Convertible top leaking air? - Vintage Mustang Forums
post #1 of 11 (permalink) Old 01-11-2007, 05:11 PM Thread Starter
I have had this situation for a couple of years but thought today I might ask a question about it. My convertible top raise in the center front a little bit at 50 MPH or so. This of course causes a breeze (slight) throughout the inside of the car. I can't believe this is normal. The side clamps seem to be pretty tight. Do they have to be really, really tight to stop this?
Any advice to solve this situation would be appreciated as it would be nice if I can find a simple way stop it.
1965 "289" Convertible
At least trying to make it original
Yes---it is red
Paul is offline
post #2 of 11 (permalink) Old 01-11-2007, 05:25 PM
The convrtible top should be held down to the two middle bows to prevent balooning, or raising up. This raising up is caused mainly by the air flow over the top side. Even with the windows up and idealy sealed the top would still baloon if not held down by the retainer strips on the center bows.
My '64 1/2 vert. Ordered May '64. D code 4 speed, handling package, caspian blue, accent group, Ford blue manual top.
'68 vert. driver. Owned since Apr '78. C code AT, AC, PS, P disc B, PT lime gold, standard black interior and top. NOS RF fender and left quarter.New top and folding glass.
slim is online now
post #3 of 11 (permalink) Old 01-11-2007, 05:35 PM Thread Starter
So are you saying that it is not connected properly to the bows in the frame?
Yes---it is red
Paul is offline
post #4 of 11 (permalink) Old 01-11-2007, 05:35 PM
HoosierBuddy's Avatar
How tight are your clamps. If it seems a bit loose, adjust the hooks in 1 full turn on each side. That will help.
Phil
HoosierBuddy is offline
post #5 of 11 (permalink) Old 01-11-2007, 05:40 PM
Mine does it, too. I figure it is metal fatigue from all of the years of use. It is adjusted correctly. It doesn't leak water, just a little (cold) air and it is really noisy when driving into high winds. The center bows are solid and prevent any balooning. Go figure. I cobbled up an over center toggle clamp to hold the center of the front bow down. I made an aluminum base to hold the clamp that mounts under the rear view mirror and a small u-shaped device with the clevice that came with the clamp that I hook to the top bow. I use electrical tape on the device so it doesn't scratch the bow. If the wind is strong the clamp gets over powered, I use black duct tape to hold the clamp closed. It is nearly invisible. One of the Mustang magazines is interested in doing an article on it, but I have to make it presentable! The local Mustang shop tells me that this is a common problem unless the top is installed a little loose.
VictorII is offline
post #6 of 11 (permalink) Old 01-11-2007, 05:46 PM
I don't know. You'll have to check. There's a skinny sleeve that's bonded to the inside of the fabric at each of the two middle bows. A steel strip runs through each sleeve and is attached with four screws at each of the two bows.
slim is online now
post #7 of 11 (permalink) Old 01-11-2007, 06:35 PM Thread Starter
Gee I didn't know that others had this problem also. At least I'm not alone.
Yes the side clamps seem to be pretty tight as they snap shut with some force. They certainly are not "loose". I may try to tighten it a bit but I certainly don't want to break anything. This would be the easiest way out.
It is beginning to sound like all the trouble that may be required to fix this that I may as well live with it. I am certainly not going to undo the top from the bows.
I have noticed that when the air gets under the roof it does seem to balloon.
Well anyway that's it. Any further advice is greatly appreciated.
Yes---it is red
Paul is offline
post #8 of 11 (permalink) Old 01-11-2007, 07:42 PM
jims6t6's Avatar
Send a message via AIM to jims6t6
I had that problem on my 64 1/2 really bad. Found out that the hooks were too tight on the sides causing the middle to bow up. loosened the hold down a little and the problem almost went away. Can also be too loose as HoosierBuddy said.
Jim,
MCA # 35023
64 1/2 Convertible, 65 GT Coupe, 66 Coupe (one owner) Red 67 Mustang JR, Red 66 Mustang JR
jims6t6 is offline
post #9 of 11 (permalink) Old 01-11-2007, 08:00 PM Thread Starter
Okay thanks. Guess I will just play around with the hooks a bit. That may well be the problem. As I said they are tight and they just might be a bit too tight. I am pretty sure that I am not going to tear the whole thing apart to fix a relatively minor problem.
I will say that I thought I was the only one that had this situation. What a surprise to find out that it appears not to be uncommon.
Thanks all
Yes---it is red
Paul is offline
post #10 of 11 (permalink) Old 01-11-2007, 08:58 PM
dalorzof's Avatar
Very common problem, my '68 had it before the restoration. At highway speeds a clear, but tiny, gap at the center of the header as air forced up the bow.
Hoping new tack strips/rubber will fix it but not too optomistic.... Debating a bit of extra padding under the middle section of the weatherstrip to push it down another 1/4" or so to help seal better. Not keen on trying to re-bend the header!
- Douglas Adams
8R03S : 76A I 2A 15M 72 5 U
8R01S : 65A B 2A 28M 72 7 5 - Factory GT
8R01C : 65A M 2A 01E 72 2 W - CS/GT
8F01X : 65A I 2G 20E 24 1 U - EXP500 repli-bute
dalorzof is offline
post #11 of 11 (permalink) Old 01-12-2007, 11:59 AM
Mine fits fairly well now, just a slight air leak at 70-80 mph. It did leak air at that speed before I put some 3/8 inch fuel hose under the top windshield molding so that it raised up the center and the side that was doing most of the leaking. I think I can eliminate the small leak I now have by tweaking it a little more to eliminate all the leak at those speeds
The poster formerly known as "bob perkins, not the judge (MCA or OTW)".
66 restomod convertible, forever in progress.
Mustang Owners Club of Austin, TX
http://www.mocatx.com
bsbprkns is offline
