JohnnyK is offline
post #6 of 8 (permalink) Old 10-13-2006, 09:52 AM
Markh's Avatar
On the 5.0 - you'll need some type of thread sealant on the holes hitting the water jackets. I just used some RTV blue on mine - been holding fine for over 40,000 miles.
Markh is offline
post #7 of 8 (permalink) Old 10-13-2006, 05:01 PM Thread Starter
But not on the shorter bolts then?
JohnnyK is offline
post #8 of 8 (permalink) Old 10-13-2006, 05:40 PM
Markh's Avatar
Can't remember which ones - just do them all!
Markh is offline
