1966 Fastback Rear Qtr Vent Drain Tube - Vintage Mustang Forums
post #1 of 7 (permalink) Old 01-26-2008, 12:56 PM Thread Starter
There was a thread that I can't find that was about fabricating your own rear quarter vent drain tubes if your fastback didn't come with them. When my 66 was disassembled, there were no tubes. But also, I don't see a way to attach a tube. It seems like there should be some kind of metal fitting welded on where the drain hole is to fit the tube on.
lesnchlsn is offline
post #2 of 7 (permalink) Old 01-26-2008, 01:33 PM
Midlife's Avatar
I JB-welded a PVC section of pipe over what remains of the downspout nipple, and then used clear plastic tubing to route the water into the rockers, ala 1965.
'Electrical Guru: Let me Check Your Shorts! Ooops...that didn't turn out right.
http://midlife66.com/harnesses
http://midlifeharness.com
Midlife is offline
post #3 of 7 (permalink) Old 01-26-2008, 04:08 PM
gjz30075's Avatar
I did this. I forgot the size of the brass nipple, maybe 3/4", but it threaded itself in nice and tight.
Greg Z.
'66 GT
gjz30075 is online now
post #4 of 7 (permalink) Old 01-26-2008, 06:12 PM
66HertzClone's Avatar
A dishwasher discharge hose from ACE hardware worked for me. One pacage was long enough to do both sides of the car. I used a clamp to positioin it over the rocker drain hole.
66HertzClone is offline
post #5 of 7 (permalink) Old 01-26-2008, 07:03 PM
From your supplied photo... the drain tube doesn't connect to anything shown in that picture... the drain tube will connect to a nipple located on the bottom of the air box. The tube will then pass through a hole in the metal support located under the box and then continue down through the rocker panel.
Dave
"The danger of communication is the illusion that it has occured"
DaveSanborn is offline
post #6 of 7 (permalink) Old 01-26-2008, 09:25 PM
Randyfastback65's Avatar
MOST, but not ALL, 66's didnt have a fitting, the water simply drained out the hole and was guided to the rockers with a pastic "water shield".
Unfortunately, over the years, the plastic shield either rotted away or was removed and not replaced... Like already advised above, either make a fitting or find a tube that will fit tight in the hole
Here is a pic of my original tubes and clamps
Randy,
'65 owner for 37 years and counting
My Mustang Slideshow:
http://www.youtube.com/watch?v=7x4gOjXMbuU
My pics from around the world :
http://www.youtube.com/watch?v=xKLfZ5oDI28
Randyfastback65 is offline
post #7 of 7 (permalink) Old 01-27-2008, 12:00 PM Thread Starter
Thanks all!
