Are you running a coolant overflow tank ? - Page 3 - Vintage Mustang Forums
 1Likes
post #31 of 42 (permalink) Old 07-30-2008, 09:07 PM
VMF Full-Timer
'70 StangMan's Avatar
[IMG][/IMG]
http://i288.photobucket.com/albums/ll175/RDF06/browning002.jpg
Dale
1970 Grabber, 351 W.
Praise the Lord and pass the ammunition.
'70 StangMan is offline
post #32 of 42 (permalink) Old 07-30-2008, 10:59 PM
sigtauenus's Avatar
Originally Posted by slim
Hiker, I agree. I keep the level as shown in the owners manual. Never overflows.
I had a Mustangs Plus 3 row radiator in the fastback before it got tore apart. Filled up to specs it would spit coolant when parked. It liked a level such that you could see the fins inside the tank. Never ran hot. Drove the car as a daily driver 10 years like that. I think it took me 2-3 years before I stopped topping it off and just left it level with the fins.
Sam
68 J-code Fastback - owned since Jan 1994
68 C-Code Coupe
78 F-150 4x4
Got a question about fold down seats or need some fold down seat parts? Check out the new http://www.folddownseat.com
sigtauenus is offline
post #33 of 42 (permalink) Old 07-31-2008, 01:59 AM
sgtfury40's Avatar
I have a plastic universal from autozone. These are a necessity in AZ if you are going to drive your car. I wanted to keep the engine bay looking stock so I mounted it in the front fender well directly in front of the tire on the drivers side. Can't see it in the engine bay and still works perfect.
65 Honey Gold 289 4V Coupe, [IMG]http://memimage.cardomain.net/member.../3061571_1.jpg[/IMG]
66 Antique Bronze 351W T5 Conv
sgtfury40 is offline
post #34 of 42 (permalink) Old 07-31-2008, 02:10 PM
hotrodder68's Avatar
I use an aluminum with a screw on cap as others do. Works well and looks nice next to aluminum radiator. I also use the cap shown in the picture w/ a double gasket. It was 104 on monday in dallas so I found it necessary to have a good cooling setup uncluding overflow tank.
306. AFR 185. Cam Research cam.670 Holley.Broader c4.subframes.9'' 4.11 detroit locker
hotrodder68 is offline
post #35 of 42 (permalink) Old 07-31-2008, 02:54 PM
zray's Avatar
I'm using the same Mustang Plus type aluminum tube style tank and a Stant performance radiator cap.
http://www.stant.com/brochure.cfm?br...ocation_id=179
It was nice to drive 1500 miles recently and have the same amt. of coolant at the end of trip as when I began.
Z.
zray is offline
post #36 of 42 (permalink) Old 07-31-2008, 04:32 PM
musgofasta's Avatar
Nope. Filled the radiator to the top, and it finds a good level. I don't drip or run hot. I check it periodically.
Must....Go.....Faster!
1967 Mustang Coupe - "Legend Lime"
1966 Mustang Coupe - "Ol' Whitey"
musgofasta is offline
post #37 of 42 (permalink) Old 06-20-2011, 12:09 PM
ricer333's Avatar
Originally Posted by t.goat View Post
I have this one from Jegs. Didn't even have to drill any holes. Everything secured on nicely on some pre-existing rad bracket holes.
Wanted to ask a few questions on this. 1) how do you like the Jegs product? 2) how did you install it, as a overflow tank or a recirculation tank? 3) what's the difference between the two installs? 4) did you use the Jeg's bracket to install this or drill your own holes?
Thanks! I've just bought a 65 Fastback and of course am having a little overflow after short trips.
ricer333 is offline
post #38 of 42 (permalink) Old 06-20-2011, 08:17 PM
a true over flow tank doesnt return the collant to the rtadiator when it cools off.
mustangted1966 is offline
post #39 of 42 (permalink) Old 12-11-2016, 07:47 PM
evantugby's Avatar
I have a cheap autozone plastic overflow tank next to my radiator. I want to pull it out and not use an overflow tank at all because the nice aluminum ones are $200+. Is there anyone else in hot temperature locations not using one?
What problems could I run into if I don't use one?
evantugby is offline
post #40 of 42 (permalink) Old 12-11-2016, 07:57 PM
This is at least a 5 year old thread but,,, I use this
https://www.summitracing.com/parts/j...OALhoCBPPw_wcB
2nd 66 is offline
post #41 of 42 (permalink) Old 12-11-2016, 08:21 PM
my69mach1's Avatar
Nope, never had the need for one.
Nothing like MACH1 COBRA JET power
my69mach1 is offline
post #42 of 42 (permalink) Old 12-11-2016, 09:01 PM
My car behaves quite well even in the Texas heat, so I don't know how much I really need it, but it looks cool and it keeps it from making a mess on the rare occasion that it does get really hot.
Rather expensive as overflow tanks go, but it was delicious to empty.
