Heater Hose Routing - 69 428cj - Vintage Mustang Forums
post #1 of 4 (permalink) Old 05-11-2007, 12:15 AM Thread Starter
During the process of changing the heater core I found out that the heater valve is missing (my car has AC). So I ordered the correct hoses for a 69 CJ with ac. I have two questions:
1 - One of the heater hoses is molded with a 90 degree angle on one end. Does this end of the hose connect to the water pump, the intake manifold or the heater core?
2 - I know the heater valve goes on the inlet side of the heater core, but which side is the inlet side of the heater core - the passenger side or the driver side?
Jim Beers
69 Mach I R-Code 428
Learn from the mistakes of others. You can't live long enough to make them all yourself.
jebeers is offline
post #2 of 4 (permalink) Old 05-11-2007, 01:39 AM
Question #1 is to the heater core. It goes from the Heater Valve to the Core it self (Pass. one).
This answers Question #2
1967 S-Code Mel's 1968 J-Code Convertible
Mike is offline
post #3 of 4 (permalink) Old 05-11-2007, 03:33 PM
manyc's Avatar
the heater hose with the single 90 degree bend goes to the outside (rightmost) heater core connection and runs to the waterpump.
there is supposed to be a short hose with 2 90 degree bends that goes from the inboard heater core connection to the water valve. the other end of which goes to the intake. Off hand I don't know for sure which direction the watervalve is supposed to point. I think ther arrow points towards the firewall.
"If I can't fix it, I'll fix it so no one can !"
1969 Mustang LE600 Sportsroof - Groovy Green
1969 Mustang LE600 Coupe - Flower Power Red
1969 Mustang Sportsroof - Dark Jade
1969 Firebird 350 Conv - Mayfair Maze
1968 Cougar Hertz XR7-G (project)
1959 Oldsmobile Super 88
1963 Jaguar XKE Coupe (project)
[url=http://www.relicrecyclery.com/groovygreen/groovygreen.htm]
[url=http://www.relicrecyclery.com/]
manyc is offline
post #4 of 4 (permalink) Old 05-11-2007, 06:58 PM
SCJSTU's Avatar
go her for more cj specific help if you need
www.428cobrajet.com
1970 Mustang Convertible 351C Shaker
2006 Mustang GT Supercharged
2004 Mustang Mach 1
1956 Ford F100 392 Hemi powered
1961 Econoline pickup-bagged
1961 Falcon 2 Door Station Wagon 302 V8
1963 Falcon Ranchero.....scraper
1970 Chevy Blazer 2WD 496 Rat
"why do the rear tires always wear out quicker then the front?
SCJSTU is offline
