Serpentine belt conversions - Vintage Mustang Forums
post #1 of 17 (permalink) Old 01-23-2008, 01:26 PM Thread Starter
hotelbldr's Avatar
Is there a way to convert to serpentine belts without busting the bank on a March kit? at $1700.00 +or- for all the parts , then add in labor. Yikes!
I'm getting tired of dealing with squealing V-belts, But at that cost I'll continue to deal with it.
"Never forget: the secret of creating riches for oneself is to create them for others."
Sir John Templeton:
hotelbldr is offline
post #2 of 17 (permalink) Old 01-23-2008, 01:30 PM
frdnut's Avatar
Hopefully some more will chime in on this but I have heard March has a water pump pulley that will allow you to use the stock serpentine crank and alternator pulleys..
68 J code sprint, 408W
11.47@123.35mph in street trim.
frdnut is offline
post #3 of 17 (permalink) Old 01-23-2008, 01:42 PM
monkeystash's Avatar
How about just salvaging one from any late model Ford that has a 302?
-Ryan
monkeystash is offline
post #4 of 17 (permalink) Old 01-23-2008, 01:49 PM
That would require a smog pump if I'm not mistaken.
Joe
'67 Fastback 351c, T-5, 3.70 Trac-lok
'69 Mach 1 project
'71 Boss 351
joe69 is offline
post #5 of 17 (permalink) Old 01-23-2008, 01:49 PM
buening's Avatar
Sourcing late model 302 stuff would work, but you will have to get the reverse rotation water pump and will likely have to use an electric fuel pump. I recall a clearance issue with bracketry and the mechanical fuel pump. What accessories are you running? The less the easier
70 Mach 1 - 351w/T-56
70 SportsRoof - 302/C4
05 F150 FX4
06 BMW 530xi
T56 Conversion
DIY Ron Morris-like Motor Mounts
DIY Engine Crossmember
DIY Camber Eccentric Eliminator Plates
buening is offline
post #6 of 17 (permalink) Old 01-23-2008, 01:54 PM
Get one from a late model 5.0 Mustang, T-bird, Cougar, Lincoln Mark VII, and small block late 80's to early 90's ford trucks (F-Series, Bronco, and E-Series van). Avoid the 5.0 Grand Marquis and Crown Vic; they have the bulky two belt design. There will be plenty of sets to be found at a local pick and pull.
Owner of:
2005 Ford Mustang GT
1968 Mustang Hardtop
Mods do the '68: '71 Mustang disc brakes, KYB shocks, 620 coil springs, 2 1/2" dual exhaust with Dynomax Super Turbos and MAC long tube headers, C4 with shift kit and TCI high stall converter, 3.40 gears,and 302 with, P&P GT-40P heads, a Ford Motorsports A-312 cam, .040" overbore TRW forged pistions, Edlebrock 600 CFM carb, Weiand Stealth intake, and 1.6 roller rockers.
dboltong is offline
post #7 of 17 (permalink) Old 01-23-2008, 01:56 PM
You can remove and bypass the smog pump by just running the belt a little differently.
Owner of:
dboltong is offline
post #8 of 17 (permalink) Old 01-23-2008, 02:11 PM
Okay, just found this. It shows how you can route the serp belt if you don't have a smog pump or PS. Plus, FMS also makes a A/C eliminator kit, if you just have an alternator. Check it:
-Ryan
post #9 of 17 (permalink) Old 01-23-2008, 07:23 PM Thread Starter
hotelbldr's Avatar
I have it all: alt, PS, AC,
I was prompted to ask this earlier by reading the Taurus electric fan swap. Since it requires a 3G alternator, why not just swap out the pulleys and belts and be done with the annoying noise.
That was my thinking.
So if I take a bucket full of pulley pullers to the pick and pull I will be able to aquire the necessary hardware. Then it would be off the autozone for a serpentine bel.
This could turn out to be a cool swap
Sir John Templeton:
post #10 of 17 (permalink) Old 01-23-2008, 07:26 PM Thread Starter
hotelbldr's Avatar
Monkeystash you really don't think we could read that small print did you?
Is there a way to make it the large print readers digest version?
Sir John Templeton:
post #11 of 17 (permalink) Old 01-23-2008, 10:10 PM
Dude, VMF now shrinks all images to the same little size. Not my doing. However, I aim to please, so here is the link. About half way down the page.
http://forums.stangnet.com/showthread.php?t=522939
-Ryan
post #12 of 17 (permalink) Old 01-24-2008, 01:27 AM
gothand's Avatar
You can run a serpentine setup from a 5.0L with a few minor tweaks. Here is a pic of mine before I converted it to EFI. Yes you can run a mechanical pump without issue ('85 GT H.O.) and you can delete the smog pump as shown in the belt diagram posted above. One issue to solve is the spacing on the harmonic balancer. I believe the 5.0L balancer is longer. I *think* you may need to buy a Pro Products balancer and spacer (or equivalent) to make sure your balancer lines up with the new pulleys.
'65 2+2 EFI
gothand is offline
post #13 of 17 (permalink) Old 01-24-2008, 02:30 PM Thread Starter
hotelbldr's Avatar
Dude is that a Delta jet?
The link isn't working right now maybe when I get home this evening I'll try again.
Thanks for the consideration, us old guys need all the help we can get.
That why I asked for the large print edition.
Sir John Templeton:
post #14 of 17 (permalink) Old 01-28-2008, 11:29 PM
Has anyone ran a 5.0 serpentine set up with just the 3 basic pulleys: crankshaft, water pump, and alternator? I dont have power steering or A/C.
fouronthefloor is offline
post #15 of 17 (permalink) Old 10-23-2011, 01:10 AM
fouronthefloor did you ever get an answer to your 3 basic pulley question? This is what I want to do.
Triton is offline
