Putting a electric fan on a 67 - Vintage Mustang Forums
post #1 of 16 (permalink) Old 09-13-2007, 04:24 PM Thread Starter
NoBottle's Avatar
I bought a electric fan today for my 67 its a reversiable fan to make it a pusher or a puller i wanna mount it in front of the radiator so it blows the air threw the radiator if i get stuck in traffic or what not my question is
since the fan on the motor is blowing air in the back will it effect the fan trying to blow air threw the front?
when mounted on the front of the radiator does that make the fan a pusher or a puller?
1967 Mustang
NoBottle is offline
post #2 of 16 (permalink) Old 09-13-2007, 04:48 PM
IMO, I would eliminate the motor fan altogether if going to an electric fan setup. I mounted an electric fan in front of the radiator on my 66 convertible and love the results. In this configuration, I consider the fan to be a pusher. I decided on a used fan from a Mercedes and fabricated four brackets that attach the fan frame to the radiator support. The only problem I encountered was that the hood release was rubbing against the fan hub. I was able to cut the sides of the hood release lever, bend it forward and weld up the cuts. It worked out well and you can't tell that the hood release was modified.
Scott
scottstang is offline
post #3 of 16 (permalink) Old 09-13-2007, 05:22 PM
buening's Avatar
A puller electric fan is always more efficient than a pusher. I would only use a pusher fan if i had clearance issues between the radiator and the motor.
70 Mach 1 - 351w/T-56
70 SportsRoof - 302/C4
05 F150 FX4
06 BMW 530xi
T56 Conversion
DIY Ron Morris-like Motor Mounts
DIY Engine Crossmember
DIY Camber Eccentric Eliminator Plates
buening is offline
post #4 of 16 (permalink) Old 09-13-2007, 05:46 PM
How much space do you guys have? I have about 3" between the rad and the motor. Me thinks I might have tog o pusher eh?
JohnnyK is offline
post #5 of 16 (permalink) Old 09-13-2007, 06:08 PM Thread Starter
NoBottle's Avatar
Im just putting this fan on without a thermostat so if i get into traffic or sitting at a drive thru the temp dosent start climing im gonna wire it to a switch that i can turn on and off.
I have alot of room but im only putting on a small 12 inch fan
1967 Mustang
NoBottle is offline
post #6 of 16 (permalink) Old 09-13-2007, 07:18 PM
Rorin67's Avatar
That's what I initially did a swell, though I used a 14" fan. 14" is as big as you can go in front, as the 16" won't fit without cutting some metal a bit in the radiator support. So your mod is totally fine, it will be pusher, and I say WTH - why not go with a 14"!
Formula for a daily driver street fighter in Los Angeles:
'67 Fastback + Built 351W + T5 + 3.55:1 + LTs + 2.5" + 40s + TT2 17s
+ Shelby drop + CSRP + R&P + Bilsteins + SFCs + under riders + 22 Gal.
+ 3pts + 2nd Skin + MTF grille/lights + LEDs + SiriusXM
MTF Grille/Light Kit Install w/ Pics... & Engine Bay Pics...
As featured in Hot Rod Magazine tech article, May 2014
Rorin67 is offline
post #7 of 16 (permalink) Old 09-13-2007, 09:58 PM
Just some guy
GypsyR's Avatar
The belt driven fan is a puller. You will mount your fan in front so it will be a "pusher". Basically it will act as a booster to the original fan. IMHO, if you need the extra help cooling the engine at idle on hot days you have cooling issues that need to be looked into. Not to say the extra won't help, it can, I've done it as a temporary band-aid fix myself.
Right now both my F100 and Bronco have added pusher fans. In both cases I use the pusher fans for extra airflow when running the AC during extended idle times. Neither truck runs hot without the fans but both are R134A AC conversions. When the pusher fans are activated I see a redution of about 30 psi in compressor head pressure. This basically means colder air out the vents versus not having the fans. You will see some of the same effect on the radiator too.
.... it wouldn't be the first time reality took theory and conjecture out behind the woodshed and gave them a good thrashing.
GypsyR is offline
post #8 of 16 (permalink) Old 09-13-2007, 11:57 PM
You have to do your measuring and research before going with a 16" puller. I had a 3-row stock radiator, and only found one 16" fan (SPAL 2350 CFM) that fit and had to trim the nose of the waterpump to make it work. Once I switched to a 2-Row aluminum radiator I could fit many more 16" fans.
I have alot of pics and info on my install at the following link:
http://www.fastbackmustang.com/Proje...emUpgrade.aspx
The SPAL fan is probably one of the best fans you can buy for the money (generally about $100 on eBay).
James
66 Fastback - 302, C4, 8" w/ 3.80 posi, Granada Discs
06 Mustang GT - Satin Silver, 5 spd, JLT Intake, Flowmaster, 3.73, Bassani X-Pipe, UDP - SOLD
2011 GT500 - Black with a few mods.
donovanjamesl is offline
post #9 of 16 (permalink) Old 09-14-2007, 08:08 AM Thread Starter
NoBottle's Avatar
I havent had a problem with the cooling i was sitting at a drive thru the other day it was like 85 degrees outside and the car got up to about 225 after sitting for approx 10 mins i have a digital guage setup for the temp i really just wanted to put it on there to keep good air flowing if i get stuck.
1967 Mustang
NoBottle is offline
post #10 of 16 (permalink) Old 09-14-2007, 09:00 AM
buening's Avatar
My apologies, i didn't realize you planned on keeping the stock belt fan as well.
05 F150 FX4
06 BMW 530xi
T56 Conversion
buening is offline
post #11 of 16 (permalink) Old 09-14-2007, 11:21 AM
Unless you want an original looking car I would seriously consider getting a 16" puller fan that fits and pulls atleast 2000 cfm (preferrably more). You will be happy with the performance gain from the loss of the parasitic drag of the fan, and you should never have to worry about the car ever approaching 200 degrees.
For $100 it is a good investment for your engine.
JMHO
James
post #12 of 16 (permalink) Old 09-14-2007, 04:21 PM Thread Starter
NoBottle's Avatar
Thanks for all the info guys.
1967 Mustang
NoBottle is offline
post #13 of 16 (permalink) Old 09-20-2007, 03:38 PM Thread Starter
NoBottle's Avatar
so im installing my fan today and i have a question because im a lil confused the stock fan blows air at the radiator from the back side im gonna install my fan on the front so would i want to set my fan up so it helps pull the air the engine driven fan is making thur the radiator right?
if i put the fan on the front of the rad and make it blow air therw towards the engine it will be blowing air against the air the engines fan is blowing in the backside and will deafeat both fans purpose right?
see why im confused lol
1967 Mustang
NoBottle is offline
post #14 of 16 (permalink) Old 09-20-2007, 03:50 PM
No bottle. Your current fan Sucks air thru the radiator it doesnt blow it thru.Put a piece of paper in front of the radiator with the motor running and the piece of paper will stick to it. By adding a Electric fan to the outside of the radiator it needs to be set to the (pusher) mode. Basically make sure the part that goes against the raditor is Blowing and not sucking. Then it will assist you in extra cooling. If you set it to puller mode you will be deafeating the purpose unless you mount it on the inside of your radiator between the engine and Radiator. Then of course you would have to remove your Mechanical Fan. Mike
1967 S-Code Mel's 1968 J-Code Convertible
Mike is offline
post #15 of 16 (permalink) Old 09-20-2007, 05:25 PM
buening's Avatar
If the stock mechanical fan is not pulling air through the radiator and pushing it to the back of the engine, then i'd venture to guess that you have a fan for a serpentine car and i'm surprised you aren't having overheating issues while driving at fast speeds.
05 F150 FX4
06 BMW 530xi
T56 Conversion
buening is offline
