Where is my turn signal flasher? - Vintage Mustang Forums
post #1 of 10 (permalink) Old 07-10-2007, 09:09 PM Thread Starter
jsgarron's Avatar
I just had a rear turn sigal bulb burn out so I replaced it. Now my turn signals do not work. I went to replace the flasher but can't find it. It is not in the fuse block. Is it on the steering column under the cover? This is on my 73 Mach. The manual isn't much help, shows it for everythinng except the Mustang.
Thanks in advance.
73 Mach 1 351 clev.
jsgarron is offline
post #2 of 10 (permalink) Old 07-10-2007, 09:43 PM
On 68, the flasher is incorporated into the main harness, so its behind the dash instrument panel. I would guess it would be in the same general area for yours.
1968 Fastback Project
1968 Coupe-RIP
ihavea68stang is offline
post #3 of 10 (permalink) Old 07-11-2007, 12:02 AM
behind the glove box on the left side. It looks like a cylindrical alu. capacitor.
Anthony Jacob is offline
post #4 of 10 (permalink) Old 07-11-2007, 12:12 AM
jmoffett's Avatar
Actually, it's attached to a metal panel that is mounted above the glove box. You have to remove the glove box insert to get to it.
"You're almost as big as you say you are." -obsidianspider
jmoffett is offline
post #5 of 10 (permalink) Old 07-11-2007, 11:18 AM Thread Starter
jsgarron's Avatar
I removed the glove box panel before I posted and did not find it. I will look again. I can't hear it because the turn sigs. won't blink. This is kind of goofy.
I will look some more tonight, but if anybody knows for sure where it is I would appreciate it if you would share that info with me.
Thanks All.
73 Mach 1 351 clev.
jsgarron is offline
post #6 of 10 (permalink) Old 07-11-2007, 06:39 PM
cramer's Avatar
In a 69 coupe there is one (metal unit) attached on the metal dash around where the radio/ac heater controls...towards the back of the metal dash and on the left hand side of the ac heater controls. There is also a blue plastic one (not sure what it is) that is attached behind the ac heat controls, right hand side, on the inside of the metal dash.
Hope this helps,
Marc Cramer
cramer is offline
post #7 of 10 (permalink) Old 07-11-2007, 10:38 PM
Jack's right (no surprise there), it's behind the glove box. I replaced it not too long ago.
-Art Nunez
One Man, Three Mustangs
[IMG]http://forums.vintage-mustang.com/fi...0-DSC_0066.jpg[/IMG]
Natalie- My 1973 Mustang Grande (351C-2v-C4 Trans)
The Geezer- My 1972 Mustang Grande (302-2v- FMX Trans)
Ana (Banana)- My 1965 C-Code Coupe (289-2v- C4 Trans)
73GrandStang is offline
post #8 of 10 (permalink) Old 07-12-2007, 03:48 PM Thread Starter
jsgarron's Avatar
Thanks all, I will look for it again tonight behind or above the glove box.
Cramer, the blue one is most likely your hazard flasher.
73 Mach 1 351 clev.
jsgarron is offline
post #9 of 10 (permalink) Old 07-12-2007, 04:53 PM
cramer's Avatar
Good to know. Thanks.
cramer is offline
post #10 of 10 (permalink) Old 07-12-2007, 05:36 PM
Hemikiller's Avatar
Above the glove box. There are two or three screws holding a metal panel in place. Remove these screws and the panel will drop down. There are other relays and buzzers on this panel as well.
BTW, now is the time to ditch the seat belt buzzer..
Nothing worthwhile is ever quick, cheap or easy, those that can't do, complain
71 Mach 1
HOLLEY TECH PAGES
FORD OE TACH HOOKUP FORD OE TACH HOOKUP w/MSD (pg 7)
Hemikiller is offline
