How to straighten up front frame rails - Vintage Mustang Forums
post #1 of 11 (permalink) Old 03-20-2007, 11:00 AM Thread Starter
cmayna's Avatar
Why didn't I address this while I had the tranny out?
I'm going to be installing a set of Maier sub frame connectors shortly and last night I decided to do a test fit only to find out that the frame rails are deformed (buldging out)enough that the U shape bracket of the SFC will not fit.
I need to squeeze the lower section of the sides of the frame box inward to their original dimension. What are my options beside a BFH ? Is the frame rail material thin enough that I could use a large bench vise mounted to a floor jack and squeeze the area inward?
'50 Chevy 1/2......'65 coupe/302/AOD......'68 fb/351c/T5Z
cmayna is offline
post #2 of 11 (permalink) Old 03-20-2007, 11:28 AM
How much are we needing? My father in law has a set of clamps that has a turnbuckle style mechanism that will pull metal together, but it only has about a 1 1/2 inch travel. It's a woodworking set that he modified.
Kind of the opposite of a porta power.
1968 Coupe, In progress
1966 Red Conv (200)
1966 White Pony Int.(289)A Code
1966 Coupe 5.0l; 10:1 compression; 650 Speed Demon, and Close ratio Toploader
1966conv is offline
post #3 of 11 (permalink) Old 03-20-2007, 11:39 AM
midpack's Avatar
You'd be surprised at how easily you can move that metal. I re-shaped the front ones on the 66 Coupe project of mine. Looked like the car went over a curb at one time... :p
midpack is offline
post #4 of 11 (permalink) Old 03-20-2007, 11:57 AM
GT_SCODE's Avatar
Send a message via Yahoo to GT_SCODE
I think that would work!
Mine were so bad I replaced them, which now I wish I had just tried to straighten.
1967 GT S-Code Fastback http://www.gtscode.com and www.SilverBullitt.com
GT_SCODE is offline
post #5 of 11 (permalink) Old 03-20-2007, 12:21 PM Thread Starter
cmayna's Avatar
So would a large massive C clamp work as well? I haven't measured the difference but I think we're look to move each wall inward about 1/2". I could attempt with the C clamp and have a 1/4" piece of metal between the clamp and the rail to distribute the load.
cmayna is offline
post #6 of 11 (permalink) Old 03-20-2007, 12:39 PM
09Frank65's Avatar
Craig,
I used a couple of pieces of oak flooring and a couple of C-Clamps to get the bulk of it back in line.
I still would up finishing with the BFH for final adjustment!
1965 Mustang Coupe
www.not2fst.com
09Frank65 is offline
post #7 of 11 (permalink) Old 03-20-2007, 12:40 PM
garner67's Avatar
Craig,
I had the same problem with my Maier subframes fitting the frame rails. I just used a few persuasive blows with sledge hammer to get the rails back into shape. The frame rail metal isn't that thick/tough. I guess that's why they dent so easily in the first place!
67 C code fastback - more pics
Paint & Body done 1/27/09
351w
Global West a-arms
Maier springs
Koni shocks
Baer disc brake system
alum radiator w/dual electric fans
G-Force T5
31 spline 9" w/3:50 gears
Azenis RT 615 225/50/16 front & rear
Fresh Black Paint
garner67 is offline
post #8 of 11 (permalink) Old 03-20-2007, 06:40 PM
SpareTime's Avatar
The others are right, they move pretty easily. One tip I can offer is for the deep dents. Drill the deepest part of the dent and run a sheet metal screw into it. Rig up a pry bar and apply firm downward tension to the screw while tapping on the "bulged" part of the rail. It's amazing how flat and straight you can get the rails to look. Weld up the holes when you are done and no one will ever know your P.O. used the rails to jack up the car.
If it can't be fixed with a hammer, you have an electrical problem...(stolen from the H.A.M.B.)
SpareTime is offline
post #9 of 11 (permalink) Old 03-20-2007, 09:26 PM
Craig,
I do have a Porta-Power that we could use to move stubborn metal. Let me know when you're thinking about doing this and I could bring my MIG welder also and finish the job.
Vic
[IMG]http://forums.vintage-mustang.com/fi..._0977d__2_.jpg[/IMG]
'65 GT Coupe Project (my 1st car)
65Stang0_1 is offline
post #10 of 11 (permalink) Old 03-20-2007, 09:32 PM Thread Starter
cmayna's Avatar
Tonight I got out my big C clamp and a couple pieces of 3/8" plates on each side of the frame rail. Squeezed them plates together and it moved so easily. The rail material is as limp as Midlife's.....well You know......
Can't believe how soft that metal really is. No wonder these car's underbellies look so rough.
cmayna is offline
post #11 of 11 (permalink) Old 03-20-2007, 09:39 PM
C-clamps to squeeze em' in. In areas where the rail was badly dented I scabbed on plates and welded them to the originals. Look is original but much more strong.
My 68 Mustang sitting in a bunch of boxes in my basement still looks better than your import!
I admit my problem, I'm checking into the Henry Ford clinic for help...
Look here, it'll make you feel better... (my car)
68 Hardtop 289/AOD in need of lots of TLC, and a couple of other rather fast cars...
68Hardtop is offline
