fuel line routing on 68 - Vintage Mustang Forums
post #1 of 14 (permalink) Old 11-16-2007, 10:13 PM Thread Starter
Pete Strzempek's Avatar
Does any one have pictures of fuel line routing on a car with subframe connectors. I put some Tin Man Subframe connectors on and now I can not use the stock fuel line route.
Pete Strzempek is offline
post #2 of 14 (permalink) Old 11-17-2007, 09:57 AM
cmayna's Avatar
That is interesting for I will be istalling SFC on Shag one of these days so I need to look into this. Where is the interference?
'50 Chevy 1/2......'65 coupe/302/AOD......'68 fb/351c/T5Z
cmayna is offline
post #3 of 14 (permalink) Old 11-17-2007, 10:07 AM
GT_SCODE's Avatar
Send a message via Yahoo to GT_SCODE
Yes, you are correct this is a problem.
When I had my subframe connectors installed they ran them below the fuel line but if I ever need to replace it I will have to run it differently.
See this post http://forums.vintage-mustang.com/sh...1/post/1716019
I think you can change a couple of bends or try to find the fuel line that run down the trans tunnel.
1967 GT S-Code Fastback http://www.gtscode.com and www.SilverBullitt.com
GT_SCODE is offline
post #4 of 14 (permalink) Old 11-17-2007, 10:10 AM
olddustyrelics's Avatar
The fuel line will fit, but not the large metal cover. You have to modify the cover and you might have to slightly notch the SFC.
I don't know a lot about anything, but I know a little about everything.
Built a 1967 Shelby GT-350 Convertible Replica, a 67 Vert resto-mod and also built a 427 FE 67 Shelby GT-500R (R Stands for Replica). 427 Side Oiler, toploader 4spd, 4 wheel discs, 9" traction loc and a perfect body. What more could you ask for? Now I car hunt and horse trade and I am currently looking for the next project! Always seeking that elusive "reasonable" Shelby.
http://www.cardomain.com/ride/2503347
olddustyrelics is offline
post #5 of 14 (permalink) Old 11-17-2007, 10:13 AM
GT_SCODE's Avatar
The NPD catalog specifies that early 67 lines run down the tunnel I would be interested in seeing what that looks like.
Dusty is right, we modified the fuel gaurd but did not need to notch the fuel line.
The biggest problem is getting it in there and running it in that tight of a space.
GT_SCODE is offline
post #6 of 14 (permalink) Old 11-17-2007, 10:35 AM
cmayna's Avatar
Notching the SFC's not fuel line. Justin I knew you encountered this issue but I wasn't sure if the 67 and 68 were routed the same.
Pete, since your SFC's are installed, even if it was notched being one very long piece I don't see how you could fish it through the notch and into place. Sounds like you will need to do some custom routing.
I like going along the tunnel idea. Similar to the 65 and 66.
cmayna is offline
post #7 of 14 (permalink) Old 11-17-2007, 10:41 AM
GT_SCODE's Avatar
Yes notch the subframe connector not the fuel line, I would think that would not work out.
As Craig said I don't see how you could route it through that small of an opening.
GT_SCODE is offline
post #8 of 14 (permalink) Old 11-18-2007, 07:21 AM Thread Starter
Thanks for the pictures and responses guys. I know the thick metal cover will not fit without some type of modification becaause mine are square shaped tubular, but I'm not sure if I could even squeeze the line between the connectors and the floor. The Tin Man connectors are really close to the floor pans. I will probably opt for the tunnel route. I really don't want to notch the subframes. I believe that would weaken them and they were put there for the opposite reason.
post #9 of 14 (permalink) Old 11-18-2007, 10:08 AM
GT_SCODE's Avatar
I wouldn't notch it either.
GT_SCODE is offline
post #10 of 14 (permalink) Old 11-18-2007, 10:36 AM
cmayna's Avatar
I don't think notching the sfc's was a serious suggestion unless when fabbing the sfc's you notched it and then installed a reinforcement plate. At least you don't have to think about that for it's already installed. Just re-route the line down the tunnel. To me, it is a lot cleaning looking having the fuel line hidden more.
cmayna is offline
post #11 of 14 (permalink) Old 11-18-2007, 10:55 AM
By "notching" the squart tube sub frames I refer to the process of cutting a half moon shape out of the offending area of the SFC. It should only require a cut through the corner of the square tube. Then fit a half round piece of steel pipe large enough to easily pass the fuel line through the SFC at the corner where it is near the floor. Then weld the steel tube into the SFC and ground smooth.
post #12 of 14 (permalink) Old 11-18-2007, 11:13 AM Thread Starter
Dusty, That sounds like a perfect solution that would work but mine are already installed and it would involve a ton of work. It would be the answer for future installers.
post #13 of 14 (permalink) Old 11-18-2007, 01:21 PM
Fast68back's Avatar
I have the TCP SFC's in my car and there is a plate right there that I plan to drill a hole through and either use a bulkhead fitting to go through or a rubber grommet with a rubber hose passing through.
-Rick
IF YOU DON'T STAND BEHIND OUR TROOPS,
PLEASE, FEEL FREE TO STAND IN FRONT OF THEM
Fast68back is offline
post #14 of 14 (permalink) Old 11-18-2007, 11:02 PM
doug ford's Avatar
I have the square tube SFC's on mine and I tried the 68 fuel line and it just wouldn't work and I ruined it trying. I talked to the owner of Fine Lines and he suggested I try I think it was a 69 fuel line if I remember correctly. It fit with some minor adjustment. It's been awhile since I bought it so I'm not positive it was for a 69 but I think it was. It routed a little differently than the 68. You might give them a call to see if I'm right.
Doug
1968 modified fastback, aluminum 427 tunnelport 4 speed toploader
1968 coupe 289
'07 Shelby GT500, black with tungsten stripes
1995 SVT Cobra
1967 Fairlane GT 390 4 speed
http://www.cardomain.com/id/d_ford
Videos of my fastback at https://www.youtube.com/user/ohiofirelt?feature=guide
doug ford is offline
