Electric Fan Thermal Switch mounting location - Vintage Mustang Forums
post #1 of 6 (permalink) Old 06-25-2008, 04:56 PM Thread Starter
70_Fastback's Avatar
Where is the best spot to install the thermal fan control switch for my electric fan?
Thread it into the intake somewhere?
I need to check the Amp draw on my fan as well to determine if I can just use a thermal switch, or if I need to use a switch/relay combo.
Or should I just use the switch/relay together anyway?
Also, should the opening & closing temperature switch range match the opening temp of of my T-stat? Or be higher ?
And lastly, I assume a manual over-ride switch would be a good idea as well? Just a little extra insurance incase of a relay failure. Or would the relay fail "open" and it would run continuously ?
thanks
Jeremy
1970 'Grabber' Sportsroof
1942 GMC Ratrod Truck
1928 Model A - traditional hotrod project
70_Fastback is offline
post #2 of 6 (permalink) Old 06-25-2008, 05:19 PM
carlosmaurixio's Avatar
I usuealy see the thermal switch IN the radiator core. I would set it a little bit below the t-stat so that it can cool the water in the radiator below the temp of the t-stat or the stat will never shut.
carlosmaurixio is offline
post #3 of 6 (permalink) Old 06-25-2008, 06:41 PM
erbssr's Avatar
Send a message via Yahoo to erbssr
The most common place is the radiator drain plug with a T fitting.
http://inlinethumb63.webshots.com/45...425x425Q85.jpg
Honey Gold coupe, Ivy Gold interior,1" lowering springs in front,Shelby hood scoop, front spoiler,TT II wheels, Vintage Air A/C, 5" fog lights, Tri-Bar headlights, Flaming River QR steering box, LED sequential tail lights, kick panels w/speakers;Custom Autosound stereo USA66.
erbssr is offline
post #4 of 6 (permalink) Old 06-26-2008, 12:24 AM
Gone but never forgetten
johnpro's Avatar
The ideal place is at the lower radiator hose. This isn't always the easiest place, though. I have mine mounted in the t-stat housing on both my '66 and my '69. You don't want it in the intake. You want it after the t-stat.
You DEFINITELY want to use a relay. Any fan that can pull enough air to be efficient, will pull a lot of amps. You'll also want to upgrade your alternator.
An override switch is nice, but certainly not necessary. I don't have one on either of my cars. It would be nice to have at the track, though, to run the fan sitting in the staging lanes, then shut off when I go to the line.
VMF Jedi Knight who's spirit will be with us forever.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
johnpro is offline
post #5 of 6 (permalink) Old 06-26-2008, 01:33 AM
Emil in Wyoming's Avatar
Summit has a radiator hose piece (made by Be Cool?) that has two fittings for temp probes. This might work for you.
'66 coupe
emilk5@Bresnan.net
Emil in Wyoming is offline
post #6 of 6 (permalink) Old 06-26-2008, 11:45 PM Thread Starter
Thanks for all of the replies guys. I appreciate it.
Jeremy
